Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Honeywell CT2800 Doesn't Follow Programming
I have a Honeywell CT2800 thermostat that I installed about 10 years ago. Within the last week, it has started acting up - the heat doesn't necessarily come on when programmed to. Sometimes it does, sometimes it doesn't. When it does, it will also sometimes shut off before the programmed temp is reached. Batteries are fresh, and the date and time are set properly. I am thinking that the thermostat needs to be replaced. Do they 'wear out' over time?
5 Suggested Answers
SOURCE: Battery Issue
This worked! Thank you! It was 49 degrees in the house, and now the heater is working again.
Thank you and warm wished for the new year!
Mary
Posted on Dec 30, 2008
  • 19 Answers
SOURCE: My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
Posted on May 17, 2009
SOURCE: I need to reset the date and year
I had exact same problem with RTH7500. Did not set the date properly at the beginning and than realized that there is no menu option to change the date after it is saved once (???!). I was very confused for few hours and wandering - trying to find changing option on thermostat menu; than I was looking online what can be done... I could not find solution...
Than I took out both AA batteries, open the thermostat (be very careful while doing this - you don't want to break plastic peaces that hold the thing together) and took out the button battery thinking that this will reset the thermostat... but it did not.
I repeated the same thing, but this time, while the button battery was out, I put two AA batteries back and this reset the thermostat... the old - blinking date appeared and I was very happy to see this on thermostat screen! This time I set the time properly and it works fine.
Hope this will be helpful if you did not solve the issue yet... if you did, someone else might find this solution useful.
Posted on Aug 03, 2009
SOURCE: I have a Honeywell CT2800 Thermostat and a message
it's just running your "return home" program, so it says "return". the FR above it is just meaning "Friday". They line up in a way that makes it look like the two words are together but they aren't, the week line is just right above the program line.
Posted on Dec 12, 2009
Honeywell RTH2300 says Heat On, but furnace isn't running.
Your tstat is not the problem. I've not yet worked on an oil furnace. I'm way down south. But either way, if your tstat was calling for heat(heat on), and you pushed a reset at the furnace, more than likely that reset is a safety. OK to reset, but now what ever that safety is preventing from happening, has failed and can not be reset until repaired. The reset should be an automatically opening switch upon unsafe operation. And manually closed to "reset" the safety. That safety is connected to something that is not working properly. Hope this helps!
Mar 02, 2017 | Honeywell prgrammable thermostat RTH2300B
Digital thermostat Honeywell RTH 2300 - compressor runs when in heat mode
Check thermostat wires maybe to long and touching in the back of the thermostat
Mar 21, 2013 | Heating & Cooling
How do I unlock a honeywell (non-programming)heating unit. Our home is not heating. We can select heat but it changes to aux. heat within 10 seconds.
This is because your home is more than 2 degress colder than you thermostat setting. Your heater is probaly broken.
Jan 04, 2010 | Honeywell ER150B Air Conditioner
Honeywell RTH2310B Programmable Thermostat
i would check to see if thier is a jumper between RC and RH on the stat if no and the red wire is hooked to RH then you need to add a jumper to RC
Sep 19, 2009 | Honeywell Focus 6300B 5-2 Days...
I have a Honeywell CT2800 Thermostat and a message FR Return came on
Jul 17, 2009 | Honeywell Electronic Programmable...
May 11, 2009 | Honeywell Programmable Thermostat Heater
I cannot get my honeywell cw 61 to heat above 20°but I need 24°
At www.honeywell.com/yourhome there is an owners manual and literature search on the right side of the page close to the middle where you can search for and download PDF versions of their owners manuals.
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
71 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
