I have a 800/1200 oscillating dish heater (optimus h-4438) i have an alarm light on it so it has stopped working. up to this point i have had no problem with it - it has been perfect. can you tell me what is wrong and what i can do to correct it ??
  • 10,319 Answers
Initial quality is questionable. Within a few days buying the unit the buttons stopped working. I was about to return it. I took a chance and I opened the unit and figured out the problem and fixed it buy tightening some screws and repositiong the circuit board. I am not sure how many would be inclined to do all that.
Posted on Feb 07, 2010
My dog chew my optimus coil dish heater outlet wire.IS IT SAFE TO STRIP THE WIRE AND REPLACE A NEW HEAD
Since I don't know your skill level I would say have it repaired to be safe. Sell the dog.
Aug 15, 2016 | Optimus Heating & Cooling
Why does it shut off completely and has to be manually turned back on?
Probably a safety feature to keep it from getting too hot. temperatures above a certain level could easily start a fire.
This unit has a temperature control with will turn it of after a certain temperature is reached it also has a timer that will turn it off.
It might also be a malfunction in one of those controls.
Dec 19, 2015 | Optimus H-4501 14" Oscillating Pedestal...
OPTIMUS H-4438 ELECTRIC HEATER ALARM LIGHT UP NO HEAT STILL ROTATE
I took it apart found nothing. Put back together took the plastic screw driver with the unit on,gentlly tapped the plastic houding opposite of the heat senser at the top of dish and it works!
Nov 04, 2011 | Optimus H-4436 Electric Heater
Hi, Will the Optimus H-4500 14-Inch Oscillating Pedistal Digital Dish Heater eventually heat up a 12' X 12' room? Thanks.
I guess it all depends on how warm you want the room. I typically sleep with mine on low in the master-bedroom with connecting bathroom. When it's not on the room is in the low 50's. When I do run it for about 5 hrs (while sleeping) it keeps the room around mid 60's.
Nov 11, 2010 | Heating & Cooling
Every time i turn on my heater, the alarm light goes off and the heater will not turn on.
I would buy another heater unless, that one is new and try to return it..
May 28, 2010 | Optimus H-4436 Electric Heater
Optimus heater h-4438
Check on the heater coil using the multi-tester. Set it at Ohms 1 x 10 position.
1. Switch it off and disconnect it .
2. Disassemble the electric heater.
3. Put the multi-tester probe (red and black) at each
end of the heater coil.
4. If the reading is almost zero, then it is okey.
Otherwise, you have to replace it.
5. Then, reassemble the electric heater.
6. Plug it back to the electric outlet, and switch on.
Nov 03, 2009 | Optimus H-4436 Electric Heater
Problem w/ Optimus space heater model H-4438.
I have the same problem. I removed the center panel on the back of the dish and found a fuse inside a white insulating sleeve. The fuse is open, preventing the current from reaching the heating coils. On the fuse it says 121 C. and 15 A.; I assume that it is designed to blow if the temp. of the dish exceeds 121 centigrade or the current exceeds 15 Amps. I don't see any reason to believe that either has happened so I suspect that these fuses just spontaneously fail. Now I just need to find a source for new ones. I wouldn't recommend jumping the fuse as it could lead to a fire.
Jan 10, 2009 | Heating & Cooling
Optimus H-4438 Electric Heater
Optimus electric heater can be found on amazon, click here and take a look: Amazon com optimus electric heater. I hope this was helpful. Cheers
Jan 10, 2009 | Optimus H-4436 Electric Heater
Alarm light staying on.
Feb 22, 2008 | Heating & Cooling
Heating & Cooling Logo
166 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
