Question about HP Computers & Internet
Windows freezes after startup
After I startup my laptop, after about 10 - 15 minutes the laptop freezes.
How do I stop this?
I deleted the temp files, cookies etc.
I removed the unnecessary startup programs
Then tried running checkdisk but it froze midway through....
I dont think it's worth trying diskdefrag as it'll prob freeze
Any help would be appreciated....
  • 129 Answers
Its better to backup your data - booting from Ultimate Boot CD and backup to an external hard drive.
Try to do regular format or low level format to know the status of the hard disk
Posted on Feb 09, 2010
Hasee laptop
your System may be slow due to following reason
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
So Follow these steps to fix computer freezes problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 10, 2013 | Crock Pots & Slow Cookers
Slow processing
Sep 02, 2013 | HP Computers & Internet
Computer slow and freezing
Sep 02, 2013 | Acer Aspire 5500 5570-2609 Laptop
Freezing up laptop
many things will make it freeze... the biggest reason is a virus or malware.. 2nd will be a bad hard drive... DO NOT take it to best buy.. craigslist has many competent people that will fix it for far far far less that the best buy scammers
Jun 16, 2013 | Computers & Internet
Compaq presdio slow desktop windows xp
  • Remove unused programs
  • Install and run antispyware software
  • Free up wasted space with Disk Cleanup tool
  • Defragment your hard disk drive
  • Disconnect unused network connections:
Click Start, and then click My Computer.
On the Tools menu, click Disconnect Network Drive.
Select the network drives that you no longer need, and then click OK.
ALSO
Stop Unwanted startup programs:
Start > Run > write msconfig > Click on StartUp tab
Deselect the programs you want to stop
Delete Temporary Internet Files:
Click Start - Run, type in %temp% and then click OK.
Once that temp folder is open and you can view its contents, select and delete EVERYTHING that's inside it.
Repeat the steps with c:\windows\temp
After you're done with both temp folders, restart the computer.
Services:
Click Start, type services.msc in the Search box. Press ENTER. Right click and stop each service which is not necessary for you.
For an instant fix use Intel Software Partner Reginout. WebRepOverall ratingThis site has no rating(not enough votes)
Dec 13, 2012 | Compaq Presario 5000 PC Desktop
They freeze and play, freeze and play the whole video
Press on Window button and "r" on the keyboard type Temp when temp window open delete all of the temp files. Then again press window button and 'R' type %temp% then delete all of the files from the window. after deletin the files again press windows + "r" then type 'msconfig' go to start up then uncheck unwanted software from the start up and click on applay and OK, Then restart the computer.
Sep 23, 2010 | Computers & Internet
Computer turns on, however after 2 minutes
Corrupted Registry
System registry corruption leads to runtime errors and your computer crashes.Windows Registry is very complex and not easy to repair manually. Hence, athird-party Registry Cleaner and PC Optimizer software is recommended.
1. Download a Registry Cleaner and PC Optimizer software such as Reginout.
2. Click Registry Cleaner tab.
3. Click Start Scan.
4. The registry scan will start. Wait till it is finished.
5. As per the results, click Fix Now button to start repairing you registry.
Often good registry cleaners include built-in Backup & Restore centre thatlets you recover from an unforeseen situation by simply restoring the state ofyour registry.
Faulty RAM
Your computer freezes due to problemswith the computer memory. A faulty RAM may result in Blue Screen of Death(BSOD).
In such a case, remove the existing RAM and clean it using a soft cloth. Then,connect it again. The problem may not persist..
Incomplete Installations
Your computer freezes because of a previously failed or incompleteinstallation. An incomplete or failed installation creates junk registryentries and thereby system crashing problem.
Repair the registry entries created by a failed setup and delete the files thatstill remain on your hard disk. Delete the contents of C:\Windows\Temp folder.
Disk Space Allocated by Unnecessary Files
Your computer freezes if the operating system has no adequate free disk spaceto perform its operations. Temporary files, temporary internet files, logfiles, browser cache and other files may occupy a large amount of your diskspace and thus generating runtime errors that crashes your system.
Using Disk Cleaner, delete the junk files from your hard disk. The steps are asbelow:
1. Click Start ' All Programs ' Accessories ' System Tools ' Disk CleanUp.
2. Follow the instructions on your screen.
May 10, 2010 | Acer Aspire 5500 5570-2609 Laptop
Trying to play games on yahoo, ican get all the
delete your cookies, browsing history and temp files. If that doesn't work click on either your vista logo or start button in the bottom left hand corner. In the run box type the word MSCONFIG, press enter. Click on the startup tab. Click on the disable all button then click on apply, OK and let the machine reboot. This will stop alot of the programs from starting up when you boot into windows. See if this works.
Dec 27, 2009 | Gateway M305CRV Notebook
Ever so slow response to typing an email using Hotmail
hey here are somethings you need to do.
1) Open internet explorer -> Tools-> Internet options ->General -> Browsing History -> Delete -> Check all boxes -> Delete. (IE 8, The process is quite similar in other browsers as well)
2)For XP
Start-> Run-> type temp-> Ok-> Select all-> (Shift +Delete)
For vista
Start-> Start Search-> type temp-> Ok-> Select all-> (Shift +Delete)
3) For XP
Start-> Run -> type %temp%-> Ok-> Select all -> (shift+delete)
For Vista
Start-> Start Search-> type %temp%-> Ok-> Select all-> (Shift +Delete)
4) Turn off laptop, Remove battery , Remove AC adapter, Press power button for 2 minutes. Put both back on. Turn on laptop.
5) Run virus scan and check for malware and other virus related issues. If anything is found delete the infected files.
6)
For XP
Go to Control Panel-> Add and remove programs-> Remove all unnecessary softwares
For Vista
Go to Control Panel-> programs-> Installed Progams->Remove all unnecessary softwares
7)
For XP
Run-> msconfig-> Startup->Disable all
For Vista
Start search -> msconfig -> Startup -> Disable all
8)
Check for the system RAM. If your laptop has 2 memory cards installed. One might have failed. So try to remove it and fix it back again and check
Aug 15, 2009 | Acer Aspire One D150-1587 Netbook
Freezing
hi
please follow below steps :-
1- disk cleanup in C drive. right click on C: drive and click on properties and click on disk cleanup button.
2- type TEMP in run command and delete all file in open windows.
type in %temp% in run command and delete all files in open windows
3- try to download superantispyware and smitfraudfix.exe for delete infected files.
http://www.superantispyware.com/downloadfile.html?productid=SUPERANTISPYWAREFREE
http://siri.urz.free.fr/Fix/SmitfraudFix.exe
disable unwanted startup items from the MSCONFIG
type MSCONFIG in run command.
click on startup items then disable unwanted programs
Thanks
veeru_india
May 08, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
137 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
