Question about DeLonghi DCM485 Coffee Maker
I have repaired two units (DCM 485) by jumping one of the two thermofuse which failed. I assume this fuse is redundant give there is a second such fuse in-line with the heating element and a thermostatic switch, as well. As a precaution I am telling my customers to shut off the coffeemaker as soon as brewing is finished. Your thoughts on this "fix"? MB Small Appliance Repair.
    Problem Solver:
  • 7 Answers
You should never jumper a thermofuse no matter how convenient it can seem. All your customers have to do is forget once and you are liable. If you are a repair person then find the correct fuse or replace the unit. Safety is above all in every case.
Posted on Feb 07, 2010
Replace fuses properly? i bought fast acting replacement fuse and sparked a light 2 seconds after powering up. why?/fast acting fuse? Or?
If you put the new fuse in the same way/place the old one was, then that is a non issue.
Assuming that you are replacing with the fuse they spec, fast acting/slow blow and the correct amperage/voltage..then losing a fuse that quickly indicates somethings failed inside, shorted to ground.
That would either be repair or replace the unit.
Sep 27, 2014 | Harman Kardon AVR 100
Where is thermofuse and thermistor located
The thermofuse and the thermistor is located in the fusing unit.Open the front cover,remove 1 screw and pull out the fusing unit(the left exit cover must open).Remove 2 screws and the unit front cover.Remove 2 screws and the upper cover,remove the harness from the harness guide,unplug the connectors of the two thermistors.Remove one screw,shoulder screw and the harness guide,remove one screw and the thermoswitch cord,remove 2 screws and the temperature detector assy.Using a soft cloth dampened with alcohol or oil,wipe clean the 2 thermistors.Verify a continuity of the thermoswitch and clean using a soft cloth dampened with alcohol,wipe clean the thermoswitch.99% the problem is a thermofuse.
Dec 17, 2012 | Minolta EP4000/5000 CS/PRO Copier
The transformer is dead and I can't find a new one. Denon DCM-30
You want to go to Mouser Electronics. http://www.mouser.com/ They have thousands of different transformers. They have never failed me yet. Since you know you need a transformer I will assume you know which one you need.
Regards, Tony
Apr 20, 2011 | Denon DCM-30 5-Disc CD Changer
Please describe code 542-00
SC542: Fusing Temperature Warming-up Error
Definition [A]
The fusing temperature does not reach the fusing standby temperature within
125 seconds after the main power switch is turned on.
Possible Causes
· Fusing thermistor defective or out of position
· Fusing lamp open
· Fusing thermofuse open
· BICU defective
· Power supply board defective
· Poor fusing unit connection
SC543: Fusing Overheat Error 1
possibly a paper jam or thermistors are dirty
Nov 18, 2010 | Ricoh Aficio 450 Copier
Copier ricoh aficio 450 error code SC 542-00 ?
  • SC542: Fusing temperature warming-up error
  • check the fusing unit -
    - Possible causes -·
    · Fusing lamp open
    · BICU defective
    troubleshooting
  • to reset the error enter the sp mode c 107 ca then use the sp np 5-801 then pres ok
Mar 18, 2009 | Minolta EP4000/5000 CS/PRO Copier
PCM Troubleshooting Check light on with no code reader power
You can't jump the connector to get codes on OBD II. (Pre 1996) Try hooking back up you code reader. If it doesn't communicate, check the fuse for the cig lighter. This fuse should also power up the diagnostic plug.
Mar 09, 2009 | 1998 Chevrolet Cavalier
Scan coming in all black with DocketPort 485
The first thing that you should try is to calibrate the scanner. If you don't have the calibration paper you can use a blank white 8 1/2 x 11 sheet. This should clear it up. If it fails calibration after repeated tries you most likely have broken the lens or the image sensor is no longer working. If that is the case then there isn't much you can do i would suggest contacting the manufacturer and hoping that unit is still in warranty.
Nov 19, 2008 | Ambir Technology DocketPort 485
GE MicroWave JES1136WL01 died while defrosting.
Mine has the same problems. After removing top cover, check fuse on power supply board (mine was OK). Then check thermo fuse located to the far left under the top cover( 2 black wires going to it) using a meter. I then jumped this fuse to see if this was the only problem. I hope to find a replacement thermofuse at the local hardware store.
Nov 17, 2008 | Microwave Ovens
SC542
thanks for the info. care to try again?
Sep 23, 2008 | Ricoh Office Equipment & Supplies
DeLonghi DCM485 Coffee Maker Logo
558 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
