Question about LaCie (300770) 250 GB Hard Drive
The Pwr light flashes when I turn it On, there is No Icon on the Monitor when I select My Computer
  • klferrell Feb 07, 2010
    I didn't see any line Item under Disk Mgmt for the Ext HD only the (C) Dr and a Basic and athese were both displayed as Healthy.
    What is the Indication of a Flashing Light?
    Brigadier General:
  • 3,917 Answers
You need to go to the control panel, then to administrative tools>computer management>storage>disk management. Here your drive should be listed if windows see it, if it is not a valid partition it will not show up in "My Computer" like the other drives. The meaning of valid partition, for example windows knows or uses (fat or ntfs ). However if the drive shows up a new/raw/unformatted you can use the options provided by the disk management console to do best to see it. Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 07, 2010
How do I turn flash on and off?
The multi selector is the round control on the rear of the camera with the OK button in its center.
The flash mode button is the top button on the selector, it has a lightning flash icon.
Press the flash mode button on the multi selector.
Highlight the desired mode and press the center of the multi selector.
The flash modes are:
AUTO; Flash fires automatically when lighting is poor.
AUTO WITH RED-EYE REDUCTION; Reduces "red eye" in portraits.
OFF; Flash will not fire even when lighting is poor.
FILL FLASH; Flash fires whenever picture is taken. Use to "fill-in" (illuminate) shadows and back-lit subjects.
SLOW SYNC; Flash illuminates mainsubject; slow shutter speeds are used to capture background at night or under dim light
The selected flash mode icon appears at the top of the monitor.
Oct 22, 2014 | Nikon COOLPIX L3 Digital Camera
My GX520 pwr light is green, on the board is an amber Led, the somputer boots up, it goes the full process, until the arrow appears on the monitor. no Iconn are displayed on the desktop
If your computer gets to that stage, then I would guess you have an OS ( Operating System ) problem. Try booting from your XP installation CD. If that works then you may have to re-install Windows.
Jun 23, 2012 | Dell OptiPlex GX520 PC Desktop
Not working
it could be possible that the pwr cord might have gone bad. change it .
before doing that try disconnecting the pwr cord from the back of monitor and hold the pwr button for 30 sec. connect the pwr cord properly and then restart the comp. if this does not work then check with other pwr outlet. if this doesnot work then replace the monitor its a problem with the monitor and needs to be replaced// nothing is wrong with the computer//
May 07, 2010 | Fuji FP-988D 19" Flat Panel LCD Monitor
Pwr Led blinks orange, with black screen (monitor is connected to computer)
Take off the monitor and hook up another known working monitor to the computer and turn the computer and monitor on. If the computer turns on with video then you know the original monitor is bad and would need to be replaced.
Jan 04, 2010 | Sony SDM-HS75P/S 17" LCD Monitor
Monitor goes blank but is still connected
Do bios update on Computer.Select the product number and search on Website for bios and than try the monitor
Oct 13, 2009 | Computers & Internet
Veiwsonic VA1912WB flashes then goes blank
You have a very common problem that happens to many LCD monitors after 2-3 years of use. Your monitor has blown the power supply that controls the backlight bulbs. Go to our web site at: www.ccl-la.com/badcaps.htm and look at the pictures of what blown capacitors look like. Open the back of your monitor and replace any of the parts that look like the ones in the pictures and you should be back going again. Be sure to usehigh temp (105c) replacements. Resolder them in with the side polarity stripe going the same direction and the old one came out. The values of the bad parts will be marked on the sides of the ones you take out, they can be ordered online from us or several other places, the one from Radio Shack are not suitable for use in the high heat inside on the monitor and will soon blow again.
I hope this helps, if so please rate my solution.
If you have more questions just ask.
Buddy
Corporate Computer
www.ccl-la.com
Sep 12, 2009 | ViewSonic VA1912WB 19" WideScreen Monitor
Computer won't boot , constant PWR problem (
i am also using same motherboard dg31pr intel but it does not reboot .......
because this is the problem with you monitor , just you change the monitor and try again .
this is only the solution to solve this as the tecnition said me.
Mar 20, 2009 | ASUS A7V400-MX Motherboard
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Kds k717s lcd monitor
That have to do some servicing in the power section at the main board.
Feb 28, 2007 | KDS K717s 17" LCD Monitor
LaCie (300770) 250 GB Hard Drive Logo
66 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
