Question about HP LaserJet P2015dn Printer
How to change ip for hp printer 2015? - HP LaserJet P2015dn Printer
  • 10 Answers
Easiest way is to connect with internet explorer to its current IP address and in menu network change IP to desired values. You can get current IP by holding green button, until flashes orange button (triangle), then release green btn and printer will print 3 pages. in third page on top right is current IP address.
Posted on Aug 20, 2010
eng_darwish1
  • 233 Answers
SOURCE: default hp 2015 password so I can change the IP address
make a cold reset or NVRAM reset
To do a cold reset you power on the printer while holding down the go button for about 5 seconds and then release the button. If the button is held for more then 15 seconds it may do a NVRAM reset
Posted on Jul 07, 2008
SOURCE: HP LJ p2015dn IP configuration using HP Toolbox FX
Hi Basically I powered up the printer unplugged the network cable. Reconnected and waited 2 min. Pressed green button till first sign of green light flashing. The printer then printed out a printout which shows ip address on first and third page. I then used internet explorer to change printer from DHCP settings to fixed. just type new ip address on internet explorer address line. PC and printer must be on same network.
Posted on Jul 28, 2008
EPIJAB
  • 89 Answers
SOURCE: Printer prints blank on paper
Open the door half way through a page print and pull out toner cartridge. The page should be in the toner cartridige. If you can see the printed image then the fuser is the problem if you see nothing then the toner is bad or has a protective sleeve inside that needs to be pulled out from one of the ends.
Posted on Jan 08, 2009
Evildice
  • 217 Answers
SOURCE: how to get printer ip
You can also press and hold big green button for 5-6 seconds till you see 2 lights blinking then reliese button..printout will give you current Jet direct configuration :)
Posted on Apr 06, 2010
printerman40
  • 170 Answers
SOURCE: printer 2015 hp problem printer printing not
not really sure if I'm understanding the question but if I am, then you may want to go get a new driver and install it.
Go Here and make sure to choose your correct operating system then make sure to choose the pcl 5 and not 6 as 6 has been known to be buggy like that Click , hope this helps you out and if so please leave this a fixya thanks
Posted on Jul 04, 2010
Why hp laserjet p 2015 only showing ip address 0.0.0.0
This is most likely because it lost the IP address or it was not entered in the machine & saved so it goes back to default of 0's
Aug 13, 2014 | HP LaserJet Office Equipment & Supplies
Why does my hp envy 5535 stops in middle of print job
Please try following the steps below and let me know if that may help:
  1. Open the HP Envy 5535 software, then click the Printer Home Page (EWS) link.
  2. Click the Network tab.
  3. Click Networking , and then click Network Address (IP) .
  4. Click Manual IP , and then click Suggest a Manual IP Address . A manual IP address, Subnet Mask, and Default Gateway displays.
  5. Be sure to take a note of the IP address and Confirm the changes, then close the EWS page.
  6. From the HP Envy 5535 sotfware click the Utilities tab, then click on Update IP Address.
  7. Type the manually configured IP address, click on Save and confirm.
  8. Open the control panel and go to Devices and Printers.
  9. Right click the HP Envy 5535 icon and select Printer Properties.
  10. Open the Ports tab.
  11. Click teh Add Port button, select Standard TCP/IP and click on New Port.
  12. Follow the steps by typing the manually configured IP address and confirm the changes.
Read More... HP Printer Support
Thanks,
Jul 23, 2014 | HP ENVY 5535 E-ALL-IN-ONE PRINTER
P2015 printer go butan led on,genaral led on and job led on not printing not engin test
The formatter board is bad and needs to be replaced. You can buy one from IPS global at
Feb 24, 2014 | HP LaserJet 3030 All-In-One Printer
Hp laser jet p 2015 ip address
Umm, yeah..... you have to be a little more specific.
Feb 10, 2014 | HP LaserJet P2015dn Printer
We changed our router and now we can't print
You have to change your network settings (IP, Sub-net mask, Gateway, DNS) for that router.
I advise you to put an static IP address in your machine. Than change the gate in your driver. And so on, and so on.
It Will be like a new installation. Except the drivers (because you already have it installed in your computer (just change the IP in the printer properties)
You can also go to a chat and ask for help. Maybe they give you the step by step
Feb 23, 2011 | Ricoh Aficio 2015 Copier
I want to change the ip for ricoh aficio 2015
Try this:
Operation functions
ok
System settings
ok
Interface
ok
Change de IP and the sub-mask
ok.
In the and click ok to programe the information.
Hope you understand
Feb 16, 2011 | Ricoh Aficio 2015 Copier
I replaced a hp laserjet p2015 printer with another hp laserjet p2015 printer but it can't print.what's the problem,pls help me
This HP printer is comes with the USB cable. To install the printer software, you need to install the USB driver compatible to your printer and then it will ready to print.
Dec 08, 2010 | HP LaserJet P2015 Printer
How to get printer ip
You can press the MENU button on the Laserjet, on the right hand side of the button to keep to pressing the right side of the button until the Print Menu Map then press the Select button. THIS PRINTOUT SHOWS SHOWS YOU HOW TO NAVIGATE TO THE VARIOUS OPTIONS.
You can select the Print Configuration then press the Select button for a printout of the printer's configuration.
Alternately you can navigate to the JetDirect Menu to view or change the IP address settings.
Jan 17, 2010 | HP LaserJet P2015dn Printer
Default hp 2015 password so I can change the IP address
Jun 10, 2008 | HP LaserJet P2015dn Printer
Nov 20, 2007 | HP LaserJet P2015dn Printer
HP LaserJet P2015dn Printer Logo
939 people viewed this question
Seeker5211
Seeker5211
