Question about Canon imageRUNNER 400S Copier
Canon imagerunner 400e
I bought a used imagerunner 400e and am having a problem getting it to print via network. It is recognized but the firmware is old. Any ideas on how to upgrade the firmware or where I can find the original installation disk
  • Anonymous Mar 31, 2014
    firmware
  • Canon Expert
  • 1,326 Answers
If the copier needs to be up-dated. It can only be done by a tech that has a laptop. The copier needs to be "Flashed" or you need to run the setup again.
Posted on Feb 22, 2008
Purchased new Canon ImageRunner C2550... using as network printer and scanner. 3 computers on network, Canon 2550 recognized two computers no problem... cannot get it to recognize the third one. Third...
The network setting for the scanner driver may be incorrect. Check the IP address of your scanner and then set the IP address on the scanner driver.
1- The steps of setting the IP address may differ depending on your operating system.
For XP operating system:
Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras.
For windows 7 operating system:
Start > Control Panel > ... View scanners and cameras.
2- Right click on the scanner icon for your machine and select Properties.
3- Click Network Setting tab and select Specify your machine by address.
4- Enter the IP Address you confirmed from the snanner menu or ask your network administrator and click OK.
Hope this helps.
Jun 17, 2010 | Canon imageRUNNER C2550 Color Copier
Network Printing is not working
what drivers are you using? try both PCL and UFRII. also, check thru WWW interface(will be faster) if there's a department managment turned on. i it is, disable it. i assume you are creating local tcp/ip port with printer ip, raw mode, port 9100 and device is canon network printer. also did you noticed is windows discovers the device as canon network printer, raw mode etc, or you have to enter it manually? if it can't discover it, there's some connection problem.
Jul 23, 2009 | Canon imageRUNNER 5000 Copier
No network printing
you need to add orinter to printers and faxes folder via IP address if you can contact me via phone i can walk you through it
May 11, 2009 | Canon imageRUNNER 3035 Black and White...
What drivers are needed to work a canon imagerunner 2200?
Could you print before reinstalling Windows? I assume you could in my answer below.
Try pinging the copier from your computer. Go to Start > Run > CMD > ping 192.168.0.5 - t
Replace 192.168.0.5 with the IP address of your copier.
Open the RUI as suggested above e.g. http://192.168.0.5
Can you use Canon Network ScanGear Tool? (Google it, it's freely available from Canon website and comes with user manual).
Make sure that your copier has the same IP range (first three numbers out of four for IP address are the same) as your computer and that the subnet mask's are the same e.g. 255.255.255.0.
Go into Additional Functions > System Settings > Network Settings > TCP/IP Settings > IP address to check these on the copier. Make sure DHCP is off (DHCP box should be filled with white, not filled in with black)
Where the network cable is plugged in can you see two lights coming out through holes? Move your head, they may not be immediately visible. If not then the network card isn't working.
Have you tried hooking up a laptop to the copier via crossover, changing IP address settings on both copier and laptop and seeing whether printing works that way.
Try turning off firewalls etc and see if printing works. If turning off firewall fixes it, turn it back on and add the copier's ip address as trusted.
Have you tried changing ethernet cable, seeing whether you can print from another computer on the network etc. If it works from another computer on the network you could share the printer or check how it's setup on that computer and copy the settings.
Set up the printer as a local printer. Set up a TCP/IP port with the IP address of the copier and use the PCL5e/PS drivers. If using PCL5e select print as image in the settings and if options installed are not immediately recognised press get device status, change settings as required. Set output paper size as A4, Legal or whatever you want not "Match Paper Size"
When you print check the copier to see if an error comes up or anything. If it comes up with an error to load paper select the paper tray you want and it should print.
If you couldn't print before reinstalling Windows do the following:
Press the counter check button. Near the bottom of what comes up you should see 2200(2200N). If you don't see the N then it's not networked properly.
Go into Service Mode (Additional Functions > 2,8 > Additional Functions). Go to Copier > Display > Version. Look at BOOT-ROM, it should have a N at the end of the number. There should be a number for PS/PCL. If there is no number for PS/PCL get a tech to come and reload firmware so you can print.
Apr 22, 2009 | Canon imageRUNNER 2200
Can't print or scan through USB port on Canon imageRUNNER 5070.
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
Apr 20, 2009 | Canon imageRUNNER 5000 Copier
ImageRunner 5570 falls off network
i would contact the place where you bought them from. The firmware may need updated.
Jan 21, 2009 | Canon imageRUNNER 5570 Copier
Printer does not print automatically. It prints manually
It may need a firmware update, new software, Also check that your drawer sizes are set right. If so you need a canon tech to visit.
Jan 10, 2009 | Canon USA - COPIERS - ImageRUNNER 2010F...
Canon ImageRunner 2200 printing
the parrellel port is used also to updated machine soft ware.... if you do not have the print bootrom installed it will not print sorry
Dec 22, 2008 | Canon imageRUNNER 2200
Solution
do you mean print via network or print via copier on glass or doc feed tray? network means you dont have your cassettes recognized in your software, or its useing the bi-pass as a default drawer.. copier reproduction means fault in you drawers, reprogram them.
Dec 07, 2007 | Canon imageRUNNER 4570 Copier
Canon imageRUNNER 400S Copier Logo
100 people viewed this question
old marine
old marine
