Question about Microwave Ovens
My microwave just started to arc. Is the waveguide cover the metal piece inside the oven? Should I try to remove it to clean both sides with steel wool?
  • 619 Answers
No the wave guide is usually a porous material that almost looks like a light colored cardboard piece. Sound as if the stirrer plate is waht you are seeing. Make sure M/W is clean inside completly. Any build up of grease can cause this. Also make sure to check for chipped areas and if there are use an appliance touch up to cover the bare metal areas. A good cleaning will usually take care of the arcing tho.
Posted on Feb 07, 2010
Panasonic genius sensor 1250w
follow this test and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity paint.
Oct 27, 2013 | Microwave Ovens
Lg combi multiwave
see the troubleshooting section and follow the steps and fix it.
God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Sep 30, 2013 | Microwave Ovens
Oven aftron
follow this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#10#ixzz2aaus0Uj3
Jul 30, 2013 | Microwave Ovens
When i use the microwave it makes a very loud coughing and spluttering noise and there is a flashing of lights inside. It also smells of smoke. Any help greatly appreciated. I live Bristol, England if they...
proceed according. God bless youIf you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
If your microwave has a shelf in it, and you do not use it, keep it out. If one of the shelf supports breaks or comes out, the microwave will arc where the support was. You will have to sand the spot down, paint with appliance paint and re-install support. If the shelf shifts on the support and touches the side it will arc.
Your magnetron waveguide will either come out of the top, or side of the oven cavity. Some will have a stirrer in it(mostly top waveguides) with a panel over, or just a cardboard type cover over it. Over time, the stirrer cover can become warped from the heat which will expose the stirrer's metal shaft which will then cause sparking. These covers and stirrers come in a kit and can be replaced from inside the oven cavity.
Your cover over a side waveguide is coated with a substance on it, and overtime this coating can come off from the heat and moisture in the microwave. These waveguide covers are very easy to replace from inside the oven cavity. Touch up any paint that may have chipped or come off because of the arcing.
If your waveguide cover and/or stirrer are all OK, then the spark is coming from your magnetron. The antenna on your magnetrom has overheated and burned, sending the microwaves out at the wrong angle. If you catch this microwave oven repair early enough, you can usually get by with just replacing the magnetron. If the arcing has caused servere damage inside the waveguide, you will need a new microwave. Waveguides are not replaceable and most you can barely see into them, let alone sand and re-paint. In this case of microwave oven repair, when you remove the magnetron, you will see the burned antenna, or your magnetron will fail the test below.
Apr 04, 2013 | Samsung CE1031B Microwave Oven
Microwave when turn on making a noise and sparks comin from fan area?
Waveguide Cover
Rack Support
Feb 06, 2013 | Turbo Air TMW-1100M Green World 1000 Watt...
Kenmore microwave is sparking when you it start and then goes to pause
see this steps and fix it. God bless you
see the guide for test the magenetron and another component.
Oct 03, 2012 | Kenmore Microwave Ovens
Sparks when starting then goes to pause mode
see this next steps. God bless you
My LG/Dometic MICROWAVE sparks inside the cooking area when turned on
see the next steps and follow with common sense: God bless you
Microwave is arcing If you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
Jul 26, 2012 | Microwave Ovens
Sparkscome from food (no metal involved) and heating VERY quickly!
Arcing in or above oven chamberThere is often a simple cause:
  • Arcing in the oven chamber with a normal load (a cup of water, for example), often just indicates that a thorough cleaning of the oven chamber is needed, particularly around and inside/above the waveguide cover. Any food that gets trapped here will eventually burn and carbonize resulting in a focal point for further arcing. Usually, the waveguide cover is designed to be removable without taking the (cabinet) cover off of the oven. However, burnt food and carbon often make this difficult so that some disassembly will be required. See the sections: "SAFETY" and "Getting inside a microwave oven".
for more information see "Arcing in or above oven chamber" section of online Microwave Repair Manual.
If the microwave is clean, please post a reply and I will look at it again (this time include a model # and/or approx manufacture date)
Oct 21, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave is arcing inside
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is the plastic ceiling.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced.
If you need more specific help, please reply back with your brand and full model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Nov 13, 2008 | GE JES1384SF Microwave Oven
Microwave Ovens Logo
218 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
