Question about Samsung SF-3200 Fax
Only copying 1/2 the page how do i fix - Samsung SF-3200 Fax
Hi my print is saying no cartridge what is the problem samsung model no sf-3200
Posted on Mar 25, 2010
Why not - I have created a 1-page document (colored green with print) to use as a book cover. I can save the document but cannot copy/paste it to the first page of a different document (my manuscrip
Not sure what program you are using, an easy fix, is to rename your document to "Temp" delete all the pages that you do not want, copy the first / the only page you need, than delete your temp when done, the original file is intact.
Tony
Aug 13, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Why are there Horizontal lines on copies spaced every 3 inches apar?
Download the following manual and check pages 1-293 through 1-308. The main problems with line on the page are do to (1) bad toner cartridge, (2) bad transfer belt and (3) bad fuser. If you want a more detailed explanation on how to get ride of lines let me know.
http://www.refurbisheddellprinters.com/content/manuals/service/Dell%203130cn%20Full%20Manual.pdf
Aug 13, 2014 | Dell 3130cn Color Laser Printer
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
How to do copies,ie what buttons do i press
Making a Single Copy
Place the original face down in the ADF.
2 Press Copy/Help twice.
To cancel, press Stop.
Do NOT pull on the paper while copying is in progress.
Copy Options: Single or Multiple Copies,
Reduce/Enlarge, Sort/Stack
You can choose additional copy options. First, you can select the number of copies. Next, you can
choose whether multiple copies will be STACKED (all copies of page 1, then all copies of page 2, etc.)
or SORTED (collated). Finally, you can choose an enlargement or reduction ratio. To automatically
reduce the copy to the paper size you have set for the paper tray, select AUTO. To reduce the copy by
a fixed percentage, choose 93%, 87%, 75% or 50%. Or, to enlarge the copy, select 150%, 125% or
120%. To copy a document at its original size, select 100%.
1 Place the original face down in the ADF.
2 Press Copy/Help.
3 Enter the number of copies you want (1-99).
For example: Press 9 for nine copies.
To start copying now, press Copy/Help.
If you would like to select additional copy options, like
SORT, ENLARGE or REDUCE, press Menu/Set.
Oct 02, 2009 | Brother FAX-T74 Plain Paper Thermal...
How do i copy two pages onto one double sided page?
there is n option on the disply panel.refers to original-with 4 option 1-1 .2-1 .1-2. 2-2 try and experament with 2-1 or 1-2 option 2-2 is for 2sided
Jun 05, 2009 | Konica Minolta DiALTA Di200 Copier
MFC-6490CW, photocopy of 11x17 document prints 8 1/2 x 11 full scale image on 11x17 sheet. The image is centered on the 8 1/2 dimension, and located at one end of the 17 dimension. The rest of the 11x17...
First make sure you are not using "fit to page" as this feature does not work for legal size documents. To fix this problem we need to check several things. First, Press Copy, Load your document, press 1 for number of copies, press the up/down arrow until you get to "paper size" then choose legal (for 11x17). Press OK
It is also possible that your machine is set to reduce/enlarge size to less/more than 100%. If the first solution did not work start over, press copy, load document, enter 1 for number of copies, press up/down arrow to choose "enlarge/reduce" then use right/left arrows to choose 100% (again, do not choose 'fit to page') press OK. Once you have done this, you can set these as default if you like. Press Copy, press up/down arrow to choose new setting, press OK, press 1 to choose YES, press stop/exit.
Apr 18, 2009 | Brother Office Equipment & Supplies
4 sets of copy counter numbers on canon imagerunner 2200
101:Total black copies and printed pages
103:Total A3 black copies and printed pages
201:Total A4 black copies
203:Total A3 black copies
Oct 31, 2008 | Canon imageRUNNER 2200
Lexmark X5100 printer. I copied a small item 3x3 and doubled its size. Now when I try to copy a full page only one small corner is reproduced. It appears I lost a default setting. How do I get a full page...
If you are using your All-In-One without it being attached to a computer and scanning a document that is getting cut off on the edges:
1 Move the document to a different place on the glass.
2 On the operator panel, press the Reduce/Enlarge button
repeatedly until Fit to Page appears.
3 Press Select.
If you are using your All-In-One attached to a computer:
2 From the software, select a copy setting with autocrop on (Color Photo or Black and White Photo) to make sure that autocrop finds the object and prints it completely.
1 From your desktop, double-click the Lexmark X5100 Series
All-In-One Center
icon. The All-In-One Main Page appears.
2 Click Preview Now to see your scanned image.
3 Select a quantity and color for your copies.
Note: To choose a paper size or further customize your copy
job, click See More Copy Settings.
4 Click Copy Now.
Note: When autocrop is on, the object (wherever it is placed
on the glass) will be printed in the upper left corner of the
page. This might make your copy look different from the
original.
try the above and post back so I know if your issue is fixed or you need more assistance
Jul 12, 2008 | Office Equipment & Supplies
Samsung SF-3200 Fax Logo
56 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
