Question about Whirlpool Calypso GVW9959K Top Load Washer
Crosley Front Load Washing Machine
I have a new 1 year old crosley front loader model number CAH4205AWJ that is displaying a FL code When I turned it off and on it started to act like it was going to wash but then it just displaed the code again if I have to drain the pump how do I do it. I need some ABC directions I have never fixed a washing machine before and to tell you the truth this little lady needs some help my clothes are piling up! Thanks for the help!
Can anyone tell me what the nf code means?
Posted on Sep 14, 2009
  • snoopy10092 Apr 20, 2011
    Mine is giving me the same nd code. I found a trouble shooting guide when I took off the top back panel. Nf means its not filling. I think my problem is the pressure switch is sensing that its got water in it.
    President:
  • Whirlpool Master
  • 2,651 Answers
FL is a flood condition fault, too much water in unit. i would turn off water supply and try to spin water out. select spin button, should put 8 min on timer try startin that water should pump out then if not you got somethin stuck in pump (lint likely)
Posted on Feb 22, 2008
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
Crosley front load error code LE
LE error code. The machine thinks the door is open. If it's not, then the switch or control board is faulty.
Jun 03, 2014 | Crosley CW6000 Front Load Washer
Why my crosley washing machine model CAWS823JQO made loud nosie then stopped spining
Likely possibilities:
  1. Coupling between motor and transmission has broken.
  2. Transmission has failed.
Number 1 is cheap and relatively simple to replace. Tip the machine up in front and place a support under the front edge of the cabinet. Look for broken pieces on the floor. See if you can freely rotate the motor shaft without affecting the transmission shaft. Check that the transmission shaft can be turned by hand. If yes to both, replace the coupling. If it breaks again after a short time, transmission is likely bad
Number 2 is expensive and difficult. If the coupling's not broken and the motor is operational, OR the coupling breaks again after only a short time, then replace the transmission, or the whole machine entirely.
May 25, 2014 | Crosley CAWC529JQ Top Load Washer
Crosley washing machine codes
Hello protocolu898 - Do you want to know how to display an error code on the washer? Or do you have an error code do you need assistance with?
Nov 26, 2012 | Crosley CW6000 Front Load Washer
IM looking for a manual for a model cah4205awj
Hello jojothunder3,
I understand that you need a manual for your Crosley washer dryer the only place that I could locate the manual is Sears Parts Direct and you have to call to see if it is available at this number (800) 252-1698 the part number is #2206690 and is called a use and care manual.
Thank you for choosing FixYa.com
justinbur167
May 11, 2011 | Crosley CWDH11W Front Load Washer / Dryer
Crosley CW6000 Washing Machine. When my washing machine is in the spin cycle, it shakes severely and the machine on the floor
My Crosley Cw6000 wash will not spin the water out, I lift the lid to watch the spin cycle, it spins but the water does not drain..
Sep 02, 2009 | Crosley CW6000 Front Load Washer
Crosley Front Load Washers FL Error
Flood Condition F L “FL” flashes if any overfill condition occurs. This condition occurs when excessive water in
the tub causes the overfill switch to trip. The control must realize that the trip was due to an
overfill condition instead of a suds lock condition in order for “FL” to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out.
The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch
resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
277 people viewed this question
Dan Webster
Dan Webster
Sal De
