Westinghouse Electric L2610NW 25.5 in. LCD TV Logo
Anonymous Posted on Feb 07, 2010
I have headphones plugged into the audio plug but sound still comes out through monitor speakers. i am using the monitor to display HDMI signal from xbox 360. sound works fine from built in monitor speakers but i need to route that through headphones to keep audio form being heard by other people
  • 4 more comments
  • Anonymous Feb 07, 2010
    i tried the contact solution, no help. i tried plugging my speakers into this jack, as well as headphones,
    and i still only get sound through built in monitor speakers. i cant use normal cpu connections for
    anything because i am using this monitor as display for xbox 360 using HDMI.
    i thought it was clear that im using the L2610NW
    this jack is located in a very difficult spot to reach behind the base stand, i can barely get to it to plug in,
    much less get any kind visual
    after a closer look this jack says audio in, there is NO audio out so i guess that's it,
    i'm stuck with this situation
    can try
    not really a solution for me, i would be totally lost, thanks for the help
Anonymous
Level 3:
  • Master 5,807 Answers
  • Posted on Feb 07, 2010
Anonymous
Master
Level 3:
Answers
5807
Questions
0
Helped
271972
Points
13914
a ) possible that built in switch inside the headphone jack is stucked,
here is a sample illustration:
those contacts breaks whenever a plug is connected, it is normally
close,
In your case the speaker is electrically disconnected whenever
a plug is connected.
Although in some cases, headphones jack have separate audio
amplifiers.
b ) Here is just a suggestion, you can use external headphones
amplifier if you intend to hear the sound or music privately,
some computer speakers have one on them.
c ) Should you feel to DIY , have an electronic contact cleaner and
spray the headphone jack with it. ( you can find it , in your nearest
electronic store ).
hope these helps
  • 7 more comments
    it might be better if you could post the make and model of the unit you are having!
    have a visual on the headphone jack, if it have more than 3 pins on it,
    then it includes speaker/headphone switch.
    have it replaced if it is more than three ( 3 )
    have you checked the headphone jack( where you plugged the headphone plug ) ?
    how many pins that it have?
    it is most likely on your headphone jack
    if it looks like these , you may need to replace it
    if it is audio in, then headphones cannot be controlled by that jack
    you may need to make one, can you DIY?
    have to get one like in the last image,
    a ) one is common or ground
    b ) two pins will be for speaker
    c ) two pins will be for original wiring
    also needing wire for headphone jack
    30 watts soldering iron
    good soldering lead
    a multimeter
    some looks like these:
HOW DO I GET SOUND ???
Your HP Pavilion F1903 monitor does not have built-in speakers. Your desktop computer probably did not come with speakers. You will have to plug computer speakers into the audio-out jack (green) on the back of your computer to play through external speakers.
There are also a number of USB speaker systems available that use USB both for power and for the audio signal.
Alternatively, there is probably an earphone jack on the front panel of your computer. If you plug headphones into that you should be able to listen on your headphones.
Amazon com AmazonBasics USB Powered Computer Speakers A100 Computers... Amazon com Joylive White 3 5mm In Ear Earpiece Earbud Headphone Earphone...
Speaker in/speaker out not working
Are you feeding the monitor via an HDMI connection? HDMI carries digital audio as well as digital video signals. If using DVI or VGA to connect it to your PC, there is no audio being fed to the monitor, so nothing can come out, unless you have a separate audio cable running to the monitor as well from the computer :o)
1helpful
No Speaker Sound, Thinks Headphones are Plugged in
If you don't plan on using the headphones - take the cover off and there may be a cable to the headphone jack board that can be unplugged. This will disable the headphone jack from sending a bad signal to the micro. If you want to be able to use the headphone, then the jack is going to have to be replaced.
My computer is a SyncMasterP2570HD i cant get any sound to come out but it is detecting sound how do i fix it
The Samsung SyncMaster P2570hd is a monitor with speakers; it isn't the computer itself. I'll assume that you are dealing with a computer connected to the monitor and not a set-top box. Make sure that Mute is not enabled on the computer. There should be an icon on the lower right hand side of a Windows desktop. If the mute is enabled, it will have a red circle with a diagonal line through it. Left click on the icon to remove the mute (change the volume or click on the mute icon). Test the monitor's speakers by connecting it to another device with known good audio output.
Next how are you connecting the monitor to the computer (VGA, DVI or HDMI)? If you are using VGA or DVI (including DVI to HDMI), you need to connect an audio patch cable (3.5 mm) between the speaker (green port on the back of a sound card) or headphone jack of the computer and the audio input jack of the monitor. The audio input jack is between the DVI and VGA ports. You can test the output of the speaker jack on the computer with regular computer speakers. Plug in the power cord (or USB cable) for powered speakers. If the free-standing speakers work, check the volume setting on the monitor with the +/- buttons to the right of the menu button. Do not press menu first, though. If that doesn't solve the problem, continue using the separate speakers. (Unless the monitor is still under warranty, it usually isn't worth taking apart a monitor to replace the speakers. You may be able find replacement parts online.)
If you are using an HDMI cable, check the output audio setting to see if the HDMI audio is available. For Windows, click on Start > Control Panel > Hardware and Sound (Windows 7). Then click on Manage Audio Devices under Sound. In the Playback tab, check what available audio devices you have. Make the HDMI the default device by right-clicking on it and selecting Make this the default device. (Other versions of Windows will a slightly different route to this panel.) You may need to restart the computer to get the audio signal on the HDMI cable after setting this. Note: not all video cards/computers support HDMI audio. If you don't see HDMI listed in the Playback devices, connect an audio patch cable as with a VGA or DVI cable, described above. Use stand-alone speakers if the monitor's speakers are bad.
I hope this helps.
(I have had the speakers fail in monitors; <$30 separate speakers are an adequate replacement for those built into a flat panel monitor.)
2answers
Why is the sound not working on my acer screen
How do you have the screen plugged in?
If via HDMI, audio should go to your screen, but you may need to output to speakers (that is, if your monitor does not have built-in speakers).
If indeed outputting via HDMI, make sure your computer KNOWS it's supposed to output audio through the HDMI port as well as the video.
Finally, you might just need to plug speakers/headphones into the monitor - most have an audio jack on the underside, by the stand.
1helpful
Is there any way to use headphones on the HP 2159m computer monitor? possibly external computer speakers? I have a desktop computer connected to the monitor by a HDMI cable.
There is no audio output on that monitor. So decoding the HDMI into analog is out. However, the simple fix is to plug your speakers or headphones into the green 3.5mm headphone jack on the back of your computer, and change the default audio device in windows. You can use both audio cards at once for different tasks, such as having someones voice come over your HDMI cable on the monitor, while listening to music on the audio out of your computer.
If you need any help setting the audio card, let me know.
~KenjiFox
Can 2.1 pc speakers work thru headphone jacks?
No it's not possible to have a sound. Because the HDMI and the Headphone (3.5mm jack) are on two different technologies.
The monitor does not have a way to convert the sound from HDMI to Headphone.
There could be a converter that might convert the sound signal from HDMI to headphone (but I'm not sure).
1helpful
What is the sound card input on an hp2207?
The Jack which you found nearby the HDMi is a Input jack. you can get a output from your Computer's Audio out to to this input jack the speakers integrated with the moniter make sound. here there is no chance to plug your headphone. if you want you can plug your headphone in the front jack of your computer
1helpful
No sound
Dear marco1983,
there are no speakers on G2400W, just the plug hole for speakers that routes forward the sound signal from the HDMI signal.
Top Westinghouse Electric Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Westinghouse Electric Televison and Video Expert? Answer questions, earn points and help others
