Question about Relisys Intro TE988 19" CRT Monitor
RELISYS TE988-RU Hi wonder if anyone can help, the buttons for horizontal movement dont move the screen but the OSD setting move but screen doesnt also the picture is bent at the edges. thank you for any help Kendo
SOURCE: OSD display on Relisys monitor 15" TH-561-RU
please reinstall ur display driver i was getting same problem u can also download driver software
Posted on Sep 11, 2008
  • 223 Answers
SOURCE: monitor menu shows up all of a sudden
If the butttons are not stuck on these monitors it could be something as simple as dry joints on the monitor somewhere. When this happens again lightly tap the front where the buttons are without pressing any and the sides then finally the back. If any of this tapping causes the menu to suddenly disappear and reappear then its dry joints. Otherwise it could be a number of problems. Post if it does not work and I will tell you more. Good luck.
Posted on Sep 30, 2008
  • 6 Answers
SOURCE: Relisys TL766 monitor. OSD menu continually open, wont close. Standby button doesnt always function.
Here is a definite solution to all those having problems with OCS menu on Relisys TL 766 Monitor.
Having tried many of the posted solutions none of which worked. The only option was to visit my local PC repair shop who disconnected the OCD monitor for UK £15.00. Spare parts for this model are no longer available. Only down side was the power indicator light in middle of now redundant control buttons does not work. Otherwise a monitor works perfectly. NO MORE STRESS.
Posted on Feb 19, 2009
Mark_Webber
  • 472 Answers
SOURCE: Relisys vertical bars
Sorry this wont help you much, but may put you out of your misery trying to repair it.
The LCD panel has failed. In particular the driver tabs that connect to the physical panel have failed and there is no way to repair them.
The only soloution is to replace the entire panel, a cost that would be close to if not more then a new TV of the same size.
I would put it on Ebay for parts (powerboard, logic board etc), and use the money towards it's replacement.
Peter
Posted on Mar 26, 2010
budmrtn
  • 11361 Answers
SOURCE: I have a Relisys TL766-RU(B/S)
90% of the LCD monitors failure are due to bad caps.
As you can see here:
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
If you have proper tools, you can do DIY repair.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Aug 17, 2011
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
No prende
Hi, welcome to FIXYA!
How may help you?
Apr 17, 2011 | Relisys Intro TE988 19" CRT Monitor
I can't get my icons and taskbar to center on my monitor. The start button is off screen to the left. How do I center everything so I can access them?
Press the OSD (On Screen Display) button on the monitor.
Use the UP/DOWN and LEFT/RIGHT buttons to navigate through the menu, to get to the "horizontal position" menu.
Press the OSD button to "select" that setting.
Press the LEFT/RIGHT buttons to "move" the image LEFT/RIGHT.
Press the OSD button to "apply" the new location.
Wait a few seconds, and the OSD menu should close itself.
Oct 24, 2010 | Microtek 815C 18" Flat Panel LCD Monitor
LG 700B SHAPE SIZE AND POSITION UPSET PLEASE HELP TO RESTORE
Push the button on the Monitor to activate the OSD (On Screen Display). With the OSD, one can "stretch" the picture (horizontally/vertically) and "move" the picture (horizontally/vertically) in order to "fill" the viewable area with your compueter's output.
May 09, 2010 | LG Flatron F700B 17" CRT Monitor
A 1/2
there are 2 possibilities 1. you have changed screen resolution by accident, try using that [right click desktop and properties, look in tabs there] or 2. your screen is old and it has "burned out" in some parts
Oct 14, 2009 | Relisys Intro TE988 19" CRT Monitor
My computer's display has moved!
I have seen apparently random movement on crt monitors..
Usually it needs nothin more than a small adjustment from the OSD (on screen display) if you have buttons on the front of your monitor they are for the OSD your manual will give you more detail about it. Or if you dont have a manual then having a little "play" will not do any harm if you dont adjust any settings.. You will normally see some icons in a box on the screen when you press the correct button on the monitor.
the icon you are interested in may look like two screens on top of each other
Aug 19, 2009 | Computers & Internet
Blue screen moved right. can't move it back to see my entire desktop
OSD Lock/Unlock
Allows you to secure the current control
settings so that they cannot be
inadvertently changed. You can unlock
the OSD controls at any time by using
the same procedure.
Push and hold the Menu ( )
button for 10 seconds or more to Lock
or to Unlock.
May 03, 2009 | Computers & Internet
Oct 15, 2008 | Relisys TL 766 Monitor
Sep 11, 2008 | Computers & Internet
Relisys Intro TE988 19" CRT Monitor Logo
Top Relisys Computers & Internet Experts
Samuel Konger
Samuel Konger
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
