Question about GE Profile JKP56 Electric Double Oven
Jkp56 I just installed a used GE JKP56 double oven with the smartset controls etc... and the lower oven comes on when power is applied to the unit without any control indication or selection on the control panel. Any suggestions?
  • longwings Feb 22, 2008
    fixed!
    was a grounded wire in the back going to the element.
2 Suggested Answers
Powerman
  • 68 Answers
SOURCE: jkp56T
The relays are soldered to the printed circuit. You would need to find a relay and then unsolder the old one and resolder the new one. This requires special skill. I would not recommend it unless you are comfortable with printed circuits.
An alternative would be to contact CG Industries at www.cgiltd.com.
They repair applicance electronic components.
Good Luck,
Powerman
Posted on Mar 08, 2008
Panel on jkp56 is dimming
Try removing the connectors to the electronic control (power off first) panel and reinserting them. It could be just poor connections. If this doesn't fix it the control board or power board could be failing.
Feb 20, 2014 | GE Profile JKP56 Electric Double Oven
GE Oven JKP56...after Self Clean bottom element in upper oven stays hot. Breaker off, let cool, breaker on...bottom element gets warm (all controls off). the breaker is off for now. Please help.
Hello, Thank You for using FixYa. I will be helping you today.Leave the power off remove the screws from under the panel and lift up to open the control panel. There are reset-able fuses in there check them by pressing the center red button if they are ok check the screen in front of the fan make sure its not blocked up it will cause this problem too.If all that is ok then the relay on the control fused closed and you would have to replace the control board with the relays on it.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | GE Profile JKP56 Electric Double Oven
I just bought a 35 w halogen bulb from lowes for my GE truetemp profile JKP56 built in oven. I just spoke to a GE rep who sells the bulbs and he said the bulb has no replacement numbers so I don't...
If the bulb you bought from Lowes is a 35 watt bulb and it screws in, then it will work just fine.
Appliance parts people love to sell you the "one" specific for your model because most of the time it is more profitable for them.
Good Luck!
Joey
The top oven stopped working 1 year ago, electricity was there, oven lamp goes on, but won't get warm, so used lower over and now it quit and for the same reason
the elements have broken down you need to replace them go to part4us and put in your oven name and model number and thay will find them for you thay also do a video on how to change them your self
Oct 27, 2010 | GE Profile JKP56 Electric Double Oven
Double oven, top oven run by keypad turns off
I have a double oven. The top unit works fine. The bottle unit will turn on to cook or clean. Then after a few seconds it turns itself off.
Oct 12, 2009 | GE Profile JKP56 Electric Double Oven
JKP56 and JTP56 Differences
Those are not full model numbers, but basically a JKP56 fits a 27 inch cabinet and a JTP56 fits a 30 inch cabinet, so obviously the key panel / control panel would be different. I looked up a couple ERC range controls, and they are also not compatible. Note: usually you will not need both of those parts. The most common of the two is the front panel. (common F1 error code) If this answers your question a "FixYa" rating would be appreciated. Thanks.
Sep 25, 2008 | GE Profile JTP56 Electric Double Oven
Jkp56T
Good Luck,
Powerman
Feb 22, 2008 | GE Profile JKP56 Electric Double Oven
Lower and Upper ovens not heating
they have a thermal fuse in them that blows if too much heat builds up in them they have an improved blower moter thermal fuze kit for them i suppect thats the promblem contact ge for improved kit and inst ins
Dec 29, 2007 | GE Profile JKP56 Electric Double Oven
Open Questions:
The convection fan comes on intermittently, starts smoking then goes off. Temperature on the display doesn't move from 100F (then it did). My wife left the door closed while it was on broil last night (not sure how long), and this morning I woke up to the smell of burnt electrical and something (one of the fans...? not sure as it was far earlier than I usually get up) running that stopped when I opened the oven door and restarted when I closed it (I'm thinking it was probably running all night). While at work, I turned the breaker off, then pulled the oven out this evening. After taking some of the metal plates off, I put the power back on and turned the oven on for a 450F bake. I don't know if the little cooling fan at the top of the unit is supposed to go on when I have the top exposed and getting plenty of air; it wasn't and it also had a faint burnt electrical smell. After disconnecting then plugging the fan power connector to the circuit board the fan ran for 10-15 seconds before it started smoking and quit. I checked voltage across the fan leads and there wasn't any. I shut the oven off, tripped the breaker, and let it cool. I then tried testing the fan motor directly i.e. bypassing the oven and using a regular outlet since the motor is rated for 120V. It ran for ~1 minute, then smoked and quit. The smoke is definitely coming from the fan rather than any adjoining wires. Is this a case of the fan AND the control board going south or one contributing to the other's demise? I should add that the clock display has been dimming for a couple of years. UPDATE (2/20): I tried just baking (as opposed to convection baking) and the bottom element did come on (I'd reported earlier that it hadn't... that was because I was using convection baking and that does only heat around the fan... just my ignorance on that one). However, the temperature readout on the display did not move from 100F though it was clearly hotter than that in the oven. I then stopped the baking mode and started convection baking. This time the temperature gauge immediately went to 141F and kept climbing. Resistance at the (room temp) temperature sensor (and at the end of the wiring harness plugged into the control board was ~1100 ohms at room temp (as its supposed to be).
Feb 19, 2016 | GE Profile JKP56 Electric Double Oven
See all GE Profile JKP56 Electric Double Oven Questions
GE Profile JKP56 Electric Double Oven Logo
94 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
