Question about Sony VPL-DS100 Multimedia Projector
Where exactly is the fuse located for Sony VPL DS 100?
Take out the screws on the bottom. Flip it over and take off the top plate. Pull (from the connectors) the wires going over what looks like a steel plate with several small holes. Take out the screws (6 total) holding that plate and the circuit board on. Pull off the steel plate and the plastic under it. Lift up on the circuit board under that: there are to connectors on the underside that have to be removed. Once you get it out, the fuse is near the end, about 3/4" long and ceramic white.
Posted on Jul 31, 2010
Sony vpl dx 100. Why does it indicate frequency out of range when I connect my VGA cable to the the port?
Sony VPL DX 100 is a native XGA projector [1024x768]
so if u connect to a PC that has higher resolution than XGA , it will not be able to project and will show u out of range .
you will need to reduce the screen resolution in your resolution settings to XGA and the problem will be solved.
On a Laptop however, the graphics card should automatically identify the native resolution of the projector and adjust the screen resolution that is being sent from the graphics adapter.
you can also repalce the VGA cable and check if the problem gets solved as a broken pin or cable internally can also result in a similar problem!
Jun 05, 2015 | Sony Office Equipment & Supplies
Want to reset sony vpl ex7
where it the RESET located? I do not have any on my VPL-EX7
Jan 02, 2012 | Sony VPL EX7 LCD projector 2000 ANSI...
Sony VPL HS 1 will not start after a power cut, fuse ok, including first stage fuse inside unit. standby light not on ..any ideas?
Try cleaning out the filter. There may be a heat protection mechanism in there. We had much less problems after cleaning (or replacing the dust filter).
Feb 23, 2010 | Sony VPL HS1 Multimedia Projector
Data projector is not turning on. How can I check for broke fuses?
open up the top case. the fuse will be on the power supply board right next to where the power cord plugs in. you'll need a continuity tester to test it. if it is blown, replace it with the exact size and type. if it is not blown, replace the power supply.
Feb 02, 2010 | Sony VPL-EX4 Projector
My sony vpl-cx6 projector does not power up
If the fuses are ok, and there is no st by light,
replace ic3100 in the psu order no.A-1302-316-A
Nov 13, 2009 | Sony VPL-CX6 Multimedia Projector
Sony VPL-DS100 will not turn on
I had same problem. The cause was a blown fuse (T5.0 Amp 250V). You have to open the case and then get below the print that is under the alloy cover. it is quite simple to fix. A fuse costs 60 cents.
Apr 18, 2009 | Sony VPL-DS100 Multimedia Projector
Will not turn on
I have the exact problem on the exact same model .
HELP ... I have been told it may be a problem with one
of the power supplies on board ??? is this a red herring ?
May 23, 2008 | Sony VPL-CX75 Multimedia Projector
Sony VPL-DS100 Multimedia Projector Logo
303 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
