Question about Belkin (F5D7230-4) Router (587009)
Gate way ip
My dell laptop has gate way 192.168.2.1
it takes for ever to down load torrent
please help
  • mickey54 Feb 24, 2008
    this did not solve problem and charter.net is isp i tried with both
    laptop and desk top still the same i have all fire wall disabled
    and pup up blockers off and still works verry slow
    think you
  • mickey54 Feb 25, 2008
    i beleave it does slow down
    thank you
    Novelist:
  • 113 Answers
Who is your ISP? Comcast, and several other ISPs (ATT, for example) have started "delaying" torrent traffic. What they are actually doing is inserting a RST packet, causing the connection to reset, and the torrent then needs to start over. This is the likely reason your torrents are taking so long.
If you'd like to ensure that the router is not at fault, you can plug a cable from the laptop's Network port directly into the modem (you'll need to take the router out of the loop), then cycle the power to the modem (so it will see the laptop instead of the router), and then try your torrents. If everything then works as you would expect, the router is the problem. I think you'll see the same problem, and if so, it proves the router is not at fault.
Posted on Feb 22, 2008
  • Phil
    Phil Feb 25, 2008
    I believe that Charter.net is one of the ISPs that is filtering their traffic. Does anything you do on the internet slow down when you are downloading a torrent? And is your internet speed otherwise fine when are not downloading a torrent?
No display problem, vga's out to external, then after 2nd reboot, internal display works, but with errors
If you have already replaced the screen...
Common problem when replacing equipment on laptops is that the "cable" goes into a flat housing that requires you to lift a little white "gate" then insert the cable and put the "gate" back down. Problems usually occur when snapping the "gate" back down. Pull the cable back out and be sure to lift the gate insert the cable and then put the "gate" back down. Once done give it a light tug and it should hold very firm and not move at all
Nov 20, 2013 | Dell XPS M1530 Laptop
I have dell latitude cpx j laptop it has problem with service pack 3 it is not loading
this is happening only if the windows genuine advantage has found the xp not genuine..and blocked with that banner the functions ...in this case better reinstall and I will recommend this windows ..
http://thepiratebay.org/torrent/5388204/Windows_Xp_Genuinesa
download it with utorrent program ...and you need to have a Nero installed or another ISO burner..and just double click on the image to burn it on a CD-R ...after that boot from it and install...the key is in the folder ..write it down cause you will need it on installing ..
Please dono forget to rate ...Have a nice day ..
May 29, 2010 | Dell Latitude CPX-J Notebook
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
IP adress configuration problem
Click on the start menu (orb) (with windows XP click on run, in Vista type in the search pane)
In the search or run box type cmd and hit the enter key. A command line window will open up, in the window type ipconfig or ipconfig /all
That will show you your IP address.
Regards.
Jan 11, 2010 | Dell Computers & Internet
My Wireless-G Notebook Adapter will not connect to the Internet
If you go to the control panel in the start menu, check the network connections. It may be a LAN connection or another wireless connection that is not connected. You can disable them by right clicking on them. If you are able to get on the internet then you are ok. Let me know. Please give good rating...
Aug 27, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
My webcam not working
hallow this you can download your processor all drivers from this website http://thepiratebay.org/torrent/4177488/Dell_Inspiron_1525_XP_Drivers
download the torrent file and open the downloaded torrent file with azerus ,,you can download azerus from this website http://www.toggle.com/lv/group/view/kl25534/Azureus.htm
the torrent has many drivers including the webcam drivers
Jan 13, 2009 | Computers & Internet
Help with Static IP address configuration
no need to set static IP addresses for the PC, i have been using UTorrent client with a laptop and used the laptop on different network, just set your torrent port to be dynamic, or let the torrent client find an open port everytime you use it (it is always under network settings / preferences).
if you have other questions just let me know, i'd be more willing to help out.
-voodoomox
Jul 30, 2008 | Linksys Computers & Internet
Dropped Wireless Connections
try getting a new network card for your laptop.
May 18, 2008 | Dell XPS M1530 Laptop
Runpath
go to add remove programs located at control panel. remove u torrent. restart your computer. thats it.
Jan 24, 2008 | Acer Aspire 5500 5570-2609 Laptop
Belkin (F5D7230-4) Router (587009) Logo
59 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
