Question about LG WM-2277HW Front Load Washer
My LG washer is stuck and won't drain so I can't open the door to fix the problem which I suspect is it is overloaded. What do I do?
  • 90 Answers
Hi
Turn OFF the main power supply to the machine .After 7 minutes the door will get unlocked irrespective of level of water in the tub. As long the power is going to the machine the lock will not open.
Regards
Berry
Posted on Feb 07, 2010
  • 1,543 Answers
Try turning power on to washer and only pushing the spin speed button to select a low speed spin, without selecting any cycle. This should display a short (12 -14 minute) time on the display. Push start. The washer should pump out and then spin. If no pump out, open access door at bottom left of front panel and use small hose to drain out water. (as long as the hose is not blocked with sand) Then, remove the big knob next to the hose to clean out filter. If filter was clear, you may need a new pump motor.
Have an LG front end washer. Last few loads there's been a faint burning smell. Today after a wash there was the same odor but also what appeared to be smoke coming out when opening the door. Help?
you have a bad spider gear caused by overloading and using to much soap,it would be easier and cheaper to replace the washer,you have to remove the whole tub assy. separate it and change out the spider gear or spin basket.you should only be using two tablespoons of he detergent that's it,when you open the door or when the washer drains do you smell a nasty smell?that's from all the soap buildup.if you look into the tub on the back wall it looks like a piece sign,that's the gear,the washer might have been really loud in the spin cycle
Nov 10, 2017 | LG Washing Machines
Miele W1926 Door Won't Open
You probably still have something stuck in the filter in have had the same problem and found it to be the remnants of hair scrunchie.good luck
Feb 22, 2013 | Miele W1926A Front Load Washer
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
Le error code on my LG washer.
On LG Washers the code LE is for motor overload protection.
Ensure that you are not overloading washer, make sure to clean pump by draining at little door at lower left corner(check manual for instructions), unplug for 30 minutes to reset, now try running cycle again. if it fails again something else is causing the motor to work to hard and will require a professional.
Apr 25, 2009 | LG WM-1832C Front Load Washer
LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Apr 11, 2009 | LG WM2042 Front Load Washer
Ice build up on floor of freezer drawer starting under ice maker
since this problem is discussed over and over on various models, I point you to a detailed manual that shows (with images) how to solve the frozen drain pipe issue. This is the manual by Avi
good luck
Feb 08, 2009 | LG LRFC25750 Refrigerator French Door
Washer won't run....
It seems as an overload issue. The machine has an overload switch to protect the motor. Take the comforter out and operate the machine,it should work fine. Good luck!
Sep 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
LG WM-2277HW Front Load Washer Logo
341 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
