Question about Sony RM-Y914 Remote Control
I can't get the tv to turn when I press the on button. The tv went blank when I tried to change the channel. I have not been able to get the tv on since.
I have a livewire ttotal tv controller but i need the codes for sony tvs an the insrtuctions ?
Posted on Mar 15, 2010
Bauhn 80cm tv model no. ATV-32HDC1N
Could be internal power supply failure.
Dec 25, 2013 | Televison & Video
Good sound no picture
Check whether you have pressed the TV/AV button on the remote control.
Apr 03, 2013 | Toshiba 37HL67 37 in. LCD HDTV
Issue with Samsung LE32B450. After the TV has been on for about 5 minutes, when you change channel the screen goes blank and the sound goes off. However, the TV is still on as pressing the power but
Just do a hard reset to this set and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset.
Jan 12, 2013 | Samsung LE32B450 32 in. LCD TV
The remote for the television was on the couch and while sitting on the couch a button on the tv's remote was accidentally pressed (dont know which button) and the screen went blank, the audio of the...
Have you looked to see if the formatting was changed to something other than your TV input such as VCR/Game/DVD? Do you have satellite TV or cable? It is difficult to say which button might have caused this without knowing what you are using for a remote.If it is set to correct source for TV Try this:
Try operating the TV using the manual controls.Turn the TV off manually.
Remove the batteries from the remote/wait a few minutes then replace the batteries .
Try turning the TV on again.
Please let me know if either of these solutions works for you.
Dec 21, 2010 | LG 32LG30 32 in. LCD HDTV
My remote is nt working for channels
before you try to change the channels, firts look for a button that says tv/video `press it ( some times more than once ) depending on how manny video jacks on your tv until it shows tv again, good luck
Dec 18, 2009 | Televison & Video
KDL-32M4000 sony tv screen went black suddenly,
We are having the same problem! Whats the solution!!!?!?!?!?!!!?
Oct 18, 2009 | Sony KV-36FS100 36" TV
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Oct 18, 2008 | Electronics - Others
Remote not working on TV
Try programming with Code Search:
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 13, 2008 | Philips Televison & Video
Frozen on a menu screen
Just fixed ours with the same problem. You need to hit the volume buttons on the remote during the time the screen goes black but BEFORE it gives you the "Connect cables" message.It should trick the TV into giving you a blank channel.
Sanyo TVs are made notoriously cheap, and have little glitches like this. Best of luck, space cowboy.
Oct 13, 2007 | Sanyo HT27546 TV
32 in ILO tv, goes blank
Usually the blue screen is an indication that the video signal to the TV is not present. Most of the new TV's have a video input selection button on the TV and on the remote; try changing the video input selection.
Apr 27, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
126 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
