Question about Freezers
Maytag Performa PTB2153GR making a clicking noise and food is thawing in freezer, fridge not staying cold
  • Anonymous Mar 15, 2014
    freezer thaw out makes a noise
  • 4,793 Answers
Check no ice around pump unit. then try manual defrost both.no hot water. clean filters/drain holes.dry as best you can then switch on.
use thermometer to check temp -20c in freezer
Posted on Feb 11, 2010
Bosch FD8709 Fridge Freezer (American Style) Freezer section not cooling (Ice maker has stopped making cubes and food starting to thaw) Fridge section seems to be working OK..! In Manual says that the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 05, 2011 | Bosch Freezers
Not cool enough to freeze the food
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
I hope this helps.
Regards.
May 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer not freezing .. It's cold..
I hope this helps........
Take care.
Apr 12, 2011 | Northland Panel Ready Upright Built In...
Freezer stopped freezing. food started getting soft on top. power light on. green light off. tapped it , green light on. less than 1 yr old.
Good luck.
Mar 02, 2011 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
Maytag freezer keeps thawing food
I am no pro on these but it sounds like your defrost heating coils are coming on to often. You may want to check them. Aslo just for good measure>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 20, 2010 | Freezers
Frigidaire won't make ice & dispenses only about 4 oz. cold water
Water frozen in the freezer supply line - you need to thaw out the freezer. About six hours, door open, turn freezer OFF. You'll need a cooler with dry ice for your frozen food. 99% certain it'll work after that.
May 26, 2009 | Freezers
Freezer not getting cold to freeze
ok if this fridge uses a defrost timer, it's probably stuck on defrost or the defrost thermostat is faulty also check the number on your thermostat it its on a low number the fridge won't cool properly also a refrigerant leak could be suspected.
May 17, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Maytag freezer
sure its on ly 3 years old. you rseled system should be covered for 5 years (compreessor, freon, evap, condesor). was it making a buzzing noise?? trying to start and clicking right off??? thaose are sounds a bad compressor makes,
Mar 19, 2008 | Maytag Freezer MQU2057
Freezers Logo
377 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
