Question about Star Micronics TSP700 Thermal Printer
Printer stopped working - Star Micronics TSP700 Thermal Printer
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
Remove all windows updates
Updates from Microsoft generally do not cause printers to stop working.
What kind of printer is it?
Usually if you clear the printer from the device list (delete it) and reinstall the printer again, this is a quick way of getting things going. What changes have been made since the printer stopped working on your PC or with the printer?
Jan 03, 2016 | Microsoft Windows 7 Ultimate for PC
Canon Pixma MP160 stopped working, showing E 2 - paper is not jammed - Printer is NOT hooked up to a computer - only used for scan and print in farm shop (heated) - suggestions? It is an oldie but a...
First thing to try is pressing the "Stop/Reset" button. If that doesn't work, hold it down for more than 10 seconds and release. If that doesn't work try turning off the printer, unplug the power cord for more than 10 seconds then reconnect and turn the printer on again.
If the printer was connected to a computer, there might be more information provided about the source of the problem. Otherwise, a last resort would be to reset the printer. Follow this exactly:
  1. Turn off the printer (using "Power" button) but leave it plugged into the wall socket.
  2. Press and hold the "Stop/Reset" button (red circle in the triangle), and without releasing the "Stop/Reset" button, press and hold the "Power" button (indicator light shows green).
  3. While holding down the "Power" button, release the "Stop/Reset" button.
  4. Continue holding down the "Power" button, double click the "Reset" button and release the "Power" button.
  5. Click the "Stop/Reset" button four times
  6. Press the "Power" button to confirm and turn the printer off. Turn printer on again.
Feb 18, 2015 | Canon PIXMA MP160 All-In-One InkJet...
Why has PIXMA MX410 printer stopped working? Re-installed Canon PIXMA MX410 All-In-One Printer on hp pavilion 23 widow 8 x 64, system would only print but menu solutions would not. Then printer stoppe
Driver issue. Uninstall and reinstall driver for win 8 64 bit - should work if same worked before. Did you try a system restore to time when printer was working properly?
Sep 11, 2017 | Canon Office Equipment & Supplies
MY PRINTER STOP WORKING WHAT DO I DO?
What do you mean it stopped working? What happens when you try to print to it? Are there any messages?
Printer's don't just stop without giving you some indication as to what is happening.
May 31, 2012 | Lexmark Office Equipment & Supplies
My mp250 printer shows error p08, I can't use it in any way. I replaced the black ink tank with a new one and tried resetting the printer and it doesn't solve the problem.
Follow the instructions step by step
  1. Turn off printer, cable power still plug in,
  2. Press Stop/Reset button don't release
  3. Press Power Button don't release and than release Stop/Reset button
  4. Press Stop/Reset button 2X , wait until service mode to " 0 "
  5. Turn off printer, cable power still plug in
  6. Press Stop/Reset button don't release
  7. Press Power Button don't release and than release Stop/Reset button
  8. Press Stop/Reset button 4X , wait until service mode to " 1 "
  9. Turn off printer, and loose cable power, wait one minute.
  10. Connect cable power, turn on printer again, now this printer ready to use.
Jul 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Document stuck in que, can't delete, can't print i can delete the other ones after the first one, but the first one is stuck. tried to delete several times, won't allow it. tried to unplug printer, shut...
I'm not an expert, but this usually fixes my printer when this happens. Go to Start, Control Panel, Administrative Tools, and then Services. You will see a long list of items. Scroll down to Print Spooler. On the left hand side you will see buttons to Stop and Restart Services. Click on Stop and wait until it stops. Then click on Restart. Try to delete the item from the printer que again. If it doesn't work, do the same steps as above, but between the Stop & the Restart, try to delete it then. This works for me. Good luck!
Mar 04, 2010 | Dell A940 All-In-One InkJet Printer
Printer stopped working. pc sending job to
hhhmmm... maybe you have installed the drivers many times.. the printer shows more copies in the printer panel... you must delete those printers... because that will cause conflict ....
Feb 15, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Both lamp on and the printer epson Tx101 stop working.
there is an existing issue w/ your printer that's why the light is not lid up ttry checking the error codes from the epson website
Apr 11, 2009 | Office Equipment & Supplies
Printer stopped working claiming the jobs have been 'stopped' and giving no explanation.
Hi Plug out the usb cable from the cpu. Try deleting the printers from the printers window(START, Printers and Faxes), uninstall the software. Power off the printer and unplug power adapter. After the printer has been deleted from the printer window, plug it back in and reconnect back to computer. Then try a new installation of the printer and software. The pending documents that have been stopped should now not be in the spooled documents.
May 02, 2007 | Epson Stylus DX4200 All-In-One InkJet...
211 people viewed this question
Top Star Micronics Office Equipment & Supplies Experts
GoogleLaughs
ray gallant
Are you a Star Micronics Office Equipment and Supply Expert? Answer questions, earn points and help others
