Question about LG 32LX1 32 in. HD-Ready LCD Television
External audio sound
I have a surround sound system, which I KNOW works ok, however when I connect the red and white wires to the back of the LG tv I have just bought, there is no sound? please can you advise?
  • ammir001 Oct 17, 2008
    when i connect my sony dav800 to my lg 42inch it doesnt giv out any soun yet u can still watch dv n hear d sound n listen to radio.
  • 92 Answers
BE SURE THE SETTINGS IN THE TV MENU ARE CORRECT IF THEY ARE IT IS POSSIBLE YOUR BOARD NEED TO BE REPLACED
Posted on Feb 22, 2008
Connect tv to surround sound system
Connect a RCA cable from the TV Audio output (red/white)
to the surround sound Audio Input (red White)
If your TV has a "HDMI OUT" and your Surround System has a
"HDMI Input" Then use a HDMI cable instead.
You will need to set the source on your Surround System to
the audio source you use on the surround system(input)
On most it will be TV or Auxiliary.
Sep 30, 2014 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
How do I get audio out of 32lc2d to go to the external surround sound system
Depends on your external sound system... If it supports HDMI, then just connect an HDMI lead between the TV and the external amp. If you don't have HDMI, look for two RCA/Phono connectors (small circular connectors) on the back of the TV (should be coloured red & white) and connect these to the external sound system. Finally, if you don't have either of these look for a 32 pin scart socket (rectangular with a bit sticking out) and get a scart to phone cable. Plug the scart plug into the TV and connect the Red & White output leads to your external system - hope that helps :-)
Aug 18, 2014 | LG 32LC2D Television
How to set up to my tv
Ok...sorry it took me so long to get back to you...Check the back of you tv and look for RCA jacks for audio and video out...There should be a yellow one for video..a white one for audio left(L) and a red one for audio righ(R)...you may not need the yellow one...now look for any inputs on the rear panel of the surround sound system...They can be marked (AUX)...they will work..once all of these are located...you will need an RCA patch cable long enough to reach from the tv to the surround sound receiver...once done...turn on the tv and the surround sound.With the remote from the surround sound remote...switch between the input sources..maybe (AUX) until you hear your tv sound come through...then you adjust the sound as needed...Assuming the DVD is built in to the surround sound system...your DVD sound will come back when you play DVD's...All connections and cables are color coded so you should have no problem connecting everything....Good luck....let me know how it goes,,,,I hope this was helpful....PEACE.....
Jan 05, 2012 | Audio Players & Recorders
I have lg lcd Lg42pq10r and I don't know how to connect its sound nd hear its sound through lg dvd home entertainment system 500W?
Look on the back of the TV for Red and White Connector. Look on the back and this should say Output or Line out. Wire the REd and white connectors to that ( not the AV sockets ) and then into the back of the surround.
Mar 22, 2011 | LG 42LC2D 42 in. LCD HDTV
How do I get tv audio out of my surround sound HT3550U. I have HDMI cable in and function turned on TV audio. I also have LG TV. Any Ideas ???
What is the TV source?
If you have a coax (antenna or some cable systems) to the TV, then you need to connect the surround sound system to the audio out of the TV. Depending on the TV, the output could include Digital audio, RCA audio (red/white) or a headphone jack. Without knowing which LG TV model, I can't be sure which ones you have. Get the best cable for your TV/receiver system and connect that. Then set the TV to use the external speakers.
If the source is a set-top box, then the cables should run HDMI from the box HDMI out to the receiver HDMI in and then from the HDMI out of the receiver to the HDMI in on the TV. (Most TVs do not have HDMI out.) If the unit still doesn't play the audio, first try new cables and make sure the correct source is selected (some receivers have multiple HDMI in). Make sure the speaker cables are all connected (if they have separate connections) and that everything has power. (One of the usual speaker system problems in my house is loose cables from someone knocking against the back of the entertainment center and pulling.)
If you need more help, please provide more information on your equipment. I will do my best to help you diagnose the problem.
Nov 11, 2010 | Audio Players & Recorders
I cannot get sound from the tv through the surround sound, speakers all tested and work ok and dvd sound comes through ok when playing dvd, radio works fine also, worked fine 2 days ago with sharp tv, have...
Hi, You have to make sure you are using the "audio out" from the dvd/surround into the "audio in" on your TV also in some case TVs will need to change the "input" with your remote to see where you connected your dvd/sur also some TVs have a switch for "n" or "off" for internal speakers and also you could have that option in your audio menu on your TV, Hope it help, good luck. Mike
Oct 19, 2010 | JVC TH-G30 Theater System
How to hook up wii to surround sound
Put all the wires to the tv. Now you need another A\V cable (yellow, red, white) only use red and white from, audio out on tv to audio in on surround system and set it to TV. OR Put the red and white from Wii to surround system and the yellow to the tv. this way you have to use surround to hear it. The other way you can use the tv or both. The first way is ideal if you have an extra cable.
Mar 15, 2009 | Nintendo Wii Console
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
HTS-GS1 Surround Sound System cannot be utilized for tv.
Check Your TV audio setup,many TV makers out there would like you to turn off the tv speakers in order to use the external speakers.
Joe
Feb 03, 2008 | Pioneer HTS-GS1 Theater System
No surround sound for TV
There are a few possibilities.
1)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the TV Audio OUTPUT to the "Audio In/TV" portion of the HTS (NOTE: Many TV's do not have an Audio OUTPUT).
2)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the Audio OUTPUT of your cable or satellite box to the "Audio In/TV" portion of the HTS.
Note: Using a red and white cable may not give you sound on all 5 speakers.
3)Get a digital audio or SPDIF cable and run it from the TV, Cable or Satellite Box's Digital Audio OUT to the "DIGITAL IN" of the HTS. This will give you the best sound quality. When using this (or any of the other) type of connection, press SURR until you get sound from all 5 speakers.
Also, the manual can be obtained from www.usasupport.philips.com
-Tha Mp3 Doctor
Nov 18, 2007 | Philips HTS3400/37B System
LG 32LX1 32 in. HD-Ready LCD Television Logo
105 people viewed this question
