Question about Nintendo DS Lite Console
The top screen on my DS Lite lights up but there is no picture, the touch screen works fine and so dose every thing ellse.
    Guru:
  • 110 Answers
Chances are the screens ribbon connectior has become loose or the screen has develouped a fault.
If its under warranty then send it in, otherwise you can take it to a local repair shop or do a bit of DIY.
Take the DS lite apart (a tri wing screwdriver is needed and can be found cheap on ebay), disconnect the top screen by lifiting the motherboards connector flap (located near the hindge) and then re-insert it, try switching it on again and see if thats sorted it. If not then you will need to replace the screen.
A new screen can be brought on ebay for a reasonable price, there will be a little soldering required as the speakers will need to be de-soldered from the old screen and re-soldered onto the new one (please take note of which wire goes where).
Remove the screws from the lid of the DS lite (4x screws hidden under little coloured squares above and below both speaker outlets) slide the top/outer part away from the hindges, it will move about 5mm and then you can lift it off... Gently pull the ribbon through the hindge so that it is free from the bottom part of the DS lite, pry the screen away from the shell (a small amount of force may be required to remove it) remove the front plastic part of the screen (with the respective DS lite coloured frame, de-solder the speakers, re-attatch them to the new screen, place the new screen into the housing along with the speakers and put back the wifi and mic to their original position if they got moved, you will notice a slot in the hindge where the ribbon goes in, this is for the ribbon to easily slide back into the bottom part of the DS lite... pop the ribbon through and then re-attatch it to the motherboard with the connector, pressing down the connectors flap.
Screw the DS lite back together and hope fully this has resolved the issue.
If you find that your DS lite now doesn't want to stay powered on please refer to my other tips and tricks I have issued on here.
I hope this helps and have to say that I accept no responsability for any damage that may occur to your DS lite when following these tips.
Regards,
SOD69
Posted on Feb 08, 2010
  • sod696969 Feb 08, 2010
    Whoops I forgot to mention that after you hve put the DS lite back together and put all the screw into place you will need to place the plastic sheet with the respective DS lite coloured frame back onto the top screen... The reason you don't put it on any time before that is if you put it on prior to putting the new screen in place you will have great difficulty trying to get it correctly aligned.
    Regards,
    SOD69
My DS lite has fallen: bottom-display won't show...
The bottom screen has gone out. They are pretty easy to fix and can be purchased from ebay and other places also.
Feb 08, 2010 | Nintendo DS Lite Console
Bottom screen black
Your bottom lcd is busted. It'll have to be replaced.
Look online for Nintendo DS bottom lcd replacements.. Fairly cheap
May 17, 2009 | Nintendo DS Lite
Bottom screen of Nintendo DS Lite won't work
Ok, I may be able to help you.
One is it new?
Two is it Damaged in any way
Three does it still have a warrenty?
four Can you post pictures (LCD may be dammaged)
May 10, 2009 | Nintendo DS Lite Console
Bottom screen on nintendo ds lite has power but no picture
this happened to my friend. she sometimes got really mad and tapped the touch screen too hard. try contacting nintendo. they helped me a lot.
good luck
Mar 28, 2009 | Nintendo DS Lite Console
Nintendo DS lite; changed touch screen and it won't start
Hi. this issue is normaly caused by bad screen (normaly top screen) or bad assembly in one of two screens, re insert carefully the flex cable again, if your screens are fine this must fix the issue
Mar 14, 2009 | Nintendo DS Lite
Top ds lite screen is red green and blue
The same thing happened to me, You might want to replace your ds touch screen...
Feb 05, 2009 | Nintendo DS Lite Console
Ds lite
sorry to say that your top screen needs completely replacing if it is doing as described!!
the bottom screen and the touch screen are seperate, jus mounted on top of each other, so if the picture works on the bottom then the bottom screen is fine just the touch screen is broken. again i think if the cables/ribbons are in correctly and it isn't responding then it will need replacing!!
Jan 29, 2009 | Nintendo DS Lite Console
Faulty game console
Maybe the ribbon cable was damaged. the ribbon cable is a flat wire thing used to connect the top screen and bottom screen. you can buy a ribbon cable on ebay for a cheap price.
if that wasn't the problem, maybe the bottom lcd screen is dead. you'll need to replace that.
Dec 26, 2008 | Nintendo DS Lite Console
Nintendo ds lite,green light on but not the screens
I had the Same problem on my wifes DS.  First problem was that it kept swithing itself off, so sent it to Nintendo for repair.  Within a week it was broken again.
This time the green light was coming on, but no sound and no sign of life in the screens.
Well, I'd already had to pay nintendo for the first fix (different region, no warranty, apparrently).  So I thought seeing as it's out of warranty anyway, why not open it up and have a look.
To open it you need specailist tools, I don't recommend it if you've never done anything like it before.
Anyways, the bios chip was no longer connected to the main PCB.  I simply plugged it back in and added some slips of post it note to stop it coming off again.
You can see in the picture, the chip easily plugs back onto that white clip on the board.
Once it was back on. the DS has been working fine.
Feb 27, 2008 | Nintendo DS Lite Console
TOUCH SREEN NINTENDO DS LITE
aparently fitting a new touchscreen works, i have just ordered one from ebay, cost me a tenner
Dec 31, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
567 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
