Question about Acer ScanWit 2720S Film Scanner
SCSI to USB conversion for Film Scanner
I have a ACER Scanwit 2720S film scanner which connects to my PC via a SCSI card installed in my PC. The drivers are only maintained up to Windows XP so probably excludes any option to change my PC to Windows 7 machine.
Can I get a convertor to connect the SCSI 25 pin output from the scanner to USB. And will I need some alternative S/Ware?
Doug Draper
  • 457 Answers
SCSI to USB converters are available, but I doubt they will be of much help for you, you'd still need a special driver for your scanner.
Windows 7 Professional, Enterprise, and Ultimate support "XP Mode", essentially a Windows XP environment running in a virtual machine. I'd try to get the SCSI interface card and scanner to run inside the VM as a workaround.
Posted on Feb 07, 2010
Do not have software for scanwit 2740s can you help
If you have a computer that is compatible the drivers are freely available for download. http://www.techspot.com/drivers/driver/file/information/13718/
Oct 19, 2013 | Acer ScanWit 2720S Film Scanner
I am running XP Pro SP3 and have installed a SCSI card and software for the scanner. When opening the utility I get error #5 cannot confirm scanner connection. Please confirm scanner's connection and SCSI...
Hello, just check you have a scsi terminator fitted to your scanner as without one you can get all sorts of bus errors. Also, keep the bus length as short as poss.
n.b. some of the later scsi devices are auto-terminating, so check the spec of your devices, and by the way,. don't plug and unplug your scsi bus whilst it is powered up as this can cause the hardware to blow (it's not like a usb plug and play bus)
Hope this helps!
nicam49
Dec 29, 2010 | Konica Minolta Dimage Scan Dual IV Film...
Computer restarts when trying to aquire photo's
go to control panel, then system,advanced tab, startup and recovery. look under startup and recovery then uncheck the block that says automacilly restart then ok. you are experiencing a software- hardware failure and when you do this you may be able to provide enough info to lead to the repair. could be as simple as an incompatible driver
Jul 06, 2009 | BenQ ScanWit 2720S Film Scanner
OVT scanner does not calibrate nor allow "acquire picture"
I had a similar problem. Driver of scanner was ok.
Went to configuration->device manager-> in list checked the USB controllers and updated the Enhanced usb2 controller. Reboot and re-install de scanner driver. Most likely this will solve your problem
regards, Andre
Jun 20, 2009 | BenQ ScanWit 2720S Film Scanner
Scanning Size
Do not try to change the scan size, change the resolution. The window that appears when you want to scan should have a resolution (DPI) area that can be changed. IE: 300 DPI to 800 DPI. This changes the picture size.
May 16, 2009 | BenQ ScanWit 2720S Film Scanner
Where can I find Linux drivers for BenQ Scanwit 2720s?
sudo apt-get install sane
Then visit this web-page to learn about Benq (formerly Acer)
http://www.sane-project.org/sane-mfgs.html#Z-BENQ
Apr 11, 2009 | BenQ ScanWit 2720S Film Scanner
Driver for scanwit 2720s
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/Benq/Benq-ScanWit-2720S-2012.shtml
Mar 19, 2008 | BenQ ScanWit 2720S Film Scanner
Benq scanner
did you try to uninstall driver completely and fater did you reinstall the driver ?
Feb 10, 2008 | Acer Scan to Web 3300U Flatbed Scanner
Acer ScanWit 2720S Film Scanner Logo
867 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
