Question about Panasonic Car Audio & Video
Pinouts for Panasonic CQ-RD45fst. Need to know what each pin is for, not colours of wires. eg Pin 15: +12V, Pin16 :GND
zzedly
  • 300 Answers
SOURCE: wiring diag. panasonic CQ-DF66EUC
Click the "Start Download" button on this page to download the owner's manual for your receiver. Page 30 has the wiring diagram.
Posted on Mar 05, 2008
tech48
  • 624 Answers
SOURCE: Panasonic CQ-DP620AEUC pinout (car radio/CD
Yellow wire is always the memory or back up, which is always 12 volts even with key off. Red is for ignition, 12 volts only when key is on. Black is ground. Speakers are color coded in pairs, the grey and white pairs are the fronts and the green and purple pairs are the rear speakers. Each speaker wire with a black stripe is the negative speaker lead and the solid color is the positive.
If you need more help just let me know and a FixYa! rating would be appreciated.
Thanks,
Dave
Posted on Jul 14, 2008
Benimur
  • 6966 Answers
SOURCE: vga pinout schema for samsung 753dfx
Apparently what you need are the wiring for the VGA cable itself. They would differ from manufacturer to manufacturer since it is not a Samsung item. Would the schematic and/or Service Manual of the Samsung chassis AN17K (753DFX, 76DF, 753V, 753S, 76V or 76E) help? if so, pls try here, here or here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 16, 2008
  • 336 Answers
SOURCE: Need SPDIF pinouts identified.
When looking at the board, bottom towards you assuming that the 3 pins are parallel to the pci/e slots, the left pin should be the +5V vcc the middle pin is the spdif out and the right pin is the ground. Also the 3 pins are probably not exactly the same distance from each other (equally spaced) the 2 pins that are closest together are the spdif and the ground, spdif is always the middle pin. This info is based on 2 different asus motherboard install guides. I hope this helps you.
Posted on Aug 12, 2009
  • 73 Answers
SOURCE: i need a wiring diagram color code for a panasonic
look on this site:
http://www.the12volt.com/
Posted on Oct 31, 2009
I need help with a 2001 ford f150 xlt data link pinout pin 16 showing no power i check the fuse are ok but cigarette lighter works i need a wiring diagram.
https://www.google.com/search?client=aff-maxthon-maxthon4&channel=t27&q=2001%20Ford%20F150%20XLT%20Wiring%20diagram
May 09, 2017 | Ford Cars & Trucks
Panasonic car head unit CQ-VW120W, my aftermarket adaptor is missing 3 wires so I'm looking for pinout info. I know what all the colors are. I just need to know which pin numbers do what.
All parts and service manuals can be obtained by calling the Panasonic National Parts Center directly at 1-800-332-5368 9am-8pm EST during weekdays.
Sep 21, 2013 | Computers & Internet
TW10794V-0
If you tell us what the monitor is doing, the solution may not require knowing what voltage is at what pin - especially since some of the voltages may be oscillating!
Dec 12, 2012 | Sharp Computers & Internet
How to crimp 1 end of cat 5e cable with rj11 connector that was cut off. What is pinout order that each wire should in the rj11 connector? the colors are: Black,green,red, yellow & clear. ...
The pinout of the modular camera connections is as follows:
Pin 1 ----------------------- Alarm / In
Pin 2 -------------------- +15Vdc Out
Pin 3 ---------- Intercom Audio Out
Pin 4 ------------------------- Video In
Pin 5 ------------ Intercom Audio In
Pin 6 -------------------------- Ground
Goodluck
Oct 18, 2010 | Cameras
Aug 11, 2009 | ASUS Intel 5000P Chipset...
RS 232 cable manufacturer
Is 25 pin or 9 pin connector?
In either case pins 2 & 3 are Tx & Rx data, you might have to swap them.
On DB-9 pin 5 is GND, on DB-25, Pin 1 & 7 are GND.
Here is a link to a reliable source of pinouts for you to construct your cable.
Apr 06, 2009 | Computers & Internet
Pinouts for Hirose 41 pin connector on panasonic LCD DL3DE0127BAA
I am attaching the image. This is standard 41 PIN Hirose connector for the LCD TV. It doesnt matter who is the manufacturer because all LCD TV has to abide with the Industry architecture. For more information click this link :
http://www.geocities.com/p9019/lcd/LCD_Panel_Pinout.html
Nov 01, 2008 | Computers & Internet
Vga pinout schema for samsung 753dfx
Oct 16, 2008 | Samsung SyncMaster 750S Monitor
IBM Clicky Model M Keyboard
Viewing the male connector (on the keyboard or mouse cable), the pinout is:
In both cases, the pins are normally used as follows:
pin function
1 data (yellow)
2 (reserved)
3 gnd (blk)
4 +5v (red)
5 clock(white)
6 (reserved)
try to interchange wire from pin 1 and pin 5 if doesn't work.
Dec 27, 2007 | IBM (02K0806) Keyboard
Car Audio & Video Logo
121 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
