Question about GE Profile DPSB620ECWW Electric Dryer
My dryer does not heat up properly, model DPSB620EC4WW, I have replaced the heating coil but this did not correct the problem. Is there a repair manual that tells my how to check the error codes for this dryer and how to check the thermistors and outlet T-Stat to see if they are working?
  • 1,543 Answers
There is usually a " mini manual " which contains the electrical diagram and a bit of other information located inside the back control panel area. Before you go any farther though, check your dryer's venting. With the dryer running, go outside and feel how much air is comming out the vent. The air flow needs to be strong for the dryer to work properly. The most common problem causing poor drying performance is bad venting. Make the vent as short and straight as possible, with rigid aluminum vent pipe and elbows. If you must use flexible vent materials, try to make it as short and straight as possible, preferablly using semi-rigid aluminum pipe (the kind that you can stretch out, bend, and it just holds it's shape) don't use the plastic stuff with the strand of wire in it if you can avoid it in any way. You may also have to clean the lint out of the vent pipe.
Posted on Feb 07, 2010
Troubleshooting heating element on samsung steam dryer
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Dec 10, 2016 | Samsung Dryers
Why does my Whirlpool electric dryer - model SEDS800JQ0, shut off after 2 minutes?
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem
Cycling Thermostat
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Aug 09, 2014 | Whirlpool Dryers
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
My Estate dryer is putting marks on my clothes that almost look like burns. With stain solution I can usually get them out but it's happening with every load now, what could be causing this? It h
Oct 02, 2012 | Estate Dryers
Frigidaire dryer not heating
You may have an igniter issue, thermostat, or a gas valve coil issue. Make sure a heat selection is made also.
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link should help get a proper diagnosis and parts.
Oct 18, 2017 | Dryers
Wont heat up
Generally either a bad thermostatic fuse or an open in the coil. I would suggest checking Here:http://www.repairclinic.com/ for issues related specifically to your make and model as well as repair/diagnosis advice and parts.
Jan 22, 2010 | Dryers
Our gas dryer takes a long time to begin heating then it stops heating midway through the cycle. The drum continues to turn. We have had a slight smell of gas.
It sounds like the safty coils on top of the gas valve are not working properly. As the dryer heats up the coils expand creating an open curcuit in the coil. There is a repair kit to replace the coils. This should be done by a licenced gas fitter.
Dec 29, 2009 | Dryers
Maytag performa dryer will not heat up
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
maytag performa dryer Model PDGT910AWW
"No Heat" complaint.
Firstly, make sure that you have selected/ascertained a "Heat" setting, then read the checklist below provided by; www.repairclinic.com
They also provide disassembly diagrams and repair parts..
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Jul 06, 2009 | Maytag Dryers
Dryer is not drying, no heat
your dryer has a coiled unit inside that heats up...this is what actually where the heat comes from is off this coil. Your coil (heat element) has a break in it some where this be the reason for your dryer not heating up. As for VERY temp solution..one could twist this heating element together making connection but again this is JUST to be temporary ..as only should be 1 day before actual heating element to be repaired correctly. If one is mechanically inclined this is not a hard procedure with the correct common tools...and heating elements can be bought offline as well as possibly if you have a Sears repair facility close by your loction. IF not, then suggest you to call a trained tech in this field if you are not mechianically inclined or unsure of yourself.
Jul 04, 2009 | Whirlpool GGQ8831L Gas Dryer
Why dosent my dryer get heat
There is a sensor for detecting airflow. If the dryer is unable to exhaust properly it will shut down the heat for safety reasons. Be sure the exhaust vent is not obstructed, and that there is good exhaust air flow. If there is insufficient exhaust, find and correct that condition.
Hope this helps.
Mar 28, 2009 | Whirlpool LGR5636L Gas Dryer
GE Profile DPSB620ECWW Electric Dryer Logo
354 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
