Question about Cyber Acoustics A-3780 Computer Speakers
Illuminated remote pod control wires pulled out where can i get a new one in canada
Can you give to me information were tou get remote
Posted on May 29, 2010
Turn signal relay 2008 jeep location
There is no relay , controlled by integrated power module . Electronics !
Feb 12, 2016 | 2008 Jeep Grand Cherokee Laredo
Tip
How to make Program for making an Universal Remote Control
<p><span>For making a universal remote control it takes few steps by using the Automatic Code Search method.</span><br /> <p><span><span> </span></span><br /> <p><span>First: Turn on the component that you want to make the program for universal remote control.</span><br /> <p><span> </span><br /> <p><span>Second: Now press the component button on your remote that corresponds to the component you want to the remote to operate such as TV, VCR, etc. The illuminated on-off button will turn on and keep on.</span><br /> <p><span> </span><br /> <p><span>Third: Press both component and on-off buttons. The illuminated on-off button will turn off, and then will come back on.</span><br /> <p><span> </span><br /> <p><span>Forth: Now release both buttons after the pressing on-off button turns back on. The button must remain illuminated.</span><br /> <p><span> </span><br /> <p><span>Fifth: Then press and release the "play" button. If the component does not work wait few seconds, than continue to press the "play" button every five seconds until the component turns off.</span><br /> <p><span> </span><br /> <p><span>Sixth: Finally press and release the "reverse" button when the component turns off, and then wait to see if the component turns on again.</span><br /> <p><span> </span><br /> <p><span>Seven: Press and release the "STOP" button to save the new code of your remote control.</span><br /> <p><span> </span><br /> <p><span>Now it is your new remote control that will work on your all component as universal remote control.</span><br />
on Dec 24, 2010 | Televison & Video
Sony bravia kdl 32l 5000 does no respond to remote controls
Check the remote control for its infrared emission. Check it with fresh batteries. If remote control is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 16, 2014 | Sony Bravia KDL-26S3000 Television
Sometimes on start up about 8 lights stay illuminated on dash & stop engine flashes along with alarm , if you hit the top of dash pod faults will go away , have had numerous VW experts look at it but only...
Sounds like bad wiring or soldering job on the printed circuit board. Chevy and Dodge were notorious for their clusters and lights going out also. Hitting the top of your dash will only make whatever is failing, fail quicker and could even cause it to short out and completely burn up the wires and instrument panel. You could try buying another panel from a junkyard and putting it in your car. It would tell you if the problem is in the wiring or in the cluster itself.
Oct 29, 2013 | 2004 Volkswagen Golf
Harmony remote stays illuminated after turning - kills batteries
The new firmware that you can download and install automatically when you're hooked up to your computer to do programming has an option that changes the time on for the "glow."
Perhaps updating your firmware and then managing the remote will produce a change that will then have the glow turning off.
Feb 22, 2009 | Logitech Harmony 676 LCD Remote Control
1989 Mercury Tracer Sta. Wgn.
your owner manaul has it. your fuse cover should have chart too.
here is 96 tracer. You also have main fuses under hood.
INTERIOR FUSE JUNCTION PANEL REFERENCE CHART Fuse Fuse Rating Color Protected Components (REAR WIPER) 10A Red Rear wiper and washer motors, heater and A/C relays, daytime running lamps control (Canada), climate control assembly panel illumination HAZARD 15A Blue Front and rear turn signal lamps, turn signal indicator lamp, indicator flasher ROOM 10A (1.9L)
15A (1.8L) Red
Blue Dome and map lamps, safety belt warning chime, ignition key illumination, luggage compartment lamp, vanity mirror lamp, radio chassis (memory), power door lock relay, shift interlock system, powertrain control module (PCM), radio amplifier (memory) ENGINE 15A Blue Fan control (FC) relays, PCM relay RADIO 15A Blue Radio chassis, radio amplifier, remote control mirror, instrument panel illumination (DOOR LOCK) 30A Light Green Power door lock actuators BELT 30A Light Green Passive restraint control module, passive restraint motors (POWER WINDOW) 30A Light Green Window regulator electric drives METER 15A Blue Instrument cluster, backup lamps, rear lamps, speed control system, shift interlock system, safety belt warning chime, passive restraint control module, hazard flasher, PCM (1.8L Canada) WIPER 20A Yellow Windshield wiper motor and windshield washer pump STOP 20A Yellow Stoplamp, horn (1.9L only), rear hi-mount lamp TAIL 15A Blue Parking lamps, cornering lamps, rear lamps, license lamps, compartment lamp, instrument panel illumination (SUN ROOF) 15A Blue Sliding roof panel motor ABS 10A Red Anti-lock brake system (ABS) (1.8L only) (DEFOG) 20A Yellow Rear window defroster HEATER 30A
circuit breaker — A/C blower motor HO2S
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 10A (1.9L)
20A (1.8L) Red
Yellow Heated oxygen sensor (HO2S) CIGAR
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 20A Yellow Cigar lighter knob and element CIGAR 20A Yellow Cigar lighter OBD II 10A Red Data link connector #2 BLOWER 30A Light Green Blower motor relay HORN 20A Yellow Horn (1.8L only)
Aug 10, 2008 | 1989 Mercury Tracer
Programming my remote ?
