Question about Garmin StreetPilot c550 GPS Receiver
LOw battery message on my C550 Garmin gps. I charge through my computer but it wont take a charge through the car. Charge will only last 3-4 days wjcorban@gmail.com
    President:
  • 1,738 Answers
There may be a problem with your car charger. You may be able to find one on eBay.
Otherwise, you may want to contact Garmin Customer Support for assistance.
North America - Consumer Products
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Posted on Feb 08, 2010
Says I have a low battery. I think I am missing the battery and holder located on the side. What is the battery I am missing?
The battery is inside the satnav. If you get a message saying that your battery is low you should plug in the car charger for 4 hours, or a mains charger for 4 hours or connect it to your computer for 8 hours to charge it.
If it fails to charge by any of these methods the battery may be worn out and unable to take a charge. If this is the case you need to return it to garmin to have the battery replaced.
Mar 02, 2011 | Garmin nuvi 260W GPS Receiver
Will not charge c550 garmin
OK, THANKS, THE MOST LIKELY PROBLEM HERE IS THE BATTERY IS DEFECTIVE.
Nov 11, 2009 | Garmin StreetPilot c550 GPS Receiver
Garmin Nuvi 265W just will not switch on!
Bad or very low battery
Replace at Garmin
But first know this:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sounds like a bad or low battery. Do you have the Garmin approved charger / car charger?? You may have to send your 265 in for battery replacement or try this:
There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F respectively) then it will not charge. When connected to external power it will only be operating off of external power.
2 - The Quest® and Quest® 2 will not charge using a USB cable.
Aug 06, 2009 | Garmin nuvi 265 Car GPS Receiver
Recently when returning from a trip my C550 giving keptme the message "satellite unable to locate" (not the exact words) This went on for a week or more but suddenly started locating me from the satellite....
Low battery power is generally r4esponsible for loss of signal or low signal. Charge itr fully before use and plug into car power source ONLY AFTER staring the engine so as to avoid spike deamage. The car charger cannot fully charge the battery it is justn sufficient to maintain a level of charge . If the battery gets too low it cannot maintain a constant signal.
Jul 24, 2009 | Garmin StreetPilot c550 GPS Receiver
How to charge battery street pilot 550 on computer
If everything is working correctly you should be able to just connect your Garmin to the USB on your computer and it will charge the battery.
May 02, 2009 | Garmin StreetPilot c550 GPS Receiver
I can't chrage garmin c550 using carg charger gtm20. But I can charge using usb connected to computer. I had to replace fuse and I may be missing a part in gtm20 assembly. Is there a spring? How does
There is a fuse in the cigarette lighter end on the power cable, twist off the end of the adapter to expose a cap, fuse and spring.
Hope this is of some help.
Ed
Apr 20, 2009 | Garmin StreetPilot c550 GPS Receiver
Dead Garmin c550
had same exact problem. my unit would come on for a minute and then go black. if you take the silver ring around the face you will see the four screws to take the unit apart if you do have to replace the battery. however first try hitting the reset button on the right side of the unit. remember the cover needs to be off. i hit the reset and my unit powered on with no problems
Oct 31, 2008 | Garmin StreetPilot c550 GPS Receiver
Help!
Turn on your garmin out of the car, connect to a PC via USB cable and see if the battery indicator goes away. If it does then the USB to PC cable is working and charging the unit. To test the car adapter, you can unscrew the tip of the plug to examine the fuse. Most Garmin car charger units have a light on them that ilimunates when you plug it in and turn the ignition. It could be that the plug is just loose in the socket. The picture shows the unit running on battery. If you plug in the usb cable and this indicator goes away, then it should be charging.
Jul 25, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin c550 GPS-Won't turn on at all.
could the battery be dead? Leave it to charge on the wall charger for several hours. Then try again. There is a way to do a hard reset....
Jun 08, 2008 | Garmin nuvi 350 GPS Receiver
Recharge
The car charger worked fine in my car, but if it doesn't work for you, you can always charge it using the USB cable with your computer.
Dec 25, 2007 | Garmin StreetPilot c550 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
120 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
