Question about EliteGroup P6VEM3 Motherboard
Memory upgrade for P6VEM3 MB
I added PC133 512mb memory to a P6VEM3 motherboard and now I have no vedio can you help
  • prazum Feb 22, 2008
    in must be my memory, the old memory works good Im trying
    PC133 512MB 133mhz CL3 by Patriot (PSS512133)
    what should I do?
    President:
  • 2,351 Answers
For this mainboard, you must use 168-pin, 3.3V unbuffered PC100 or PC133 SDRAM memory modules. You can install any size memory module from 32 MB to 512 MB, so the maximum memory size is 2 x 512 MB = 1 GB. As noted on pg. 9 of your manual. Shut down your system. Remove one dimm of memory & start the Pc. Does it boot & do you have video? No? Shut down & replace the the dimm with next stick of memory. Try again. Still no video? Replace memory with old memory. Did you regain video? In most cases of installing new memory it's found the memory just wasn't seated well enough. In few others the memory did not meet the correct voltage.
prazum post back your findings.
Posted on Feb 22, 2008
Acer aspire 5100 series bl51 video memory upgrade What is posible here?
This is a laptop. The video chip is on the motherboard. This machine cannot have a video card added.
Jul 26, 2014 | Acer Computers & Internet
Cannot find specification for packard bell i start 1379. I want to look into the possibility of upgrading this pc. Can anyone point me in the direction of the specs being available online for this...
Here is the homepage:
http://www.packardbell.co.uk/pb/en/GB/content/download
This specs provided was complete with a Intel Intel Serial ATA-300 ATA-133 PCI 160 GB Microsoft Windows Vista Home Basic , ATI Radeon Xpress 1100 128 MB 4 MB . The Desktops memory add up to 2048 MB , with standard memory 512 MB , memory installed 533 Mhz DDR2 SDRAM DIMM 240-pin Very low profile PC4300 Compact Flash Type I with 2 Expansion Sockets/Slots.
You can update the graphic, by adding a better graphic card, on the mainboard.
The ram can be upgraded to 2 gb ddr2 ram.
A bigger harddrive, can be added, for more space.
The cpu will be hard to find, it probably have socket 775, but this cpu is not available anymore.
And not all cpu`s will fit the mainboard.
Good luck
Feb 10, 2013 | Packard Bell (181368) Motherboard
Gt5082 what is the best sticks for gateway gt5082
Memory Upgrade for Gateway GT5082 Computer, the Gateway GT5082
Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory
Type, and comes installed with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your
Gateway GT5082 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) standard Memory installed.
For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Gateway GT5082 Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope it helps
Apr 14, 2012 | A-Data Technology 1GB kit (512MBX2)...
Hello, I have a Sharp Actius MC 24. I'm looking to upgrade the memory. I found 1 memory board in the compartment with the fan on the bottom of the machine. This board was labeled 256 MB. Do I remove this...
The other memory module is soldered on to the motherboard.
Go to Crucial.com and run the memory upgrade scanner. This tool will tell you what memory the system can use and exactly how you can upgrade.
Mar 28, 2010 | Sharp Actius MC24 Notebook
Does this motherboard support ddr400
Yes, this does support ddr400, there are two memotry sockets on the board they will hold 1 gig each you could try a 2gig stick in each but according to the spec on the board it only takes upto 2gigs of ram.
Jan 31, 2010 | Intel D845GVSR Motherboard
I added 2 mb memory to my 2 mb dell dimension c521 but it only shows 3.25 mb memory on my desktop when it should be 4.00
This is normal. You need a 64bit Windows if you want to see a bit more. The graphics can take up quite a bit of memory space.
Jan 03, 2010 | Dell Dimension C521 PC Desktop
How can i increase the memory of my dell optilplex sx260, with an intel 845 chip? i only have 8 mb graphic memory
You can't. The video card is integrated and there is no expansion slot available to upgrade it.
You can increase the total RAM on the computer by adding a larger piece or an additional piece, but this will not affect the graphic memory.
Feb 21, 2009 | Intel Motherboard
Memory confusion different readings
It sounds like something isnt working right, what operating system are you using, Vista? I would take out the original 512 and see what it says after, often ram isnt compatible if it is too different in size and speeds. Also, if your motherboard supports dual channel ram and you have the extra 512 chip it wont run in dual channel mode, you would run better with just the 2 chips then the added 512 chip.
Jan 17, 2009 | Mach Speed (S755) Motherboard
Processor Upgrade and Memory query
This motherboard supports up to 3gig of RAM so you can go ahead and upgrade it, There's no particular order fo install the RAm just put it to the empty slot then that's ok..
Hope that helps.........
Aug 21, 2008 | Intel D845HV (735858149143) Motherboard
Problem upgrading RAM to Intel D845GLLY
Most likely the memory is incompatible or in the wrong configuration. Check here to see the proper configuration for this motherboard.
Jul 16, 2008 | Intel D845GLLY Motherboard
EliteGroup P6VEM3 Motherboard Logo
223 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
