Question about Uniden TRU8885-2 Cordless Phone
Transfer phonebook to new base
My original base unit died. All the handsets are still good and have good copies of my phonebook. I got a new base on ebay. However, to register the handsets to the new base, I had to do a complete clear of the eprom (as learned here at FixYa). The problem, of course, is that clearing the eprom also clears the phonebook. Before I clear the other two handsets I have, I'd like to know if there is a way to store and retrieve the phonebook. For example, can the phonebook be "downloaded" to a computer or website, and then reloaded into the base unit or handset after re-registering the handsets to the new base unit?
Looks like a have the same problem and need to complete clear of the eprom. can you pls post instructions on how you did it?
Posted on Oct 23, 2008
Phonebook says unavailable
It is likely the phonebook is open on the other handset or base when you are accessing it from your normal handset. Take out the batteries from the other handset or turn off power to base and re-start. That should release any locked sessions or menus including the phonebook.
Aug 23, 2014 | Uniden Dect 15351 Digital Cordless Phone...
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
Can I connect a CL82409 handset to a CL82409 base system
Yes, and no.
When you buy the new corded base station (CL84109) with 1 handset, that base unit by default is "paired" with only the 1 cordless handset that came with it.
While you can plug both base stations into the landline wall plugs (RJ-11), and when the line rings, both base unit phones will ring and will each operate as independent corded phones would.
But, in this scenario, the cordless phones communicate only through the base unit they are Paired with. The cordless phone paired with the CL84109 corded base unit will not be able to transfer or Intercom between the cordless phones paired with the CL82409 base unit.
However, if you want to transfer the cordless phones that originally came with the CL82409 base unit to work directly with the CL84109 corded base unit, you can likely "Pair" them to work directly with the CL84109 corded base unit for a total of 5 cordless phones to be paired to the CL84109 base unit.
Consult the User Guide that came with the CL84109 base unit for instructions on how to Pair additional cordless phoned to this base unit.
The CL84109 can be expanded and paired with up to 12 cordless phones. So, this should be do-able.
Keeping in mind that the CL82409 will no longer have any phones paired to it and will thus be useless from that point on. (unless you pair more expansion cordless phones to it again)
Mar 13, 2011 | AT&T CL82409 Cordless Phone
How do i copy a phone book for the Uniden DECT1560 cordless phone
Kathy,
This should do the trick!
Copying Phonebook Entries to Another Handset:
You can transfer one phonebook entry at a time or all phonebook entries at once.
1) With the phone in standby, press the address book icon.
2) To copy one entry, find the phonebook entry you want to copy, press Menu /Select , and then select Copy.
To copy all entries, press Menu /Select and then select Copy All.
3) Move the cursor to select the handset which you want to transfer the entries to and then press Menu /Select .
If you select Copy All, Are you sure? appears on the display screen. Move the cursor to select Yes, and then
4) The phonebook entries will be transferred to the designated handset. During the copy process, the receiving handset shows Receiving and the ID of the sending handset.
5) When the transfer is completed, Done! appears on the handset.
Notes: • The handsets must be currently connected to the same base.
• If the handset you want to transfer to already has seventy entries in its phonebook, you will hear a beep and Not enough memory in receiving unit appears on the display.
• If the selected handset is out of range or data transfer is cancelled, Unavailable appears in the display, Phonebook listings will not be transferred.
Have Fun!!
Jul 07, 2010 | Uniden DECT15602 Cordless Phone
How to transfer phonebook from handset to sim.
go to phonebook
2. search for the name & number you want press
" OPTIONS".
3. select COPY or DUPLICATE & press " OK ".
4. select "COPY FROM PHONE TO SIM ".
5. press 'OK ".
Nov 10, 2009 | LG KU990 Viewty
Phonebook entries copy to second handset
use the memory or sim card. then use the feature "copy contacts from or to phone"
Aug 14, 2009 | Lands Phones
Iphone phonebook transfer
I got a solution:
Used hardware:
Pioneer DEH-P65BT
Jailbroken!! Iphone 3g FW: 3.1.2.
Mac or PC (addressbook on Mac or Outlook on Win)
Steps:
- Sync your contacts trough Itunes with your PC or Mac
- Go to addressbook on Mac (or Outlook on win) and export all your contacts to a vcf file (Called Vcards in addressbook)
- Copy the vcf file to your Iphone (iphoneExplorer / SSH / DiskAid or other solution)
- Download iBluetooth (I used it from the Xsellize source)
- Set up you radio to PhoneBook Transfer (Your phone is not connected to the radio at this point)
- In iBluetooth browse to the VCards.vcf and send it to the Pioneer unit.
- It now says transfer done and the phonebook is stored.
Posted this because it took me days to get it working. Haven't found a working solution on the net.
Also transfering the phonebook from another phone isn't a solution because however the phonebook will be stored it won't be usable by your iphone. The pioneer registers the phonebook to a device so it's absolutely necesarry to transfer it from the actual iphone (or send it from a laptop with a spoofed BT-Mac that matches your iphone)
- Cedrick
Jul 22, 2009 | Pioneer AVIC-D3 Car DVD Player
Adding a new handset
You need to register the new handset with the base.
In Global settings De-register the new handset then place it on the main base unit connected. It should then register.
Jun 30, 2008 | Uniden TRU8885 Cordless Phone
Uniden TRU8885-2 Cordless Phone Logo
293 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
