Question about DXG Technology DXG-305V Digital Camera
How do I install the drivers?
How do I install the drivers correctly in Windows 7 64 bit? It worked fine when I had Windows XP. Now, when I install it, nothing happens.
I want to download driver for my digital camera DXG 4.0
Posted on Feb 07, 2010
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Apr 03, 2014 | Video Game Consoles & Games
System won't recognize downloaded driver, I have installed an update provided on HP's site, but it still won't work. trying to install on a windows 7 computer. had installed it earlier on a...
When downloading a printer driver from HP you will need to ensure that you are selecting the correct OS (eg. Windows 7) and the appropriate version (eg. 64 or 32 bit operating system). These drivers are different and using one on the other will not work.
Windows XP drivers also will not work properly in a Windows 7 environment and the majority of Windows XP drivers are 32-Bit.
Sep 06, 2011 | Office Equipment & Supplies
Hello and Help! :) I have Microsoft Picture It! 2002 and it was working fine on my old XP, but now that I have Windows 7 I just get a message that says, "Picture It! has stopped working. A problem...
Hi , I have Works 2004 and Picture It! works fine under my Windows 7 Ultimate 32 bit . It's possible it would'nt work in a 64 bit system . If this is the case and you have Windows XP install disc , you could :
install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
or partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html. Easy and safe , no specific knowledge required .
Regards .
Jan 17, 2011 | Computers & Internet
I have an old Princeton VL 173 that I had been using with an old computer running Windows XP Pro. It works fine. Got a computer with an Asus MB and a Intel Core 2 Quad running Windows 7 Home Premium...
It sounds like a driver/software issue. When you ran the Princeton VL173 on XP you probably had all the correct software for your video card and the correct drivers to support your video output. When you changes OS to Windows 7, the XP drivers are no longer in place. My best guess is that you need to find and install the correct drivers for your system video and for your video card that are Windows 7 compatible. The old XP drivers will not work in Windows 7.
I am running XP with a Princeton VL173. It works great. I identified the correct video drivers for my system and installed them. My video card is nVidia 8800GT. I downloaded and installed the latest software from nVidia and installed it. It runs like a champ.
Several months ago my display died. It was just blank -- black. I tried using a power supply (AC adapter) from an old HP printer that died, and it worked! The plugs were identical, and the power output profiles were very nearly identical. It has been rinnung great for many months now.
I hope this helps.
Steve
Dec 29, 2010 | Princeton Digital VL173 Monitor
Scanjet 4470c. Can't get it to work with Windows 7. Any ideas on a solution or is there a Windows 7 driver out there?
Hi ,
I succeeded to make my Scanjet 4470c run in WIA mode under W7 32-bit Ultimate . Should also work with W7 64-bit .
Make sure driver XP ( yes , XP ) is correctly installed .
Then , download and install FreeKapture ( yes , it's free ) from here : http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Load Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanner works fine in this mode but if you choose HP PrecisionScan Pro , program will freeze .
In any case , no slides or negatives scans possible but the rest works .
Regards .
Dec 13, 2010 | HP Scanjet 4470c Flatbed Scanner
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Scanjet 5470c with WIndows 7?
better download the latest driver for your scanner from the hp's website and while selecting the new driver you have to specify that you are using windows 7 and also specify if it is 32 bit or 64 bit you will get the driver , install it and connect the scanner it will work ..... thats all....
Feb 04, 2010 | HP Scanjet 5470c Flatbed Scanner
Installed windows 7 - now standard VGA driver is not working correctly
if you installed VGA driver for windows xp then it might not work;try using vista driver if windows 7 driver is still due;and don't forget to check if your os is 32 bits or 64 bits
Nov 24, 2009 | Everex StepNote NC1500 Notebook
Running digi 001 on windows 7
i got digi 001 running on windows 7...
i left my xp on hard disk while installing win 7. it kept xp on folder windows.old folder. in control panel i saw digi as multimedia adapter wich system couldn't recognice. hit "change settings" -> driver -> update driver
used my old windows to search for driver. it found "Dalvin.sys" driver for adapter. installed that. after that windows recogniced digi 001.
downloaded "digidesign asio 6.11" driver installer for win-xp and ran it.
and bingo - it works!
in every step windows was complaining and asking do i want to do this. just yeah'd everything. as i just had a clean install of win 7 i just thought whatta heck i can install everything again if it would not work, but it did.
so in a nut shell:
1: install Dalvin.sys in control panel for digi 001
2: run digidesign asio 6.11 driver installer for win-xp
for me it worked but i absolutely take no responsibility if you mess your system with this! at least reaper got a sound out of it. i haven't tried to record anything yet. but asio settings seemed to work as they used to do in xp.
- veikko-antero
Mar 17, 2009 | Digidesign Mbox 2 Barebone
Vista to XP downgrade
If you did a clean install of Windows XP Vista has nothing to do with this problem. I infrequently have problems with Dell drivers not working but when I do its because I've installed the wrong ones. I have gone down the wrong troubleshooting path several times because the driver said it installed correctly..... I noticed that when you go to the Inspiron 6400/E1505 download page (http://support.dell.com/support/downloads/index.aspx?) you have the choice of selecting drivers from lots of OS versions including both 32 or 64 bit versions of XP. I would verify that you have the write driver versions and try again. Another alternative is using the drivers and tools CD that typically comes with a Dell. You can run that and it should have XP drivers. If you don't have the disk you can also try getting the network card running, connect to the Dell site and running their driver ID wizard to ID the drivers you need. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 20, 2007 | Dell Inspiron 6400 Notebook
DXG Technology DXG-305V Digital Camera Logo
167 people viewed this question
Top DXG Technology Cameras Experts
Jerry Greenberg
Jerry Greenberg
Derick Williams
Level 1 Expert
Are you a DXG Technology Camera Expert? Answer questions, earn points and help others
