I have a problem with my Lifestyler C760 Triple Action Electromagnetic Silent Drive Exercise Bike. The tension belt (drive belt) walks up on to the right/outside edge of the tension pulley (pedal crank pulley). The belt appears to be in good condition. A replacement belt is no longer available. I have adjusted the belt tension per the manual instructions, but this does not solve the problem. I don't understand how to align the rear tension pulley with the front belt hub so that the belt will stay in the pulley groove. Any suggestions?
  • leonardowrey Jan 20, 2009
    How can I get the specifications for the powersupply/Power Cable of the Sears Lifestyler C760 exercise bike?
    I have a number of powersupplies but I am not sure which one works with my Lifestyler C760 exercise bike. I do not want to apply the wrong voltage by using one with too high of a power rating
  • gennoh144 Apr 03, 2009
You can download the User's Manual as a PDF file for free:
http://www.fitnessequipmentcatalog.com/lifestyler-owners-assembly-manual.htm
A complete parts list is included in the manual.
Posted on Apr 09, 2008
Posted on Apr 06, 2008
I have a NordicTrack C2270 NTL12950. the belt is slipping. I have attempted to tighten it, but it seems to keep slipping. I would like to figure out if it is the walking belt or the drive motor belt.
if it's the walking belt, make sure that the rear roller is parallel to the back of the walking board. Sounds goofy, stand on the mill looking back away from the front of the display. Look down to where the walking belt goes around the roller, the roller should be parallel to the walking board.
Jan 09, 2018 | NordicTrack Exercise & Fitness
How to stop the bike from slipping
Hey
This may help you
https://www.youtube.com/watch?v=GWYERtOBFI0
Sep 25, 2016 | Nordic Track NordicTrack Commercial VR...
Feels like pedals slip once in a while. How do I repair this please?
replace the spring, maybe it has lost some of the loading and become "tired".
Jul 03, 2015 | Cybex Cyclone 530c Upright Exercise Bike...
Walking belt slip, sliding away!
You need to replaced the walking belt and have a professional reset the drive belt to the proper tension.
Aug 01, 2017 | HEALTHRIDER S300i Treadmill Motor Control...
We just bought a gently used Lifestyler Expanse 1500 treadmill today; it turns on & runs nice & smoothly...until we walk on it. When we start walking on it, it wants to slow down & we feel like...
From the manual: Troubleshooting
Symptom: The walking belt slows when walked on
a. If an extension cord is needed, use only a 14-gauge general purpose cord of five feet or less in length.
b. If the walking belt is over-tightened, the treadmill performance may decrease and the walking belt may be permanently damaged. Remove the safety key and UNPLUG the power cord. Using the 3/16" allen wrench, turn both rear roller adjustment bolts counterclockwise. 1/4 of a turn. When the walking belt is properly tightened, you should be able to lift each side of the walking belt 3-4 inches off the walking platform. The center of the walking belt should just touch the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert safety key and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
c. If problem persists, contact customer service.
Sep 17, 2017 | RTO Exercise & Fitness
The walking belt on this Lifestyler Expanse 8.0 Treadmill has slipped towards the left side; folding the left side of the belt over itself.
I'm sorry to say that the belt is toast and needs to be replaced. I would also check the end caps I believed it is a one piece unit that the belt tension bolt is attached and the left side had cracked and cause this problem. Call Icon Fitness @ 1-800-999-3756 with locating the proper parts and pricing
May 28, 2010 | RTO Lifestyler Expanse 8.0 Treadmill...
Belt stops running while standing on the treadmill
Either front roller may need to be replaced or the motor drive belt may need to be adjusted. This problems are caused when a walking belt is worn out and in need of replacement. Too much tension can cause bearing failure in the motor and the front roller and front roller pulley failure.
Motor drive belt adjustment: The motor drive belt is adjusted independently from the walking belt. Some newer models have an auto tensioner which is a lever that has a wheel that puts pressure on the drive belt and a spring on the other end that automatically loads the belt to the proper tension. You should not adjust these since they are preset. Tension can be affected slightly by adjusting the tension of the walking belt but if you have a slipping problem, the drive belt will require replacement. If your drive belt is too loose, it will slip on the front roller pulley or the motor pulley. If it is too tight, it will increase your amp draw to the point that you may have an electronics or motor problem. Due to this, it is better to be on the safe side and replace a drive belt rather than risk over tightening it.
Feb 20, 2010 | Proform CrossTrainer Treadmill
I have a Lifestyler 8.0 Treadmill. It keeps
Use a good silicone Spray under the belt for every 10 hours of use
Jan 02, 2010 | RTO Lifestyler 8.0 MPH Treadmill Walking...
Lifestyler c760 power supply values/specs
it is made by technical Devices
AC ADPTOR Model No. DV-1250
Input: 120 VAC 60Hz 12W
Output: 12VDC 500mA
Apr 21, 2009 | Exercise & Fitness
Washing Machines Logo
758 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
