Question about Sony Televison & Video
Our Sony TV goes into standby mode periodically and we cannot get it to release. After a period of time it releases automatically. What is wrong and how can we correct this. We have Comcast cable and they have checked from their end and say it isn't cable.
SOURCE: Nikon D40 won't stay in remote mode
read manual ! you can change it up tp 15min.
Find in Custom Settings > "17 remote duration".
if it is not there change first in SETUP MENU>CSM/Setup menu from "simple" to "full"
Posted on Nov 05, 2007
ctf1800
  • 4402 Answers
SOURCE: SONY KDP 65WS550
are you sure it 10?
these are the codes i have
· 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
· 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
· 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
· 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
· 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
· 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
· 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
· 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
· 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
Hopefully, the descriptions of the blinking lights and the symptoms and problems will point you in the right direction to tell the problem with you Sony Projection Screen Television. If it is not enough, do not worry -- in the coming few posts I will talk about entering the Diagnosis and Service modes for your television set!
Posted on Mar 14, 2008
SOURCE: Tv shuts off automatically periodically
There is a switch located behind the lamp vent panel on the back of the set. Remove the vent panel and hold this switch in the down position while you turn the set on. The set should stay on as long as this switch is in the down position. If the set stays on, check the inside of the cover you just removed from the set. Locate where the switch rests against it and make sure that it is not broken. When you reinstall the vent cover, lay it flat against the back of the set and slide it down so it can catch the switch on the way down. Most times this switch will come loose and flip up while moving the set. Or if you just replaced a lamp and didn't get the switch back in the right position.
Posted on Mar 03, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Posted on Apr 15, 2009
  • 8 Answers
SOURCE: screen goes blank, sound still on
even though lamp came back on and worked for awhile, it was a bad lamp. replaced lamp and set works
Posted on Apr 16, 2009
My tv power comes on with a snowy black and white background but after some time it goes automatically into standby mode.
Hi camadino ,
You need to set the auto standby mode to a long time for e.g. 3 hours or disable it.
Check the settings for standby mode and you would be able to set it accordingly.
You could access the TV's settings via the panel on the TV or via the remote which comes with it.
Hope this helps ...:)
May 10, 2011 | Sony KLV32S400A 32 in. LCD TV
System defaults to "Automatically fix file system errors"
Open my computer and right click on your local drive click properties click tools click check now remove check from Automatic fix file system errors start same with the more drives
Jul 04, 2010 | Sony Computers & Internet
The ps3 will not pick up on the tv untill the hard drive is out the it says it wont work caues the hard drive is out
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 26, 2009 | Sony Video Game Consoles & Games
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
My PS3 has no menu. No sound or video
try video reset
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
My ps3 stopped showing picture ,it was working i turned it on i saw user screen then nothing,already replaced video cord
try video reset
My ps3 has a fuzzy screen when playing on it this only happened a few days ago should i tae it back as it is only 4 weeks
first try video reset
then take it back as these steps will not void warrenty
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
Sony kv-34hs429
The 6 blinks are a diagnostic code to indicate the problem circuit. I'm on the road at the moment, but will look up the code when I get to the shop. In the mean time, a few questions:
1) Does this occur all the time or just after or before a warmup period?
2) Have you noticed that this is occurring more frequently lately or did this just start?
Thanks,
Dan
Aug 07, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
No picture, Standby blinks then goes out
Sony Trinitron XBR
Problem/ Standby Flashes Power button
Aug 12, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby mode on dvd player
Has it recently been zapped by lightning? Ive never heard of this happening but i can tell you its not a problem you can fix. I suggest getting your money back or exchanging it for a new one.
Nov 29, 2007 | Sony DVP-NS400D DVD Player
Televison & Video Logo
216 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
