After turning on the computer it boots to the desktop and then goes blank but still has the backlight on. In safe mode it will stay on the entire time.
1. download ComboFix, click Here 2. Close all programs of you computer 3. Double click ComboFix.exe on you desktop (on Save Mode) 4. When Combofix finished, it will create logs for you. 5. Restart your Notebook.
Looks like an issue with either display or system is overheating. Please try the below steps.
1. Shut down the computer 2. Keep on tapping F8 key as us press the Power button to turn on the computer. 3. Choose safe mode using the arrow keys on the keyboard and hit Enter Key 4. Stay on the safe mode to see if the screen is going blank, if not 5. A system restore should help to fix the issue. Let me know!
Hi, you are lucky you can access safe mode. now in safe mode, go to device manager by right clicking on my computer icon and selecting manage. then select device manager. select the VGA from the list by the right and right click then select uninstall. restart system , it will boot into normal mode
Try reloading the Operating system When you on it then Press F11 for factory setting reset and then follow instructions and you are through but remember is going to clean all you have in it first
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Check to see if this problem follows in safe mode. Reboot and when the Dell splash screen comes up tap F8 until you see the multiboot options. Scroll to "safe Mode with Networking" let the machine boot up and see if you have a screen. If you do, right click on the desktop and set the resolution to 800 X600 and reboot normally. Usually when a screen goes blank in normal mode but shows up in safe mode means you have an incompatible resolution for the monitor or graphics adapter. This may be a driver issue or hardware. If the screen boots up in normal mode at the lower resolution, then try and go to properties again and bump the resolution up a bit, if it blanks again, try to go online and update the driver for the graphics chip.
- Press F8 during the boot,
- go to Safe Mode,
- After Desktop is displayed,
- restart the system in Standard Mode
If the problem is still there, you need to reload the Windows with Recovery CDs.
First see if it will boot in the Safe Mode, pressing F8 when the computer starts up. Choose Safe Mode in the boot option. If it will boot in the safe mode. Restart the computer and press F8 again and select Start in the last known configuration. Hopefully
this will fix the problem. If not and you are running XP Pro, boot in the safe mode and do a restore. you get there by clicking Start, Programs, Accessories, System Tools, System Restore, choose a date that the computer was working and click Restore.
BPCS
