Question about Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server
When Tray 1 (A4) is empty it is picking up Tray 2 (A4 ? letterhead) and we don?t want that to happen cause we print in bulk! When Tray 1 (A4) is empty it is picking up Tray 2 (A4 ? letterhead) and we don?t want that to happen cause we print in bulk!
  • Canon Expert
  • 287 Answers
Hello Uncle123,
I don't have a user manual at my fingers, but you can go into "additional functions". I don't recall if it is within the"common settings" tab or "copy settings" but you can designate any paper tray to be "unique". For example you can designate tray 2 as "colored paper, or recycled paper" .In which case, if you are feeding from tray 1 and it runs out the copier now knows that tray 2 has a type of paper that is different than the current run.Even if the paper size is the same. I hope this helps. Take care. ..............................spinal.........................
Posted on Apr 19, 2008
Why does my Samsung ML-3712ND printer say "paper empty in MP tray" when it is not empty?
The MP tray is the fold down 50 sheet tray that is built in to the front door of the Samsung ML-3712. It is usually used for thick papers, letterheads and unusual sized paper.
Sometimes people mistake the 250 sheet cassette tray that slides underneath the printer for the MP tray.
If you want to print on plain paper in your cassette tray and you keep getting this message.
1. cancel all print jobs
2. try printing a new document ( you can make a new word document with just one line)
if that works
Usually one of the settings in the print job you are printing will be out of specification ( could be too small margins) and the printer will be trying to feed from the MP tray
If the new print job doesn't work, the problem is likely in your default printer settings/properties
Dec 01, 2014 | Samsung Office Equipment & Supplies
How to set printing to tray #2? HP Laser Jet printer won?t stay printing on tray 2- They do a lot of printing from this printer in the wire room and for some reason it will not stay printing on tray 2-...
Thanks for the inquiry.
Print a configuration page from the menu to determine what Tray 2 is set to.Pull Tray 2 and make sure the rear paper stop is set to Letterhead. Make sure it snaps into place and is not broken or loose. If it's broken you may have to replace the tray.
On your computer got to the printer driver icon and right click for properties. Make sure tray 2 is set to 8 1/2 x 11. Tray 2 should now be the default tray unless tray 1 (Manual Feed Tray) is open and then it will pull from it first.
Let us know how this works. We need to eliminate these setup issues 1st and more steps can be taken if necessary.
Thanks for contacting FixYa.
Oct 20, 2010 | HP LaserJet P4015N Printer
Printing from wrong tray
I suffered from the same problem for a long time. We got Xerox Phaser 8550 and 8560 here. I choose on computer "tray 2" but the printer just print from tray 1 which is empty.
Today i figured it out! It's some configuration at the printer. So go to "Paper tray setp" -> "Tray 1 mode" and "Tray 2 mode" -> change to "static".
I figure it's like this. Before it was "dynamic", it probably means the printer decides it's better to use tray 1 even though you choose tray 2 - and this decision is stupid. Changing it to "static" fixes this.
Let me know whether this works for you too!
Feb 12, 2010 | Xerox Phaser 8560MFP Laser Printer
How to change the default tray on a HP 2430?
print config page of printer,see how trays are configured.
Jul 01, 2009 | HP LaserJet 2430n Printer
HP Laserjet 4250tn - cant print a letterhead invoice
Do a paper path test from each tray in diagnostics on the control paneland check Printer Properties for PAPER HANDLING
Feb 17, 2009 | Office Equipment & Supplies
Lexmark T630 printer pulls paper from wrong tray
Verify your settings under the Paper Menu are correct as far as size and type. All trays with same size and type settings are automatically linked as per the User Guide.
Dec 31, 2008 | Lexmark T630 Laser Printer
Paper Tray Settings
You have Auto Tray Switching acticated (ATS). Unless you specify each tray/paper with different settings it will switch.
Go in to the utility menu and you can find this in the paper tray settings area I believe.
You can turn this off completely to avoid this in the future.
If you look around you can even just tweak the settings for this, but in your case i would just shut it off.
May 30, 2008 | Konica Minolta bizhub C250 All-In-One...
Printing using various trays
Set tray (3? ) or other non standard paper type trays to type setting of letterhead and set normal paper tray (2) paper type to plain .
You do this on printer keyboad find menu then find paper handling, tray xxx, paper type. xxxx...set or tick
Via operations panel you can also printout current settings too to see if you have done the change if you do one before and after
Then test,
There are other settings on your printer that can effect this and driver configuation and doc type setting on pc that can effect this also but try step above first and report back if still having issues. Is it run by a server? Do you abity to change driver settings on your pc?
Oct 19, 2007 | HP LaserJet 4350 Printer
Computers & Internet Logo
237 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
