I just purchased a 32 inch sony bravia hdtv, I hooked it up and the screen says no signal
circuitcity
  • 137 Answers
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Posted on Dec 06, 2007
SOURCE: How do I hook up the HDMI cables to a cable box
how do i hook up hdmi cables to cable Sony KDL Bravia LCD HDTV
Posted on Sep 26, 2008
welcomejee
  • 10594 Answers
SOURCE: replacement table top stand for sony bravia 32
OK, Following is part number of Stand of KDL-32S3000 TV
A-1259-944-A STAND (M_WS) ASSEMBLY (KDL-26S3000/32S3000 ONLY)
It is available in Part Store.
Thanks.
Posted on May 18, 2009
  • 8 Answers
SOURCE: hook up speakers to 32 inch lcd hdtv
"Line" level audio output is available at the audio output phono jacks at the top of the rear panel, but not speaker-level output. So, you'll need an amplifier to use in conjunction with your external speakers. (An alternative would be "powered" or "amplified" speakers that have their own amplifier, but often are less satisfactory acoustically). You don't necessarily need to get a full-fledged "receiver" with multiple in's & out's... I simply used an inexpensive stereo amplifier.
Connect the "Audio L - R" jacks on the rear of the set to the "line" or "aux" inputs on your chosen amplifier and speakers. If you go into the set's Menu - Option - Output Select and set it to "Variable", the internal speakers will be disabled, and you can control the volume (and muting) of the audio sent to the amplifier, and still have "armchair" control of the volume as before... but now with better stereo!
Posted on May 22, 2009
vinnyq
  • 157 Answers
SOURCE: remote doesn't work for sony bravia 32
You can check if it is the remote itself by using a digital camera or cell phone camera. Point the remote control towards the lens of the camera like you are taking a picture of what is being transmitted. Start pressing buttons on the remote, if you see a blinking light on the LCD screen of the camera, then the remote is transmitting correctly. If not, replace the batteries in the remote. If this does not fix it, you need a new remote.
If the Remote is transmitting properly, then it is either the IR sensor inside the TV or the main board. There is no easy way to check this without taking the TV apart. This can only be checked by the verifying the voltages along the line, you would need a technician to work on it unless if you have a voltmeter, the service manual and an basic understanding of how circuits work.
Posted on Oct 05, 2009
My screen is cracked on my 32 inch sony bravia.is there a replacement scrren i can buy
Replacement panels are available for purchase, but in most cases it will cost more to replace the screen Vs. buying a new set.
Jan 13, 2013 | Sony BRAVIA 32-inch 720p LCD TV...
Greetings. I have a Sony 40" LCD HD TV hooked to a DirectTV DVR device. When I turn the TV on, sometimes the screen is discolored, or the audio doesn't work, or the screen size is wrong. Any ideas...
The tv Tuner signal board is dying and the causes.That the board,where all the output devices and the incomming broadcasting signal cable plug in.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 05, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
HDMI NO SIGNAL
make sure you set it to an acceptable resolution
try 640x480 that should always work
then try 1024x768 that should work too...
if not, could be a failiure, but is usually just a setting
Jul 26, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony V lcd 32 inch losing digital channels and after doing a resetting scan it is ok for about 30 mins.... then screen image breaks up totally and message 'weak signal' shows on screen. Help,please.
You answered the question in your question.
''weak signal' means exactly that, however it can also mean the signal is too strong.
If you have a booster installed into the ariel remove it, if not, try one. Make sure the TV is directly connected to the ariel, not via a DVD recorder or any other devices which require an ariel input.
Sony tv's have very sensitive tuners installed so its just a case of making your aprticualr settings compatible.
Check signal strength over at www.digitaluk.co.uk
Thanks
Nov 29, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
TV screen reading no signal. We have satellite
tune in tv or put tv in AV / EXT mode the no signal means not tuned or on areal in tv
Nov 28, 2009 | Sony Televison & Video
Can you fix a cracked screen on a sony bravia 32 inch
HELLO
The answer is simple to this one....NO!
This is the main problem with LCD TV's when the screen is cracked a replacement screen will cost more than a new set.
Your only cure is a new TV!
Oct 20, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have a sony bravia xbr 32 inch and the picture is only on half the screen
It is possible that Twin Picture function is enabled, turn it off with remote/ menu options.
If this is not the case then T-Con board sounds bad and needs to be tested/ replaced.
Qualified tv tech will test and replace it.
Thanks.
Oct 06, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Replacing LCD TV screen
crack on the screan of 32 inch plasma
Mar 03, 2009 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
I can't Tune my V32XBR1 in Australia
Greetings...
Are you connecting to a digital signal from a cable box using an HDMI cable?
Ed
Apr 03, 2008 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Bravia Color
why can't you adjust the color? What do you mean
Dec 22, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
