Question about Kyocera MARBL K127 Cellular Phone
Screen stuck on Phone is OFF Will power on automatically
The computer is stuck on preparing automatic repair
use the operating system/install boot from it, then run repair the computer form the install menu
May 29, 2017 | Power Computers & Internet
Samsung Galaxy Note 4 - Stuck in a power up loop
Samsung Galaxy Note 4: power on off loop:
I have a Note 4 also.. When I updated to one of the newer OS it started power on off looping when the battery got to a low percentage. This would freak out any User. It is normal for many people however. It is a Google software firmware issue that will probably be fixed after the next patch update.
In the mean time, if when your battery gets really low and you get the power on off loop, just charge the device or pop in a charged battery.
There is no fix for this right now. You just have to deal with it.
If your battery is higher then 15% left and it is looping, then the possibility is that either you tried to/or the system automatically tried to update your phone, but the transfer was interrupted or corrupted some how.. could be bad connection between the towers or the WiFi router you were on.. or any number of other things.
If you are in the US, best to drop by a local Best Buy store. Call ahead and ask if they have a Samsung Experience Shop inside. Not all Best Buys have one.
Ask to have Best Buy transfer your call to the rep there if possible (I'm not sure if they have a phone there.. if not you may have to just visit the Best Buy store with the Samsung Experience Shop inside there..
Bring your device and your charging cables/adapter just in case, make sure the battery is charged).. Ask if the Samsung Manager can help you and when s/he will be available.
That person will have the knowledge and the equipment inside the Samsung Experience section to get your phone back to normal again, however note that you may lose all your data files on the phone. It most likely will have to be factory reset and possibly reFlashed with the OEM firmware.
WELCOME TOTHE SAMSUNGEXPERIENCE SHOP
Jan 09, 2016 | Samsung Galaxy Note 4G
Please help me reset my phone its stuck on start up blue screen... It won't lets reset because of kill switch. Please help me my email is josh.staff87@gmail.cpm
You didn't explain which phone do you have its Android or Windows phone. Every smart phone has feature once it stuck at a point press and hold power on off switch for few minutes,you will see it restart automatic and you will be able to use it. Try it.
Aug 09, 2015 | Cell Phones
Had keyboard replaced,now powers up and screen blanks off
If the power button is located on the keyboard, then make sure the power button is not stuck. Cause when stuck, it switches off automatically after 4 seconds.
Or check if the RAM memory is properly inserted.
Sep 18, 2013 | Toshiba Satellite 1715XCDS Notebook
Zte score stuck on muve music screen loop
Hey i've been workin on these ZTE phone and i guess all u need to do is a reset. But the only problem is u will lose all ur data. all u gotta do is First power off the handset, press the Camera key + Power on key +Down volume key together at the same time.
when restart the handset,When display "ZTE", press the Menu key at the bottom of the screen;
Choose "Wipe data/factory reset" through volume key
Press "Camera" key to confirm the above item
Choose "YES...delete all user data"
Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
Now once its done ur phone will automatically configure all the factory setup and should work fine,
Apr 09, 2013 | ZTE Score
Stuck on android logo
Just try the following steps and you can solve the issue that you're facing:-
1.Power off the phone.
2.Press and hold Vol+ key and Power key simultaneously for about 10 seconds until the some option appear on the screen which are reboot system now; apply update from sdcard; wipe data/factory reset; wipe cache partition.
3.Use Vol+ key and Vol- key to move the cursor to "wipe cache partition" and press camera key to confirm it.
4.After 5 seconds, the cursor will be on "reboot system now" again and press camera key to confirm it. The phone will reboot automatically.
Mar 30, 2013 | ZTE Warp
The screen is stuck on calibrate
Reset your phone to fix the issues by following steps:-
1)First power off the handset, and press the POWER key + MUVE key + UP Volume key together at the same time;
2)When the screen displays recovery pattern, press POWER key + UP Volume key _MUVE key together, enter into recovery menu;
3)Choose "wipe data/factory reset" through volume up key, press MUVE key to confirm;
4)Then choose "YES...delete all user data" through volume up key
5)Choose "reboot system now", handset will be restarted automatically and all the user data will be erased;
Feb 11, 2013 | ZTE Chorus - Black cricket Paygo Prepaid...
My ZTE muve cricket phone is stuck on the lock pattern screen and when I go to unlock it all the circles do is flash red and green and wont let me draw the pattern?
I have a Cricket X500 phone and to reset this phone I use the following instructions:-
1) First power off the handset, press the Power on key + Camera key + Down volume key together at the same time when restart the handset.
2)When display "ZTE", press the Menu key at the bottom of the screen;
3) Choose "Wipe data/factory reset" through volume key
4) Press "Camera" key to confirm the above item
5) Choose "YES...delete all user data"
6) Choose "reboot system now", handset will be restarted automatically and all the user data will be erased.
Jan 23, 2013 | ZTE Cell Phones
Kyocera MARBL K127 Cellular Phone Logo
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
DROPNDEAL
DROPNDEAL
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
