Question about LG WM1814CW Front Load Washer
Soap Dispenser drawer will not open.
The soap dispenser drawer seems like it is getting stuck on something when I try and pull it out. Similar to a drawer when you have something in there blocking it from coming out.
    Problem Solver:
  • 5 Answers
Upon taking the top of washer off, it exposes the liquid dispenser. There are three snap clips on the right side as you look at it from the front. Unsnap and lift slightly on the dispenser lid. This should provide the clearance you need to open the drawer. Examine the blue covers for the fabric softener and bleach. You will see scrape marks where it has been rubbing on the the top cover when closing and opening. Using a soldering iron or an abrasive, wear down the sharp edges that are catching...This solved the problem for me.. ( :
Al Holm Chisago City, MN
Posted on Jun 30, 2013
    Genius:
  • 1,554 Answers
If you cant resolve it you will have to remove the top access panel, 3 screw in rear , then remove the front panel , 3 screws in front lip.
then you can see under /around the drawer.
it would be easier to get a torx set of drivers to undo the screws.
Posted on Feb 25, 2008
How do i get the soap dispenser unclogged?
Open the soap dispenser drawer and press the green drawer retainer (in the middle compartment) down while pulling the drawer outwards, this will release the catch on the drawer.
Sep 03, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Tip
Dishwasher does not dispense cleaning tablet
The soap dispenser drawer is supposed to open during the cycle. Try first to understand if the drawer is opening or not during cycle.
If the drawer is not opening, then check if the opening mechanism is stuck, if it is blocked by dirt and soap, if it is broken, or if something, for examble a basket too close to dispenser drawer is preventing the drawer from opening.
Some dishwasher works only with powder, in that case indications are given on the owners manual.
If the drawer opens and the table, or powder is still staying stuck in the drawer, then that means that the spray does not have enough power to solve the tablet.
In that case check spray arms and impeller pump.Also check water temperature.
If the problem is also happening with powder, then it is probably a drawer not opening on cycle.
on May 26, 2009 | Stoves 27 in. DW60 Built-in Dishwasher
WM2277HS front loader , the drawer to put the detergent in is stuck, how do I get it open?
I have slightly different model. Tried the remove the top option. It turned out the the drawer assembly had removable top, removed to two screws that held the assembly in place, uncliped e front assymply drawer handle and cleaned out the soap deposits. Soap build up under dispenser parts had caused the problem. It seems like running the machine a few times might have cleared the soap.
Mar 14, 2011 | LG WM2277HSW XL Front Load Stackable...
We have a Kenmore frontloader pooring water from soap dispenser
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 16, 2009 | Kenmore 44102 Front Load Washer
Indesit WIE147 leaking from soap dispenser
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Jun 17, 2009 | Washing Machines
Soap Dispenser won't empty
Feb 25, 2009 | Kenmore Elite 45986 Front Load Washer
Simpson brand dishwasher won't disperse detergent tablet
Feb 18, 2009 | Dishwashers
Soap will not dispense
Feb 07, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Sears Kenmore HE2 front load washer
there is a spring around door opening that holds bellows on remove it and pull back from inlet opening also possible if you use dry detergent a lump has become lodged in fill line working something from both ends may dislodge it
Nov 26, 2008 | Washing Machines
Cant open soap drawer on washer
I opened up the top of the washer by unscrewing the screw in the back. then I pressed down hard on the white plastic cover of the soap dispenser that you will see on the front left hand side of the machine. I also moved it slightly to the right by pushing on the side of the same unit.
The soap dispenser then opened up fine. I cleaned out the soap dispenser from any crud that developed in it. Now it opens and closes nicely.
Did you know there is a class action lawsuit against LG for mold that develops inside of this model washer? I joined in the lawsuit. There should be no mold accumulating in any washer.
Sep 07, 2008 | LG WM-1485FHD Front Load Washer
LG WM1814CW Front Load Washer Logo
577 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
