Question about Dryers
DLG2532W - LG Gas Dryer - Not spinning/working
My dryer is turning on giving me the option of selecting my drying setting, but then when I hit the START button, nothing happens.
I've unplugged it, turned the circuit breaker off and on, cleaned the lint filter well.... and now I have 2 wet loads of wash I can't dry.... :-(
Any Suggestions?
  • 92 Answers
COULD BE A DOOR SWITCH A THERMAL FUSE A CONTROL BOARD OR A MOTOR
YOU'LL PROBOBLY NEED TO CALL FOR SERVICE
Posted on Feb 22, 2008
My dryer's cotton/time dry/wrinkle free option know turns freely. Dryer will not start.
Take the other knob from the other switch nd put it in that place. It should turn then . You will be able to turn it on by a pair of pliers until you get a replacement knk.
Feb 22, 2013 | Dryers
My DLG2532W just stopped getting hot, is this an easy fix or do i need an expert to fix it?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 03, 2011 | LG Dryers
I HAVE A LG DLG2532W GAS DRYER. IT WILL NOT DRY. I HAVE TAKEN IT APART AND CAN SEE THE HEATING ELAMENT HEATING UP. CAN U HELP
Safety First, Unplug Dryer. There are two thermostats in the dryer. They are on the exhaust tube that houses the burner element and the ignitor. One is on the top half of the exhaust tube near the dryer wall and the other is on the bottom half of the exhaust tube toward the center of the dryer. The one on the bottom half of the exhaust tube in the one with the reset button.pull off right access port cover, look in and left for thermostat hanging down off of exhaust tube. Press button between the two wires going to thermostat. It is a 3 minute operation if you can get to the right side access port. hope this helped Tim
May 22, 2011 | LG DLG2532 Gas Dryer
I have model # DLG2532W. It will not heat up. I have replaced the igniter and the M220 part. I was going to replace all the thermostats but can not seem to find the F130 and F140. Where is it. The...
The M220 (part #6931EL3003C) is a manual resettable thermo. (Gas models only) (reset by pushing in pin between electrical contacts) If it is tripped out, your vent is in-adequate. There are two themostats located on the back side of the blower housing (ref #'s K550 and K560, part #'s 6323EL2001B and 6931EL3002A respectively) but first, have you tried cleaning off the moisture sensor bars inside the drum, near the lint filter? Try to use timed dry. If that works, your problem is the moisture sensor bars need cleaning, due to build of of fabric softener on them, which makes the dryer think that the clothes are dry, so it will not heat.
Sep 25, 2010 | LG DLG2532 Gas Dryer
LG gas dryer DLG0452W drum makes a clicking noise
one of the dry drum baffle screw might be lose are there might be something caught inbetween the dry drum front seal are rear
Apr 24, 2010 | LG DLG0452W Gas Dryer
DLG2532W Loss of heat
I had same issue and cleaned out all lint from the entire cavity of the dryer. Fixed the problem.
Jul 08, 2009 | LG DLE0332 Gas Dryer
Only spin dry available?????
Yes, turn on the machine, push the button for spin to select the speed and then press start.
Apr 26, 2008 | LG WD-12126RD Front Load Washer / Dryer
LG DLE2532W Electric Dryer doesn't allow adjustment of drying options
it may be possible the contol is bad can you change the settings at all
Feb 07, 2008 | LG DLE2532W Electric Dryer
HOW TO INSTALL THE BELT ONTO A LG DRYER MODEL DLG2532w
Connect Gas Supply Pipe
(Gas Dryer ONLY)
For further assistance, refer to section on Gas
Requirements.
1. Make certain your dryer is equipped for use with the
type of gas in your laundry room. Dryer is equipped at
the factory for Natural Gas with a 3/8” N.P.T. gas
connection.
2. Remove the shipping cap from the gas connection at
the rear of the dryer. Make sure you do not damage the
pipe thread when removing the cap.
3. Connect to gas supply pipe using a new flexible
stainless steel connector.
4. Tighten all connections securely. Turn on gas and
check all pipe connections (internal & external) for
gas leaks with a non-corrosive leak detection fluid.
5. For L.P. (Liquefied Petroleum) gas connection, refer
to section on Gas Requirements.
Oct 15, 2007 | Kenmore 63932 Electric Dryer
Dryers Logo
215 people viewed this question
Top Dryers Experts
Marvin
Marvin
