Question about Garden
I have a poulan weedeater. It starts easily but then dies.
I prime the engine and it starts then dies. I prime it again and it starts and dies again. Seems like it can't get gas unless I manually pump it. Anybody know what causes this problem? Air filter is clean. Thanks Bob
  • 246 Answers
SOURCE: Poulan 17'' Gas Weedeater keeps dying!
Hello su2yak2:
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holdong it to the Carburetor Body.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 9 Answers
SOURCE: weedeater XT 85T wont run
Check to see if your feul line is cracked or it is drawing air . Check your clamps that hold the lines on . One other thing you can check is to see if any bolts are loose that hold the carb on . Best of luck Ed.
Posted on Jun 18, 2009
  • 279 Answers
SOURCE: Replaced Poulan 25cc weedeater fuel lines/Now no start
You have/had a fuel filter in the tank.The connector goes to that filter, I think. The length does mean something but I don't know any way to figure it without a manual. You could try to figure from the total length. The fuel filter hold the line toward the bottom. Good luck.
Posted on Jul 14, 2009
SOURCE: ENGINE STARS AND THEN DIES
Try changing the fuel filter and if that dont do it there is a small screen inside the carb that usually plugs up carefully disassemble it and clean it out with a good brand of carb cleaner
Posted on Jul 20, 2010
SOURCE: 31cc Poulan Pro Weedeater
Sounds like the fuel lines are crossed. Either the in and out lines on the primer are crossed or the primer line on the carbureator is crossed with the normal feed line. Good luck
Michael E.
Posted on Aug 02, 2010
Poulan pro weedeater will not start without starting fluid and wont accelerate after starting Once started the first time it is easy to restart and idles fine, just cant accelerate the motor without it...
Your carburator is clogged.
1st make sure you have FRESH gas.
Empty and clean the fuel tank
Remove and disassemble the carburator and soak it in fresh gas for about 15 minutes to disolve any gunk.
Using a can of small carburator cleaner ( available at Lowes, Home Depot etc.) blow out all the ports.
reassemble and refuel with clean fresh gas
The little carbs clog easily
May 19, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Jul 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Jul 20, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan pro weedeater will start fine run untill you pick it up then dies
poulan has a bad habit of the fuel breaking inside the tank if it breaks before the fuel filter that makes the fuel line shorter
Nov 05, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Weedeater won't take fuel
You need to remove the carb., disassemble and spay with carb. cleaner. Use a Den Tek Brush, (used for cleaning between teeth), toclean the small portals in carb. Check the small screen. It could have dirt clogged in it. Reasseble and start. If it still doesn't run properly, you will need to buy a carb. kit and replace the screen, needle valve, gasket(s), & diaphragm.
Jim
Jun 04, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Echo trimmer won't start, gasoline flows out of exhaust
look at choke and air filter. ensure choke is operating and clean air filter.
May 24, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Hello su2yak2:
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Poulan Garden
Garden Logo
789 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
