Question about KitchenAid 30 in. Architect II Series 4.3 cu. ft. Single Convection Steam Oven - KEBU107SSS Dual
Kitchenaid oven KEBS107SS00 Preheat audible signal no longer sounds when oven reaches temperature
5 Suggested Answers
  • 125 Answers
SOURCE: Ovens won't heat up beyond 250 degrees.
if you cant program it for more than the 270 you may have changed it from farienhiet ( bad spelling) to celcius. pushing and holding broil may switch it back.
Posted on May 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kitchenaid Superba electric convection oven not preheating right
Your temperature sensor is failing. Replace the temp sensor.
Posted on Jul 21, 2009
  • 153 Answers
SOURCE: my kitchenaid built in double oven takes over an
well plz read the menual
carefully
Posted on Jul 22, 2009
  • 2696 Answers
SOURCE: I have a KitchenAid double oven with convection on
it will either be the sensor or the board,hopefully it's not the board,the part number for the sensor is 4455636 and subs to w10131825,the sensor is around 100 bucks,there should be a tech sheet on the machine most likely behind the touch pad on the top,it will tell you how to check the sensor with a meter,just unplug the sensor and read it out i think it's around 1100 ohms but check that on the tech sheet,if it's not the sensor most likely it will be the board part number 4453661 and that's around 300 buckseverything runs through this computer board but the sensor tells it how hot it is in the oven hopefully you have a bad sensor.let me know what you find,you'll most likely have to pull the oven to repair it but maybe just enough to get the top open,good luck
Posted on Sep 04, 2010
Kenmore oven shuts off before preheated
On any gas appliance there is a high and a low limit temp stat which could be indipendant or on the gas valve it's self, that is faulty.
When the oven reaches temp, it cuts out. sounds like faulty over heat stat.
Mar 21, 2014 | Ovens
Kitchenaid Superba Electra oven doesn't reach set temperature. When we set the temperature for 400, it only gets to 375. Is there any way to fix this?
sounde like a temperature probe going bad or thermostat out of adjustment .ask your parts dealer if your oven uses a temperature probe or thermostat.
Oct 19, 2013 | Ovens
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
My oven seems to take a really long time to preheat -- about 20 minutes to reach 350 Fahrenheit. Is that how long it is supposed to take? Thanks
That would seem to be longer then normal...
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Feb 04, 2011 | KitchenAid Ovens
I have a KitchenAid double oven with convection on the top and conventional on the bottom (model #KEBC207KBL0). When I set the temperature and preheat the top oven, the display shows the temperature rising...
Sep 04, 2010 | KitchenAid KEBC207 Electric Double Oven
Preheating
hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
May 12, 2008 | Ovens
KitchenAid 30 in. Architect II Series 4.3 cu. ft. Single Convection Steam Oven - KEBU107SSS Dual Logo
76 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
