Question about Gaggia Syncrony Compact Digital Espresso Machine
Syncrony Compact Digital unit- Used well for 5 yrs without incident. Currently, after bean grinding and tamping stages, a strange, non metallic rumbling/grinding sound occurs just before the pre-brewing and brewing stage. Then following the brew, the same rumbling sound occurs as the puck is ejected into the dreg drawer. After two brews the "drew drawer full" message appears. Also a message "brew unit blocked" appeared this morning, but didn't reappear after I emptied the dreg drawer and removed, then replaced the brew unit. Any Thoughts? Brad
  • 21 Answers
You described the timing of the noise clearly. During this phase, the brew group is moving into place. It is probably having a lot of friction. If there is too much friction, it explains the "brew unit blocked" message. The brew unit needs a cleaning. Start with a thorough rinse. If that is not enough, clean the gunk out of the little rails inside. Then apply Vaseline otherwise it will jam up again.
Posted on Aug 14, 2010
    President:
  • 1,618 Answers
First clean the screen and tube on the brew unit, then lube the guides/gear grooves on the brew unit, also lube the o-ring(big red one). Then that should take care of it. You can also try backwashing/degreasing the brew unit if the machine has a preground chute.
Posted on Feb 07, 2010
4 Suggested Answers
  • 1089 Answers
SOURCE: gaggia syncrony compact is leaking. Removed top
Hi What color is the steam manifold? It is located under the black cover with the trough in back under the whit tube. If its whit or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand.
Posted on Jun 14, 2009
  • 1089 Answers
SOURCE: coffee beans empty
Hi
Coffee beans empty is caused by the grinder running for about 15 seconds without filling the doser chamber. Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute.
Once that is cleared go to the bean hopper. There is a lever on the right side of the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
Posted on Oct 31, 2009
  • 1089 Answers
SOURCE: We have a Gaggia Syncrony Logic that is just over
Hi
Check the drain behind the brew unit. There is a pocket below the injector that can plug up and cause water to drain under the drip tray. Check this first. Stick you finger in the pocket and see if there is water in it. If there is, the drain below and to the right is plugged and just needs to be cleaned.
Posted on Dec 11, 2010
Testimonial: "Indeed, it appears the pocket below the injector was plugged. Was able to clear it and it now drains properly. thank you!"
Its telling me that coffee beans are empty...but they are not..it makes grinding noise but the message keeps popping up beans are empty
You have one of 2 problems either the grinds chute to the brew unit is blocked, or the grind is too fine.
Sep 18, 2010 | Gaggia Syncrony Compact Coffee...
I have a Gaggia syncrony compact coffee machine and the coffee grinder has jammed for the second time. The repair agent employed by Gaggia inform me that they have been waiting for spare parts from Gaggia...
If the grinder jammed it might have been because the grind was too fine, try adjusting coarser then using the + or - lever to add more coffee for proper extraction. To clear jam remove brew unit and locate door to grinder chamber on left, vac out grounds, also beans in hopper. When clean run grinder and set to coarser, then add small amount of beans and test.
Aug 25, 2010 | Gaggia Syncrony Compact Coffee...
I have a Gaggia Digital Syncrony. The machine
Hi
You could have a micro switch in the doser that is going bad and needs to be replaced. They are a special micro switch that is very sensitive and can get stuck with a little coffee dust inside the switch.
Mar 10, 2010 | Gaggia Syncrony Compact Digital Espresso...
Coffee is not strong enough?
Hi
There are 2 knobs in the bean hopper. Turn the small one to the + then back up 1 click. Turn the large knob to a smaller number, but only when it is grinding. The grind should look like coarse granulated sugar. It takes 3 cycles for the grind to take effect.
Jan 12, 2010 | Gaggia Syncrony Compact Digital Espresso...
Beans grind, then the machine sounds like it's 'struggling' mechanically, then it just gives up and clears the ground beans out before pumpng any water. I think the problem is mechanical, but am not...
really hard to repair these yourself. User access limited. Brew unit may have spent coffee stuck in it or it may be blocked. Best return to service centre
Sep 19, 2009 | Gaggia Syncrony Compact Coffee...
GAGGIA syncrony compact coffee grinder motor is
Remove the brew unit and to the left of that is the the discharge area for the grinder, make sure that hole is clear, then adjust grind 1 number coarser, and check machine.
Jun 07, 2009 | Gaggia Syncrony Compact Coffee...
Problem with tamping
Try adjusting the grind to a finer setting also the amount of coffee can be adjusted with the lever in the grinder chamber.
May 06, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony does not get past the grind cycle
Water has probably been spilt in the beans area. The grinder needs cleaning out along with the chute
Feb 24, 2008 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony Compact Digital Espresso Machine Logo
357 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
