Question about Canon PIXMA iP1600 Printer
Canon ip 1600 printer pulling on one side
The printer is pulling paper on right side and not going through printer correctly
  • 4 more comments
  • yarnmommy Feb 28, 2008
    I am having the same problem ip1700. tried using the 'clean paper feed rollers' maintenance, four times, still pulling to the right
  • ObiKenobi Mar 18, 2008
    Likewise with my iP1600. The paper gets pulled to one side like it's getting caught on something. Has someone found a solution to this problem yet?
  • braniti Mar 20, 2008
    I have same problem... who knows... maybe some Canon trick to punish users that did refilling.. .
  • lucyshade Jun 23, 2008
    Same issue - it worked great for a year and then suddenly started feediing the paper in on the right but not the left. There don't seem to be feeder wheels on the left, which is weird, but I haven't moved it or changed it in any way except to dust occasionally. So it can't be that a wheel fell out or broke or anything.
  • Anonymous Jun 23, 2008
    i have the same problem cant fix it can you help
  • das897 May 11, 2010
    thats happening to me, the paper keeps geting jammed and it says that its out of paper, and inside the roller is also jammed.
    HOW CAN I FIX THIS? ='(
I need driver for canon ip1600 mac os 9.2
Posted on Mar 07, 2008
DOUBLE SIDED COPYING
First normaly copy first side, then take copied paper and set it in bypass tray, when you do thath, the copier ask you for paper size and type, choose correct sett. and confirm with OK.The side on wich you want to print must be face down in bypass tray.
May 11, 2010 | Canon iR 1600 Laser Photo Printer
The printer warps paper on entry .
try to reset your Canon printer, turn the printer off with the power button. Then disconnect the data cable from the printer. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable. Then turn the printer back on.
Jul 02, 2008 | Office Equipment & Supplies
When the printer pulls a sheet down it grabs the right side of the sheet (as you face the machine) leaving the left side up, to warp the sheet and make a grinding noise trying to pull the sheet in. Of...
Solution: Cleaning The Paper Feed Rollers (Windows) iP1600
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the printer properties.
  2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  3. Remove all sheets of paper from the auto sheet feeder.
  4. Confirm the following message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. Thisactivation will take about 90 seconds. Do not perform other operationsuntil this operation has finished.
  5. Confirm the following message, and click 'OK'.
  6. After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  7. Confirm the following message, and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
  8. Click 'OK'.
Roller Cleaning is completed.
Canon iP 1600 printer won't print. Says that
Hi
If it keep saying paper jam Then it maybe just that you may not see any paper in it but it only takes a very small bit of paper that stopping it or I would take a closer look inside, you may have had a paper jam before and it has left a small nit inside. All Best: Pineworks
Feb 01, 2010 | Canon PIXMA iP1600 Printer
Canon pixma ip 1600...can't clear paper jam there is no paper jam but it keeps telling me there is
possible that there is a very small piece of paper near the edge or back that the sensor is picking up ... check again and see if there is something there
Jan 10, 2010 | Canon PIXMA iP1600 Printer
Canon pixma ip 1600. paper feed mechanism faulty. will not grab paper and feed through or takes it through at an angle
You said that the paper is fed on one side. Am I right?. If it so,it seems that another material is present inside your printer.
Please check this post for more information
Nov 29, 2009 | Office Equipment & Supplies
Paper pulls to right side and bunches up
Have you tried pulling off the back cover and wipe the rubber wheels off. some times they get dust on them and can cause them to not be able to grab the paper correctly.
Oct 22, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Canon Pixma iP 1500 is not feeding paper correctly, pulling it on the right side but not on the left.
If the feed roller in the back wobbles a lot, the end could be broken, but usually I find that something has fallen in the back stopping the paper. The best way to look for something fallen in is to use a flashlight and small mirror.
Jul 12, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Cannot get the printer to take the paper
Its the paper feeder,, this can be repaired by changing the small greas that grab the paper , you will need to do this by taking the prointer apart. Unfortunately chances of getting it to pull straight after repairing it is very very slim. If i were you i'd toss it out and buy a cheap printer like a canon ip 1600, which can refill ...
Jul 21, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon ip 4300
Google "canon ip4300". The canon.com entry near the top has a support tab. and enter "paper skew", you'll get a roller cleaning procedure.
As a matter of fact, it didn't solve my problem. The alternative, of having the machine repaired, is, of course, silly vs. buying a new machine. But in the meantime, the lower paper feed still works, albeit slightly less convenient.
Apr 22, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA iP1600 Printer Logo
96 people viewed this question
old marine
old marine
