Question about RCA HD52W59 HDTV Projection Television
How do I access the Factory or service menu? - RCA HD52W59 HDTV Projection Television
While the TV is on, turn it off for 10 seconds, after 10 seconds hold the vol down and channel down buttons on the front of the set for approx 10 seconds until set turns on. The service menu will be displayed
Posted on Feb 21, 2010
Panasonic CT-30WX54j: What is the sequence for a complete factory restore?
Check the site linked here for more detail. All of it is not possible to include here by this window. http://electronicshelponline.blogspot.com/
Dec 07, 2013 | Panasonic CT-30WX54 30" TV
For a Panasonic CT-30WX54J: What's the button sequence to do a factory restore of the settings in the 'Service Menu'.
Press and hold Power & Chnnel button on the front panel of the TV, and plug it to AC power. The set must come on with service mode screen. The procedure will differ set to set. If you wish to get some details, check the site linked here.Pull up older posts.
Dec 07, 2013 | Televison & Video
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
The word "Factory" has appeared on the screen in red
Hi.
Factory on screen means that the TV is stuck in service mode (Durabrand and more). The problem is fixed accessing Service mode and resetting to factory default settings.
On Durabrand TVs problem is fixed using a programmable remote, entering service code on remote, and accessing service menu.
Procedure is listed on TV service manual.Most durabrand use Menu and key combination 683 to access service mode.
If that does not work, calll manufacturer number to get the key sequence to enter factory menu.
Jul 06, 2010 | Televison & Video
Need codes to display service menu for esa et427e
This is a Funai product. Factory reset may be 1 2 3 4 DISPLAY. But Funai manuals I have refer to a "Service Remote" to enter service menu.
Mar 13, 2010 | ESA ET427E 27" TV
How do i unlock the key--- display on my Provision television that is operated by a beko 12.1 remote control.I also need the service code for some Geometric adjustment.
Service Menu Access Procedure To access the service menu, press and hold the handset sound mute button whilst pressing the TV's front panel 'Menu' button (under the front panel cover on the TV). The up/down channel buttons on the handset step through the options and the left/right buttons change the data values. Turn the TV off to get out of service mode and DO NOT touch any other handset buttons whilst in service mode. Service menu access is also similar for many other Toshiba large-screen TV's so this procedure may work on other Toshiba TV's - even those sold outside the UK.
Maybe this list can help you, click here for a list of each widescreen Toshiba TV Service Menu adjustment with details on the purpose of each.
The factory settings of each service menu option will be entirely different on every TV manufactured, due to component, tube and scan coil tolerances, so don't under any circumstances adjust your TV's settings to my factory default settings or your TV's picture will probably look awful! The factory settings are provided out of interest - the useful part of this document is actually the definition of each service menu option. You will see that some geometry settings are duplicated for each screen mode such as 'Cinema' and 'Subtitle'. This could, for example, help resolve a geometry problem that's present just in one screen mode.
I hope help you with this.
Oct 14, 2009 | Televison & Video
Dsc-w40 when turn on the word access and lens goes in and out
Please remove the Battery from the Camera then reinsert it after three minutes. Please make sure that the Battery is fully charged. If menu options are accessible then reset the Camera to the original factory settings. Please follow the steps that are mentioned below to reset the Camera to the original factory settings.
(i) Turn ON the Camera.
(ii) Press the Menu button on the Camera to display the menu options.
(iii) Then use the control button on the Camera to the select the Setup option.
(iv) Next, select the Setup 1 option then "Initialize".
Performing the above steps will reset the Camera to the original factory settings.
If the issue persists even after resetting the Camera to the original factory settings then service will be required.
Jul 13, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
How do I access service menu to reset lamp timer for Optoma H56?
In order to reset the bulb counter you need to access the Service Menu:
To access the Service Menu:
Turn on and warm up
press the following sequence:
Up
Up
Left
Give it a few goes, it took me 5 minutes to enter with the right timing. The Service Menu will appear, highlight factory reset and the counter goes to 0. Job done. Cheers, Matt.
Apr 15, 2009 | Optoma H56 Multimedia Projector
Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
Apr 13, 2008 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Looking for service menu of 32Q6TVH LCD TV (NEC and Onida)
HI FRIEND,
I DON'T KNOW THE SERVICE MENU OF NEC BUT TO ENTER IN ONIDA PRESS VSM AND DISPLAY BUTTON SIMULTANEOUSLY, FROM ORIGINAL REMOTE .
JABBAL,
9422117997
NAGPUR
Jan 15, 2008 | NEC PlasmaSync 42MP3 42 in. Television
RCA HD52W59 HDTV Projection Television Logo
168 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
