Question about Nikon COOLPIX P4 Digital Camera
Broken piece on my nikon coolpix p4 between the battery and sd slot there is another little slot. what exactly is this. it's empty now but once had a little white piece in it?now the camera wont turn on. Battery is good.
  • 2 more comments
  • hoome3 Feb 29, 2008
    I'm having the same problem. My son broke off the top of the little white piece when removing the memory card. I can get the memory card to insert properly, but the camera won't turn on.
  • Sam S Iam Mar 15, 2008
    Yes i have the same problem
  • lwubbena Mar 23, 2008
    My camera will not turn on after white piece near memory card slot broken off.
  • TimKnight Jul 11, 2008
    Ihave a Nikon Coolpix P4 digital camera. I very happy with this camera and lovethe features. I use this camera a lot. Just recently camera will not power on.Battery is charged. I did notice thou that when I open the battery compartmentthat a white tab fell out. Very small and I lost the tab due to being outsideand it fell in the grass. I did look for it but never found it. Furtherinspection I see where that tab might of cam from. Above the card holder andbelow the battery there is a slot there and looking thru a magnifying glasslooks like that is where the tab goes. On what principle does this tab work? Iknow it is a switch. Is it a push or lever switch? If it is a lever switchwhich way is on. How can I fix this so my camera will work again? Is there adiagram on how to take this camera apart so I can fix this part? If so what isthe direct link? Send reply to TimWhiteknight@mac.comThank you for you time.
Only solution to turn ur camera on is to get that plastic fixed coz it is slided when u close ur battery cover to connect the power on.without it circuit is broken and camera cant be turned on.
Posted on Oct 29, 2008
How much memmory support does it provide nikon coolpix p4 vr
The P4 has about 23MB of internal memory, which might hold five pictures at the camera's best resolution. The camera also accepts SD cards up to 2GB in size, which should hold several hundred pictures. And, of course, you can use multiple cards.
Jan 04, 2011 | Nikon COOLPIX L18 Digital Camera
I woold like to use a 8GB for my coolpix P4. May you sugest me if it is possible and which brand ?
Unfortunately, you can't. The P4 only works with SD cards, and SD cards max out at 2GB in size. This is a hardware issue and cannot be changed by a firmware update.
Dec 27, 2010 | Nikon COOLPIX P4 Digital Camera
Good Day, I have Nikon coolpix P4. The manual states 1GB SD card max. What is the Max SD card I can really use? Can I use SDHC Memory Cards and up to what size: tks Bat
Do you have any reason to doubt the manual? If the manual doesn't specify SDHC, then I wouldn't bother trying any but stay with SD only.
Dec 13, 2009 | Nikon COOLPIX P4 Digital Camera
A white piece fell out from the spot next to the memory chip of my Nikon coolpix P4 camera, now the camera will not turn on, can you tell me what this piece is for and if my camera can be fixed, thanks
if you feel technically inclined you can open the camera carefully and take it apart to the point where you can remove the upper circuit board ( NOTE 1: make a careful note of every screw you remove since they are different size and need to be used exactly in the same order) and then the small black plastic assembly above the circuit board below, you can see the defective switch on top of the 2nd board, remove the plastic part of the switch until you see the bare 2 contacts on the circuit board, solder a small piece of wire to bridge the contacts, now very carefully reassemble the camera observing the exact order of screws used, see NOTE 1. If everything is back in order insert the battery and the camera should work now.
note: should you not be inclined to do this work and want to sell the camera as is for spare parts I am interested, drop me a note at: cocnutray at yahoo.com. A Nikon repair shop will charge between $80 to $110 FOR THIS TYPE OF REPAIR, THEY WILL ACTUALLY REPLACE THE DEFECTIVE MICRO-SWITCH. HOPE THIS HELPS :-)
Nov 27, 2009 | Nikon COOLPIX P4 Digital Camera
Wont turn on
The problem is a tiny microswitch which is located between the battery slot and the SD card slot,
Apr 03, 2009 | Nikon COOLPIX P4 Digital Camera
White plastic between card slot and battery charges plz
Ok, I Joe McGee'd the issue -- take a small piece of tin foil -- make it fit the hole area. Insert it and poke it into each open "port" on both side -- pack it in with a pin --
Mine is working fine now -- not sure how long, but it works.
Oct 29, 2008 | Nikon COOLPIX P4 Digital Camera
Nikon P4 all Photo's are "green"
try getting a new SD card and transfer the old photos to the new SD card
Sep 17, 2008 | Nikon COOLPIX P4 Digital Camera
Nikon Coolpix P4 - no power after little piece between battery and SD card ...
the little white peice is what holds ur battery cover closed i think, so without a closed cover it cant really function. i think so anyway
Jun 12, 2008 | Nikon COOLPIX P4 Digital Camera
My camera dose not whant to turn on.
The problem is usually cuase by a broken microswtich which is located between the battery slot and the SD card slot and it is activated by a tab in the battery cover.
If you feel technically inclined you can open the camera carefully and take it apart to the point where you can remove the upper circuit board ( NOTE 1: make a careful note of every screw you remove since they are different size and need to be used exactly in the same order) and then the small black plastic assembly above the circuit board below, you can see the defective switch on top of the 2nd board, remove the plastic part of the switch until you see the bare 2 contacts on the circuit board, solder a small piece of wire to bridge the contacts, now very carefully reassemble the camera observing the exact order of screws used, see NOTE 1. If everything is back in order insert the battery and the camera should work now.
Jan 31, 2008 | Nikon COOLPIX P4 Digital Camera
Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
Oct 15, 2007 | Nikon Coolpix 3200 Digital Camera
Nikon COOLPIX P4 Digital Camera Logo
116 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
