Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
My washer is leaking oil and has a weird noise
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The problems you are facing are due to gear case, from where the washer is leaking oil. And due to that the washer tub has become unbalanced and you are getting weird noise. Run a mini-cycle to rebalance the load. However, in this case the load can't be balanced as the transmission oil is leaking and due to this it may have happen that drive coupler between the motor and transmission is broken and needs to be replaced.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 07, 2010
2007 Explorer XLT. Just had the oil changed and they showed me a loose washer in the oil pan. I haven't had any issues with knocking or other weird noises. What might this washer be?
Why was the oil pan removed for a oil change there is no need for that
the only washers on the bottom of the engine are the pickup union bolts and the crankshaft and connecting rod bearing caps
Nov 24, 2016 | Cars & Trucks
My truck is making a weird noise by the left front tire and it looks like something is leaking
Near the front wheel could be brake fluid or shock fluid or if it's a front wheel drive could be a CV joint leaking oil.
Get someone to help look for which it is.
Hope this helps.
Feb 25, 2015 | Cars & Trucks
Loud noise during the spin cycle
Did you have an oil leak at the bottom of the washer? If yes, chances are your transmission oil leaked and your transmission needs changing or repairing.
Jan 15, 2014 | Kenmore Washing Machines
Car made weird noises and then shut off while driving now wont even turn over
If the engine wont turn over after weird noises you may have seized the engine from over heating or lack of oil. Check for water in the radiator and oil in the sump. and if you are missing either then a replacement engine is the go
Feb 01, 2013 | 1999 Buick LeSabre
My 99 lexus gs400 is leaking a brown fluid. Not sure from where as It has had a transmission flush and radiator replaced. It also makes a weird rattling noise when started in the morning.
re rattle on start up,turn engine off then start again,repeat again if rattle continues.if oil change needed do it as my hydraulic lifters rattle in low temp or when oil old
Jan 31, 2013 | Cars & Trucks
Engine makes grinding noise when starting
people like Ariana new help their help who with their and tooo sorry happen just so now 5012731103
May 24, 2017 | 2000 Chrysler Town & Country
The check engine light stays on after oil change. When you apply the brakes the steering wheel vibrates and there is a weird humming type noise coming from the rear while idling.
Hope the oil filter was changed and with the OE type and the correct oil grade.
If so the oil pressure switch can be clogged and so produce the check engine light.
When applying brakes the steering vibrates as it can be due to faulty linkages in steering column, problem in the hydralics pump or fault in the steering rod bearings.
finally the weird noise from rear can be from a faulty exhaust , leak or poor joint in the exhaust or vibration of the exhaust with loose mountings.
Sep 21, 2011 | 2000 Dodge Grand Caravan
I own a 08 impala 3.9. I have weird sound coming from inside of the engine. There is no oil leak..coolant leak.. Oil is not mixing up with any other fluid. Car does not overheat or rough ride.. What could...
if level of oil correct then it could be anything and without hearing the noise i couldnt just tell you what it is and i dont think anyone except the O mighty one could ,so please ask a local mechanic to take vehicle for a ride then post what he says for confirmation
May 07, 2011 | 2008 Chevrolet Impala
Engine is making a weird noise and it smells like burning oil.
I can help if you can describe the noise. Is it rattling, knocking, clicking? I would check the oil level and make sure you have the proper level. Also look for leaks.
Dec 31, 2010 | 1990 Jeep Cherokee Limited
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
74 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
