Computer switches itself off. COOPER
Computer switches itself off. Any ideas what to do ?
COOPER motherboard
Altissimo chassis
6 in 1 memory card reader
Modem CNR 2900-W sec
    Problem Solver:
  • 11 Answers
Get any updated anti-virus ,install it & scan your system.if the problem still persists then Install/Repair your operating system.
Posted on Mar 04, 2010
    Problem Solver:
  • 18 Answers
U should use heatsink on ur cpu n load defaults on bios confrigtn
Posted on Feb 19, 2010
Ram not working
Step 1:
A memory slot is a slot in your motherboard where you place your RAM (Random Access Memory) card. In layman's terms, the RAM is the "temporary memory" that the computer utilizes whenever it is turned on. If the computer cannot detect a RAM card installed in one of your memory slots, you have to troubleshoot the problem immediately.
Ensure that the problem is with the RAM slot and not the memory card. Turn off the computer, unplug all devices connected into the ports of your computer and open the computer casing. Refer to the manual of the computer to know the specific steps to follow in opening the computer casing. Remove the memory card from the RAM slot. To do this, unlock the card using both hands. Pull the card away from the slot to remove. Inspect the RAM card for any apparent physical damages. Wipe the card with a clean cloth to remove dust. Also wipe the memory slot in your motherboard. Place the RAM card back into the memory slot. Press the card into the slot until it clicks into place. Close the computer casing, connect the cables back into their respective slots and turn on the computer. Turn on the computer and see if the memory is detected. If the computer does not boot up, the RAM card is not detected by the computer. Assuming that you have two memory cards installed in the computer and the computer boots up, check if the second memory card is detected by the computer. Click "Start," right-click "Computer" and then "Properties." Under "System," check the amount of "Installed Memory (RAM)." If the RAM is not detected, the RAM slot or the RAM card itself may be malfunctioning. Place the RAM card into another memory slot in your motherboard and see if the card is detected. If it is detected, the other memory slot is malfunctioning. Do not install any RAM card into it to avoid further damage. If it is not detected, the RAM card may be malfunctioning. Insert another RAM card into the slot. If the RAM card is detected, the slot is malfunctioning.
http://www.youtube.com/watch?v=wGp5AiyJInI repair memory slot
Feb 23, 2013 | Computers & Internet
What does this mean if you have power one second and the next you dont. If I let it sit for a day it will boot up for a sec. then have to wait for the next to boot up
hi wired_mouse!
sorry to hear about this issue but based on this symptoms, this can be a possible motherboard or memory card issue. if you think you can disassemble your computer's chassis, go ahead and open it and try reseating the memory modules. if you have vacant memory slots on your motherboard, try inserting your memory modules there then restart the computer. if it doesnt work, try one memory module first (if you have a pair), remove the other pair see if it will work. I've had the same issue before and we were thinking it was the motherboard but luckily, it was only a bad memory card. it's cheaper than a motherboard.
for more options, try going to the official website of your computer and see if they have online manuals for your product model for accurate guide on how to go about the process.
you have a good day!
Sep 27, 2011 | Gateway Computers & Internet
ASUS P4S533-E. Question : The system intruded, chassis opened or tempered before. Please check the system. What does it mean?
Some computer-cases have a small switch that is "triggered" when somebody removes a side-panel. The trigger sets a flag on the motherboard, to say "intrusion", i.e., somebody opened the case, possibly removed something (RAM, video-card), or cut some wires.
You need to inspect the computer, to see if the "intruder" did anything to your computer.
Then, you can enter BIOS SETUP mode, and "clear" that flag.
Optionally, you can then "disable" that "chassis intrusion" programming.
Jun 01, 2011 | ASUS P4S533-E Motherboard
Iomega beeping when turned on
The computer beeps if there is a computer components or a device that is not detected or having a trouble. So in that case you have to open your system unit or they called it as cpu, Before handling any computer component or device you must discharge electro discharge that presents in your hand or body. Hold the computer casing chassis for about 1 minute and you may hold the computer component after discharging. Unscrew the video card and unplug same with your system ram or memory. Clean the video card and memory by brushing and vacuuming so that the dust will remove and to clean the slot. Clean the video card and memory pin only using a hard eraser to its pin and brush the pin to remove the dust. After cleaning put it back altogether and turn on your computer to test your computer. Have a nice day.
Mar 23, 2011 | Computers & Internet
Power switch hook-up
You can use a manual switch off a computer and connect to the on and off switch on the motherboard.
Dec 21, 2009 | Asrock P4i65G Motherboard
Dell dimension 2400 blinking amber light
1. Remove All External Devices
2. Check the Computer's Power LED
3. If the power LED has not changed unplug the Power Cable From the Computer Disconnect All Hard Drive Power and Data Cables and power on the computer. If still no go.
4. Remove All PCI, PCI-E, and AGP Expansion Cards .
5. Remove All Memory From the Computer
6. Reseat the ATX and 12-Volt Connections . The ATX connector will be a 4 pin square connector connecting to the motherboard from the power supply and the 12-Volt Connection would be the biggest connector with a lot of colored wires.
7. If still no go.
8. Disconnect the Power Connection to the Chassis Fan
9. If the light still flashes then it could be a power supply or motherboard failure. Try a good know power supply first and if that does not fix the problem it is the motherboard. Also check the back of the tower for 4 lights lables ABCD or 1234.
Rate if useful.
Aug 11, 2009 | Dell Dimension 2400 PC Desktop
Computer won't read my memory card
Hello. Regarding your problem first you have to consider the compatibility of your memory card in your computer cause not all memory card supported by computer. Other memory card need to install their device driver in order to recognize by the system that you are currently using. Therefore my recommendation, try to check first if the your memory card reader evice is recognize by the system/computer then check also the memory card itself maybe their something wrong with your memory card and if you find out that the memory card of your's have the problem then return it to the supplier.
Jun 15, 2009 | PNY Optima Pro 2GB Secure Digital Memory...
P4m800pro-m478 "No video"
if you have another pci slot install the card there
if that does'nt work
your card has probably gone
please rate me
thanx
Feb 02, 2009 | EliteGroup ECS P4M800-M Socket...
Tyan tiger mpx (S2466N-4M) weird boot problem
probably the board is bad or the board is grounded out on the chassis edge somewhere or possibly the mounting screws...
recommendation.. pull the system out of the chassis
test the power and board on a sheet of cardboard...
also try one stick of memory only and set the options for full ecc scrubbing on to test the memory correctly
Aug 26, 2008 | Tyan Tiger MPX S2466N-4M Motherboard
My computer lights
hello,
i assume you know how to open your pc...
Solution (1)
1. make sure your computer is not plugged in
2. open the side panel
3. remove the memory card
4. plug in you computer
5. switch on your pc. you should hear a beep. this is to check whether your pc is still working.
6. unplug pc
7. re-install the memory card. make sure that it is firmly attached to the memory slot.
8. switch on again. this should do it.
else
Solution (2)
Try replacing your power supply unit (PSU). faulty PSU may not be able to supply enough power to your motherboard or other peripherals which is attached to your PC.
hope this post can help you :)
Aug 05, 2008 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
