Question about Whirlpool SF369 Gas Kitchen Range
Whirlpool SF365pegq my whirlpool oven burner starts ok,but it will not relight after it is warmed up
  • 3craftygirl Oct 22, 2008
    I have Whirlpool gas oven model SF369 & had tech here 3 times for different iginiting problems.Gas just pours out & no flame. Whirlpool wants me to buy parts- the oven is still fairly new (2004) & I've had many problems since I bought it. The tech was last here in October 08.
  • 15,935 Answers
The way the ignition system in most of today's ovens work is like this:
1. Set the oven or broiler temperature.
2. The igniter begins to glow.
3. Once the igniter reaches a certain current potential, the gas safety valve opens.
4. Gas is introduced into the manifold and you have ignition.
5. NOTE: It can take roughly 30 - 90 seconds from the time you set your oven temp to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the oven to prevent free flowing gas from accumulating in your home without ignition. That's why you typically don't hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) - needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) - needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
An easy way to determine if you may have an igniter problem is to check BOTH your oven features. If the oven doesn't light, check the broiler and vice versa. Since both the BROIL manifold and BAKE manifold are fed from the same gas source, but have separate igniters, it's an easy assumption to make that the igniter may be bad, if one or the other doesn't light.
The igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn't produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won't light). Longer ignition times can be another symptom of an igniter possibly going bad.
For this solution, however, we're going to assume you have a bad igniter and need to replace it. Follows these steps:
NOTE: The same method applies to both the broiler and bake manifold.
1. UNPLUG the range and turn the gas off if you have a local gas cut-out valve (it is recommended that you do).
2. Open oven door and remove (if possible). Refer to your owner's manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot figure out how to remove the oven door, use care not to lean on the door or put too much weight on it. A common complaint following any kind of oven maintenance is that the oven door doesn't shut correctly any longer. This is usually caused by bending the hinges or springs coming loose.
3. Remove the oven racks, and remove the oven pan. (There are usually two screws either in the back or front of the oven holding the pan in place).
4. Remove the Flame Spreader. This is a metal plate on top of the manifold.
5. The igniter will be mounted directly to the gas manifold. Follow the wires that lead to igniter. It will either be plugged into a connector, or be connected together with ceramic wire lugs. Your replacement igniter should come with extra ceramic wire lugs. In the event the plug does not match the one on your range, cut the wires and connect using the ceramic wire lugs. DO NOT use standard wire lugs, they are not heat resistant and will melt.
6. Unplug the old igniter and remove the mounting screw holding it to the gas manifold.
7. Install new igniter on gas manifold using care not to handle the element on the igniter with your hands. The oil from your hands can cause damage and/or premature failure. The igniter is also considered FRAGILE.
8. Reconnect the wires using the recommendations mentioned in Step 5.
9. Plug in the range, turn the gas valve back on and do a visual test by setting the oven temperature to the desired range. Allow 30 - 90 seconds for the igniter to light the gas. Turn oven off and allow sufficient time to cool. If the oven has only been lit for a minute or so, the cool down period will be brief.
10. Reinstall the flame spreader, oven pan, and racks. Reinstall door if necessary.
Most igniters cost around $50. Prices will vary with models.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
How to relight the pilot light on the whirlpool super capacity 465 oven
Rebecca Yount, we're sorry to learn that your Oven will not ignite. We recommend service due to we aren't certified Technicians and wouldn't be able to advise you on how to relight the pilot light on your Oven.
Oct 17, 2017 | Whirlpool Ovens
The oven comes on an heats up to temperature , after a short while the oven no longer continues to heat. The contol panel shows on in bake mode , but the oven continues to cool.
Hello Brian;
You did not provide any information on the unit that you have. After you open the oven door there is a metal label on the face of the oven. Send that to me so I can see what you have.
1.) Some ovens have a single or dual broiler thermocouple.
2.) Some ovens have a separate control board for the oven.
3.) Some ovens have a Infinite switch.
Mar 21, 2015 | Kitchen Ranges
Oven wont bake
If this is the design that the oven will click to light they generally will preheat but shut down once they go to standard bake. The oven will try three times to relight but then shuts down and will not try to light again until you reset the oven. If this is the case the oven burner itself is usually the problem. the burner comes with the electrode.
Nov 27, 2013 | Whirlpool Ovens
I ran out of gas and now we have some but it want lite the stovetops or the oven
You will have to run the gas to bleed the lines. Turn on the stove-top and run until you smell the gas. Turn off the burner and let the air clear then relight the burner.
Feb 10, 2011 | Whirlpool RF365 Electric Kitchen Range
A possible short in our whirlpool oven
Someone definitely needs to get inside and check the wiring. Possibly a bad neutral would explain the clock backfeeding power from the burner switch. Eric
Sep 15, 2009 | Whirlpool Ovens
Whirlpool gas oven sf315pemb1- oven not heating
Hi, It sounds like the ignitor has gone bad. Remove the floor panel in the oven and locate the ignitor fastened to the burner. There should be 120V going to the ignitor harness.
If you have voltage but no ignition, change the ignitor.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 27, 2009 | Whirlpool GS445LELS Gas Kitchen Range
Gas oven wont stay on
If this is electronic ignition, then chances are the burner or ignitor nub has residue on them, preventing the flame detection system from keeping the gas on.
Use warm soapy water and a plastic scrub brush to thoroughly clean the burner cap, burner base, and ignitor nub.
Jan 25, 2009 | Whirlpool GS475LEKS Gas Kitchen Range
Whirlpool SF369 Gas Kitchen Range Logo
419 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