These are the instructions to re-code the remote:
1.Manually turn on the component you want the remote to control.
2.Press and hold the component key (TV, VCR, Etc..) you wish to program. The illuminated ON-OFF key turns and remains on.
3.While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off.
4.After holding down both keys for three seconds, the illuminated ON-OFF key turns back on.
5.Release both keys. The illuminated ON-OFF key remains on.
6.Press and release the ON-OFF key repeatedly until your component turns off. Wait four seconds between each keypress. Each time you press the ON-OFF key, the illuminated ON-OFF key blinks and the next code in the list is sent. This process continues until all of the codes in the Code lists have been searched. If your component turns off, you have found the correct code.
7.Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON-OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored.
Apr 19, 2008 | Jensen JER-321 Remote Control
I Lost the Code List for This Remote Control
coding:
Apr 10, 2008 | Jensen JER-321 Remote Control
My player doent accept dvd disc from canada
Your player doesnt play a dvd disc in canada this could be because of region limitations and your remote control has nothing to do with this problem try replacing with new pair of batteries and try again.
Thankyou
Feb 10, 2008 | Panasonic DVD-S27 DVD Player
One controller pod...being split for two speaker sets?
Technically it's not a KVM connector.
A KVM switch uses a DB15 serial connector.  Just like a monitor uses a DB15 for it's VGA connection.
The pinout for the control center's DB15 connectori is not likely to be the same as either one of those two types of devices.
Unfortunately, there is no way to make one pod work with two sets of speakers. The reason for this is that the voltage supplied to the control center comes from the sub-woofer.  You can imagine having two sources of power connected to one, single control center...
The control center would not know which sub-woofer and power system to regulate.  You would end up with issues revolving around power distribution, volume levels being variable - or worse.  More than likely, you would either overload the control center or it would simply not be able to keep up with the demand for both systems simultaneously.
I myself just had my set of Z-5500's RMA'd to Logitech under the exact same circumstances.  I just received my new set today.  Retail box and everything.
He was NOT kidding you.  I had to make him repeat himself just like you did.  LOL.
But I sent the control center, remote and purchase receipt with them.
5 days later, I found out DHL almost had my package here.  (Although I was lucky.  The turn-around time on the RMA is subject to supply and demand.  I was quoted 6-8 weeks at one point due to their lot being completely empty.  They are manufactured and shipped from China according to the rep I spoke with...)
My advice to you is to get right on the RMA process.  Get your incident number from the Logitech rep who sets up your RMA.  Get those two pieces sent in as soon as you can.  Do what I did.
To do this, call the following number.
General Technical Assistance/RMA: 646-454-3200
Package the remote, control center into a box snuggly.  WRITE YOUR INCIDENT NUMBER given to you by the Logitech rep on the receipt.  Include the receipt in the box.  Take it to the post office and send it by USPS Priority mail.  Get "Delivery Confirmation" on it.  All told it came to just under $10 for me.
Send it to the following address:
Logitech Incorporated
6505 Kaiser Drive
Fremont, CA 94555
ATTN: Incident Number# <put your incident number here>
You will also be instructed to send a copy of your receipt by way of fax.  WRITE YOUR INCIDENT NUMBER AND PERSONAL INFORMATION ON IT BEFORE FAXING.  (Or at least on a cover letter.)  They're supposed to send you an email to let you know that they received the fax...but I never received one.  Good thing I included a second copy with the control center and remote...because that's the one they used for processing.
FAX: 702-269-3439
I have pics of the shipping order that came on the box, too.  If you would like to see this proof, let me know.  I'll be more than happy to post plenty of pics that show my old set (sans the control center of course...) and the new set.
But don't delay like I did.  Mine was two days away from expiration of the warranty before I sent in the parts.  LOL.
Any more questions?  Let me know.  :)
Cyryl
Jul 20, 2007 | Logitech Z-5500 Computer Speakers
Cyber Acoustics A-3780 Computer Speakers Logo
358 people viewed this question
Top Cyber Acoustics Audio Players & Recorders Experts
mukhtar21 shaikh
mukhtar21 shaikh
Carlos L. Burgos
Carlos L. Burgos
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
