Question about Sport & Outdoor - Others
I have Detroit 60 series installed on a launch. Recently the Starboard unit suffers a catastrophic failure and piston No2 came out of the block, making a big hole. This engines are using heat exchangers, and sea water cooled Charge Air Coolers and sea water self priming raw water pump. We contact the local dealer an the veredict was a "Massive salt water ingestion" that caused an Hydraulic lock and damaged cyls 6 and 2. They say that the water came from the deck covers, but there is no way for that to happen, I think they dont want to honor any warranty, because we suspect that the water came from the Charge Air Cooler. I want to know if the CAC can cause that type of failures and if anyone had a similar problem. The engine cost is about 66K and only had 2300 hours.
  • Emerson Bermudez Feb 07, 2010
    This is exactly what they are saying, they are blaming our maintenace crew and now I was comisioned by my manager to find an explanation other than the water coming from outside, passing the filter, the turbo and de CAC. I think, there will be another person in the world to have a similar problem, but I haven't find it in the Internet. Do you know something about?
  • 15,950 Answers
I would have to say that a sleeve got pitted or lost an oring or the CAC sprung a leak. I believe you are correct in your assumption that the water did not enter the unit in the manner they are saying. The only real way to tell is a complete tear down and someone is going to have to pay. They are also a high maintenance item and someone is going to say that the preventive maintenance was not done.
Posted on Feb 07, 2010
Code icu 140 columbia detroid engine
I googled: icu 140 columbia detroit engine
There are a number of answers. They should help.
May 07, 2015 | Freightliner Columbia Dash Panel: 2002...
2006 Freightliner 60 series Detroit throwing the following codes... 108, 117. Can anybody help tell me what they mean.
these are specific detroit / freight liner codes
take it to a service dealer as the downtime costs will be more than fixing the fault quickly
Apr 20, 2015 | Cars & Trucks
Series 60 detroit oil pressure to high
try and put a manual gauge in motor and confirm pressures or if you have a scanner , gauges or sending unit could be the problem
Sep 26, 2014 | Cars & Trucks
I have a ford 289 block I can't get it to fire on,
with the distributor at the rear of the block and looking at the front of the engine then pistons 1-3-5-7 are on your right hand with no 1 being the front piston. on your left will be 2-4-6-8 with no2 being the front piston. from the front and looking down on top of the distributor cap no 1 HT lead will be positioned at the 11 oclock position ( 12 oclock will be dead in line to the front of the engine). The rotor turns in an anti-clock wise direction Looking from the top . The firing order is 18436572 when installing the distributor ensure that the no1 piston is at TDC compression stroke
Sep 08, 2014 | Cars & Trucks
Where is the location of thermostat on 6v53 detroit diesel
series 60 have 2, are you referring to a 671 ,2 stroke or a Silverado v6 detroit
Aug 20, 2014 | Cars & Trucks
Having power surges on 60 series detroit
run fault codes . Check that the air vents on the tanks are not blocked causing a vacuum in the tanks and not letting fuel through to pump
Jan 28, 2014 | Cars & Trucks
Where is the oil pressure sensor located on a 60 series detroit
60 series detroit has oil sender on driver side near rear of engine just above the starter. It usually has 3 wires, and sometimes can be buried in the harness, so you may have to look under wiring harnesses in that area to find.
Dec 28, 2009 | 2008 Jaguar Xk Series
Locate the oil pressure sending unit on freightliner
on a 60 series detroit its behind the lower left rear of engine near steering column
Oct 18, 2009 | Lisle Oil Pressure Sending Unit Socket...
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
