Question about Canon PIXMA MX300 All-in-One Printer
I have Pixma MX300 printer. I can't scan. When you press scan button, nothing happens although printer is connected to computer. I tried changing printer driver but it didn't work. Frustrated?
  • 1 more comment
  • dpanchoy Feb 07, 2010
    I changed the cable but it didn't work. When you press scan button nothing happens?
    Hi Ginko,
    I am waiting for your reply. I changed my cable but it didn't work.
    Don
    Hi Ginko,
    I am sorry, I went out so I couldn't followup on your solution. You are great man, it works now. Here is the summary of what I did or tried:
    Change USB cable
    uninstall driver
    restart computer
    install new driver
    connect USB cable
    result___still has the same problem
    I did all of the above with different lap top and it works. Only thing is when scan window opens it say trying to connect to device and if go ahead and hit start button anyway it comes with the following message:
    "an error has occured while attempting to import. Either the source is unavailable or the detination is full or read only"
    I checked at the top of the window where it is importing from(source) it says drive D or CD drive. If I manuualy change this to Canon mixer300 and hit start it opens with a new window with scan button.
    If you hit scan now it works.
    My question is why source comes with drive D instead of canon300. I didn't have to do this before?
    How I can I fix this problem so when I hit scan it should start scaning as it used to do.
    Don
    Sergeant:
  • 244 Answers
If you are using a MAC, i believe there is a known issue in scanning (no response even after pushing the button)
There is a special tool (MP Navigator EX X.X Opener) from the download site to install it. Click this link CANON
Hope this helps.
Posted on Feb 08, 2010
  • Canon Master
  • 19,396 Answers
Hi.
I fix many printers, and I can tell you that a common cause for this is a defective or too long USB data cable.
A problem with the USB cable on one of the data lines can cause the scanner not working , and will not affect in any way the printer functions.
Try replacing the USB data cable. It may look strange, but after driver problems, this is the most common fault that can cause the printer working and the scanner unit not responding on an All in One printer.
Regards.
Posted on Feb 07, 2010
  • Ginko
    Ginko Feb 07, 2010
    That is probably because you also changed the printer driver.
    Go to the control panel, remove all the copies of the printer, and install the printer again. Disconnect the printer cable before starting this procedure. Keep the printer driver not connected until asked by the driver setup procedure.
    If you do not have the driver disk, see: How to download driver for a Canon printer...
  • Ginko
    Ginko Feb 07, 2010
    Hi, did you read my last comment. You may have also messed up the drivers.
    I repeat:
    If that does not work, then test the printer on a different computer, rather than a communication problem, in that case there may be a fault.
    Ensure you have the USB cable not connected when starting driver setup (you will be asked to connect during installation). If you connect USB before installing the drivers, Windows may install its own drivers.
    Regards.
Tip
How to Reset Ink Level Canon MX300 Cartridges
1. Switch off the Canon MX300 and disconnect the power cable.<br /> 2. While press and hold the power button, Connect the power cable to electric socket.<br /> 3. While pressing the power button, press the "Cancel/Stop" button (red button).<br /> 4. Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says "idle".<br /> 5. Press "&gt;" (next button) once "Shipping Mode 3&prime; then Press the "OK" button. Press "OK" again for "without cleaning".<br /> 6. A test page will print.<br /> 7. Open the cover, like you are about to change the cartridges.<br /> 8. Disconnect the power cable again without switch off the printer.<br /> 9. Take out the both cartridges.<br /> 10. Close the cover.<br /> 11. Connect the power cable and turn on the printer.<br /> 12. Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
on Feb 17, 2011 | Canon MX300 Office All-In-One Printer
How do you get the Canon MX300 printer to scan? I do not know what all you need for a printer to scan but when I press the scan button it just beeps and nothing happens.
Hİ,
First You must install "MP Navigator EX" program to your Pc..and then you can control every feature of the scanner from your computer..(not from scanner...)
This program normally comes with the MX300 as CD ,if not you can download from Canon support page....Good luck..Regards
Mar 31, 2010 | Canon PIXMA MX300 All-in-One Printer
Hello there ok
Try
Here the Solution to reset the ink level for Canon Pixma MX300 follow this steps to reset the ink level in your canon MX300.
3. While pressing the power button, press the “Cancel/Stop” button (red button).
4. Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says “idle”.
5. Press “>” (next button) once “Shipping Mode 3′ then Press the “OK” button. Press “OK” again for “without cleaning”.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 07, 2010 | Canon MX300 Office All-In-One Printer
Canon mx300 not printing
Hi
It is ink low error U051
1. Disconnect the power cable
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The prints turns into a kind of factory mode...(wait for about 10 seconds, utile it says "Idle")
6. Press the ">" (next to the "OK" button) once.” Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print.
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Or try this
Nov 02, 2009 | Canon MX300 Office All-In-One Printer
Cant print using Canon Pixma MX300
Hi
Or try this
Sep 08, 2009 | Canon PIXMA MX300 All-in-One Printer
Scanning with Windows XP
first make sure the printer is installed to the os, if the cd wont work download the driver from the manufacturer website. then connect the device to the computer so that the scan can actually go some place. i believe this particular model has a scan buitton on the device however i am not so sure so please double check. if it does press the button. if not u have to scan the document with the software installed
Jul 08, 2009 | Canon PIXMA MX300 All-in-One Printer
How do i scan on the pixma mx300 I've tried putting the paper in closing and pushing the scan button then ink color black and it does nothing
Open up Windows Photo Gallery or whatever you use... Import from camera or scanner. The button isn't on the printer. Good luck!
Mar 20, 2009 | Canon PIXMA MX300 All-in-One Printer
What is the scan procedure for the canonpixma mx300?
First make sure you download the right driver/software for MX300 according to your OS. Then with the printer connected to the computer u can proceed:
press the scan button on the printer
then on your pc click my computer and u should then see the printer scanner at the end, right click on that and you will get the scan option.
I too couldn't do it for a bit then kept fiddling till i was able to and I have Windows XP.
Hope this helps.
Jan 23, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon PIXMA MX300 All-in-One Printer Logo
106 people viewed this question
old marine
old marine
