Question about Goodmans GTVL32W27HDF 32 in. LCD TV
Picture very dark and flickering - Goodmans GTVL32W27HDF 32 in. LCD TV
Vizio LCD dark screen and picture is flickering flashing
Your back light inverter is provably bad.
You can get get parts for this tv at www.interliquidparts.com
Nov 25, 2011 | Vizio 42 in. LCD TV
Picture "flickers" from dark to a lighter
This is a board level fix.
The part is about $10. + time to solder on the part
Capacitor C809 is failing.
390mfd @250V
Mar 05, 2011 | Proscan 42LA30H 42 in. LCD Television
No picture screen remains black some flickering
hi
what you are experiencing is that your screen bulb is burnt.the screen bulb is what lights up your screen, its just like a fluorescent tube,when it is burnt it flickers for a while and it later goes off.. the only solution is to change the screen bulb as soon as you can
goodluck with that!
Feb 17, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
Friend's Laptop Screen has become too dark to work with
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 24, 2009 | Toshiba Satellite U205-S5002 Notebook
Toshiba Plasma 42
plasma42 color flickers in and out and now its just snow,now its black screen. still have sound.please help me.. what board should i replace??
Dec 29, 2008 | Toshiba Televison & Video
My tv picture is dark and flickers
is there any spar, u observed inside the tv when it do like this.
Jul 05, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Picture Flicker
Well Matt it sounds like your Flyback. there are 2 problem that occur with the flickering of this set. For more info visit ctechnicians.com
Dec 28, 2007 | Hitachi 57F500 57" Rear Projection...
Goodmans GTVL32W27HDF 32 in. LCD TV Logo
50 people viewed this question
Top Goodmans Televison & Video Experts
Raj Patel
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
