Question about Epson Stylus C86 InkJet Printer
Epson stylus sx100 general error message. Flashing lights
I have a general error message. Flashing lights and it says remove paper jam. There is no paper jam. What can i do ?
SOURCE: Epson stylus photo R1800 printer
http://www.fixyourownprinter.com/forums/printer/35608
this website will answer all your problems
Posted on May 27, 2008
Dipu007
  • 2110 Answers
SOURCE: Epson Stylus D88 Plus paper jam
1. Unplug the power and USB cables from the printer. I pried open my C42UX printer, careful not to break anything. I use a flat blade screwdriver to pry it apart; there are two-three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
2. Next I removed the two (2) waste ink pads. They are located at the back on the left hand side. I used the flat blade screwdriver to lift up the ink pads (they were soaked). Please use rubber gloves as it gets very messy.
3. Next I took the pads to the kitchen skin and washed them with just plain hot water until they were white again. I just let the hot water run on them (the pads are about three inches long).
4. Once washed I dried them using a hair drier. (you could place it the sun for a few hours or on top of your heater or maybe in a heated oven; (make sure you do not set it on fire with too much heat).
5. Once dried I placed the pads back in the ink waste bin at the back of the printer.
6. I closed the printer cover and put back all the pieces and plugged in the USB & power cable and turned it on. (Yes the lights are still flashing).
7. Go to this link and download this software: http://inkjetprinterhelp.us/epsonSSC.html
8. Install the software and run it.
9. Select your printer and model number ( It only says C42 there is no UX, choose it anyway).It will ask if you replaced with new pads; say “YES”. Then close the window.
10. Now right click on the SSC service utility, it looks like a printer icon near your clock in the task bar.
11. Then click on reset counters. You can do all other stuff with this utility too.
12. Turn off the printer power and then turn it on again. If necessary un-plug the power cord from the back of the printer, wait 20 seconds. Plug it back in.
13. THERE YOU GO! IT WORKS AGAIN.
14. By the way I use generic ink and I fill my own cartridges. I use ink from www.atlanticinkjet.com. Great stuff.
try this and let me know it worked or not ...
Posted on Dec 12, 2008
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
Posted on Feb 16, 2009
aicaxz
  • 511 Answers
SOURCE: alternate flashing red lights on epson stylus photo 900
Flashing alternately? Need reset waste ink. SSc ver 4.3 support this model. Find at indoreset.blogspot.com.
Posted on Jun 26, 2009
tech-agent
  • 83 Answers
SOURCE: Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Posted on Feb 13, 2010
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus 1200 lights indicate carriage jam
This means that your Epson printer has come to its end of life. In short, Epson wants you to retire your printer and buy a new one. Your Epson printer may be in good shape which is often the case. But Epson has this build-in "feature" which they want you to buy a new one.
Jun 15, 2010 | Epson Stylus Photo 1200 InkJet Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Epson Stylus TX110 printer paper jam light flashing but no paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 28, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus SX100 General Error
The flashing lights are a "Maintenance request error" or a "Fatal error". Most of the time it is a "Maintenance request error" which means the waste ink pads need to be serviced. You can reset the waste ink counter but the ink pads will need to be serviced at some point. get more information and help from here . Hope this helps you.
Sep 11, 2009 | Epson Stylus Multifunction Inkjet Printer/...
"Clear paper jam" error, but there is no jam!
Use flashlight to shine inside of all possible visible areas of printers. Especially to the very right or very left. I'm sure you will find something. Remove it
May 25, 2017 | Epson Stylus Photo RX620 All-In-One InkJet...
Error message
Which lights are flashing?
Sep 25, 2008 | Epson Stylus Pro 4800 InkJet Printer
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
662 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
